Del's Titanic build. Academy limited edition
  • adt70hk
    • Sep 2019
    • 10415
    #31
    Del
    That is going to keep you very busy indeed!
    All the best for the build.
    • wotan
      • May 2018
      • 1150
      #32
      Wow that looks like a kit and a half. definitely one to watch.
      • Nicko
        • Apr 2019
        • 1410
        • Nick
        • East Anglia
        #33
        Liking your table covering Del and I think BattleshipBob has one like that too. Here's what we have - pic from my old kitchen table setup.....
        [ATTACH alt="20171122_182520.jpg"]415382[/ATTACH]
        :smiling3:
        Nick
        • Del640
          • May 2020
          • 1151
          #34
          :smiling3:
          Nick
          It's a great cover, wipe down and very robust.
          • Del640
            • May 2020
            • 1151
            #35
            ...and we're off!Click image for larger version
              • 15723
              Hi Del
              They say the greatest journey starts with the first step.
              • Del640
                • May 2020
                • 1151
                #37
                ..that didn't take long for a confusing bit! :
                Instructions require me to remove these parts (and quite a few large areas of the deck)
                Problem is they're clearly stairs?
                The larger parts will require a proper cutter due to the amount and thickness so I've ordered a Dremel that I'll receive tonight.
                So ...these stairs.
ID:	1144989Click image for larger version
ID:	1144990Click image for larger version
                • Del640
                  • May 2020
                  • 1151
                  #38
                  ....in the meantime I've built the iceberg.
                  (Well, when I say built I meant froze)Click image for larger version
                  • Mr Bowcat
                    SMF OG
                    • Dec 2016
                    • 4605
                    • Bob
                    • London
                    #39
                    I'm following your build Del, I quite fancy building this kit at some point.
                    Si vis pacem, para bellum.
                      Are they to be removed and replaced with PE equivalents?
                      If so, I don’t envy you having to make the treads!
                      • Nicko
                        • Apr 2019
                        • 1410
                        • Nick
                        • East Anglia
                        #41
                        (Well, when I say built I meant froze)[ATTACH=CONFIG]n1144992[/ATTACH]
                        Hey Del... are you sure that's the same scale as the ship???
                        Looks a bit small to do too much damage... :smiling3:
                        Nick
                        • Del640
                          • May 2020
                          • 1151
                          #42
                          Nick
                          Good point, well made (unlike my iceberg)
                            • 18271
                            Thats what the captain on the real ship said.
                            • Del640
                              • May 2020
                              • 1151
                              #44
                              Reluctantly removed a lot of decking this morning, I've left the stairs in as there is no reference to a replacement that I can see, I can and will remove them later if required though.
                              LED strip's placed into hull (once I managed to unstick them from my fingers/eyebrows etc...the STICKIEST adhesive I've ever come across....think flypaper)
                              Hull pre-painted so that Vallejo red hull paint was a tad pointless!!!Click image for larger version
ID:	1145079Click image for larger version
                              • Del640
                                • May 2020
                                • 1151
                                #45
                                Hull placed onto the stand, don't know if this is taboo as such having not built a ship before but the destructions said stick it on the stand!Click image for larger version
