Del's Titanic build. Academy limited edition
At least we know it’s not the led’s!
I would examine that switch and try switching the sockets round before binning it.Comment
HI Del ive posted the switch to you this morning an its on it way to you an when you get it after youve soldered on your wires do not try an c/a it as it will get glue in it an become no good best idea i use with these tiny switches is cut a tight fitting hole in a bit of plasti card an just press the switch in place then glue the plasti card to the ship where you want it chrisComment
My intention is to place it at the rear of the stand if it doesn't sit happily in the existing power hole.
Either way it'll be fine!
Thanks again.
DelComment
First wooden decking placed, it's purported to be pre cut but it isn't...fortunately it's pre marked so a fresh blade in my Swann Morton and away I go.
The sheet has an adhesive on the backing which is bloody strong...no mistakes, you need to get it down first time, it doesn't move and you can't shore it up either (you can before you remove the back but it's still tricky when you come to apply it!)
DelComment
