Hachette build the bismarck 1/200 scale
  • peterairfix
    • Jul 2012
    • 11074
    Another bismarck i here you cry this one is 140 magazine part work i still have 40 to find but I have 95 to keep me happy and when I purchased this build the skeleton was already built i have just completed three quarters of the first layer of planking.Click image for larger version
ID:	1149511Click image for larger version
ID:	1149512Click image for larger version
  • peterairfix
    • Jul 2012
    • 11074
    All planking finished actually it was fairly easy for a change. Click image for larger version
ID:	1149610Click image for larger version
ID:	1149611Click image for larger version
    • adt70hk
      • Sep 2019
      • 10409
      Looking very good Peter.
      • peterairfix
        • Jul 2012
        • 11074
        All planking and the basic Hull shape has been finished.
        And the first piece of resin on the bow Click image for larger version
ID:	1149739Click image for larger version
ID:	1149740Click image for larger version
ID:	1149741Click image for larger version
        • peterairfix
          • Jul 2012
          • 11074
          Started some filling on the bow and stern and started building up the super structure Click image for larger version
ID:	1149822Click image for larger version
ID:	1149823Click image for larger version
ID:	1149824Click image for larger version
ID:	1149825Click image for larger version
ID:	1149826Click image for larger version
ID:	1149827Click image for larger version
ID:	1149828Click image for larger version
ID:	1149829Click image for larger version
ID:	1149830Click image for larger version
ID:	1149831Click image for larger version
          • peterairfix
            • Jul 2012
            • 11074
            From a card bismarck back to the wood one still concentrating on the hull planking I am half way through the second layer and have added the bilge keels and surrondsClick image for larger version
ID:	1154714Click image for larger version
ID:	1154715Click image for larger version
            • boatman
              • Nov 2018
              • 14462
              • christopher
              • NORFOLK UK
              HI Peter this bismark is looking good an as its nr all wood will this sail or just a static model ?
              chris
              • peterairfix
                • Jul 2012
                • 11074
                chris
                Just static for the moment but it might change
                • peterairfix
                  • Jul 2012
                  • 11074
                  Here's the next batch of work I have finished the second layer of planking and now add two sections with portholes in at the bow and stern I will now spend the next couple of days sanding and filling. Click image for larger version
ID:	1154814Click image for larger version
ID:	1154815Click image for larger version
                  • boatman
                    • Nov 2018
                    • 14462
                    • christopher
                    • NORFOLK UK
                    nice work Peter
                    chris
                    • peterairfix
                      • Jul 2012
                      • 11074
                      Almost completed the Hull all the main sanding done just filler at the bow and stern to do but I need to wait until tomorrow for it to harden.
                      I had to do the work outside as it's the only place I can work on it as it's so big. Click image for larger version
ID:	1154897Click image for larger version
                      • peterairfix
                        • Jul 2012
                        • 11074
                        Just given the Hull a spray and I can now see how much work I have to do so it's going to be filler and sandpaper galore for the next couple of days, weeks, years etc etc Click image for larger version
ID:	1154959Click image for larger version
                        • boatman
                          • Nov 2018
                          • 14462
                          • christopher
                          • NORFOLK UK
                          Just given the Hull a spray and I can now see how much work I have to do so it's going to be filler and sandpaper galore for the next couple of days, weeks, years etc etc [ATTACH=CONFIG]n1154959[/ATTACH][ATTACH=CONFIG]n1154960[/ATTACH]
                          HI Peter ive just gone through all that sanding on my tiger hull an oh you will have fun an earnt you goin to fill the porus wood holes with sandin sealer as its a lot easyier than fillin a little bit at a time with normal filler as all you do is brush it on like paint an it will come up a nice hard finish after sandin an havnt you got a eletric sander ?
                          chris
                          • peterairfix
                            • Jul 2012
                            • 11074
                            HI Peter ive just gone through all that sanding on my tiger hull an oh you will have fun an earnt you goin to fill the porus wood holes with sandin sealer as its a lot easyier than fillin a little bit at a time with normal filler as all you do is brush it on like paint an it will come up a nice hard finish after sandin an havnt you got a eletric sander as well.
                            chris
                            I don't have an electric sander but I think I best invest in one as it will come in handy for my victory.
                            And where do I find sanding sealer.
                            • boatman
                              • Nov 2018
                              • 14462
                              • christopher
                              • NORFOLK UK
                              HI Peter yes invest in a eletric sander as it makes easy work of sandin as i hate doin this but its got to be done with a mask an goggles for protection an sandin sealer can be obtained at a model shop that sells R/C planes as thats where i get mine from but as its so good its a tad exspensive but i bought a big litre tin for about 20 quid for my nimitz hull about 15 yrs ago an i used this on my tiger hull as it keeps for yrs in a tight tin but did you say you have painted the hull already as if you have then you cant use sanding sealer as its may attact the paint an then it will craze an mess up the hull so have you painted the hull ? as i said sandin sealer must be used only straight on the bare wood an not paint
                              chris
