Heller 1/400 H.M.S. Hood.
  • spanner570
    • 15482
    #46
    Thanks for the very nice posts, chaps.
    Rear funnel.
    This had some elementary surround, but I beefed it up a bit. The white bits are my plastic card.
    This is the kit part. Excluding the white card bits.
    The finished funnel surround.
    Cheers.
    Ron
    • Mark1
      • Apr 2021
      • 4156
      #47
      A bit of attention to detail makes all the difference.
      • rtfoe
        • 9123
        #48
        Hi Ron, I wasn't sure I was in the right place and was going to ask if you were the right Ron. The scratchery wasn't the usual we know of so where have you hidden Ron you imposter.:smiling2: Jokes aside well done on the major improvements even if you say it's not accurate but it looks alright from where we stand. You've got balls to improve this horrible kit.
        Hope you've got the stamina to run the course. BTW I'm a stowaway...lost my ticket for a cabin and have been stoking the boilers down below.
          • 18944
          Nice upgrades Ron. This is bringing the whole thing up a notch or twoโ€ฆ.
            • 15811
            Hi Ron
            Most excellent funnel improvements.
            Hopefully, this will suffice. Anything different and Jim might well get bored and fall asleep....Ain't that right, Jimbo?
            Me, fall asleep when there is the prospect of a whole herd of Zulus charging down off the hill or Mrs "Chucker" Ron launching the whole thing skywards - no chance :tongue-out3:
            • spanner570
              • 15482
              #51
              Thanks boys.
              Doing the extras is hard work, but to leave it.......
              Richard. I suppose a similar analogy to the 'Hidden Scratchery' Ron, is the fact that I have a pair of nipples, and should I have become pregnant, then I would have been be able to have a bash at the job in hand. Needs must and all that sort of thing........
              Jim, seeing your funny post has reminded me that my Rorke's Drift diorama has yet again been knocked to the floor and the Zulus were indeed charging down hill. :sad-face:
              Also, I really must get a grip and finish the aircraft ramming thingy I've been doing, or the missus will loose her chucking ability you mentioned.
              Ron
              • spanner570
                • 15482
                #52
                The forward bridge was by far the worst for detail - Save for two very faint window outlines, an almost a complete lack of it!
                On this the lower section, you can just make out the portholes, vents and where the life-rafts go. That's it.
                The upper deck surround is moulded in. The lower one, I made out of a thin strip of plastic card. I need to make many more of these surrounds as I don't want the crew walking off the edge of the decks. Let this one suffice to show the lack of detail.
                Apart from the surrounds, I added card doors and windows etc. The windows I painted on with a cocktail stick.
                You can see the windows here. I also added a load more 'Bits' which I won't bore you with. But they all helped to liven the thing up a tad.
                There is still more to add to this, but it's a start.
                ...and I need a break!
                • spanner570
                  • 15482
                  #53
                  Break over....
                  Funnels fitted. Along with some kit bits.
                  Ready for the tripod mast and the thing wot sits on the top of it.....
                  Cheers.
                  Ron
                  • spanner570
                    • 15482
                    #54
                    The tripod mast legs are a tad too short, so I scrapped the kit one and made me another set out of sprue.
                    Also the star thingy arms which sits on top of the legs are too short, so I extended these using plastic card. (Not much card left now!)
                    Top of the 'Star'
                    ...underside of same.
                    I found the easiest way to paint all the very small windows is to first paint a dark grey band where the windows are to go.
                    Then with a cocktail stick, paint in the light grey surrounds. Leaving the darker grey windows.
                    Here is the finished assembly fixed to the bridge structure.
                    Cheers.
                    Ron
                      • 15811
                      Hi Ron
                      Clever stuff. Painting the windows in like that - makes a big difference.
                        More water 570 that rums a bit tasty.
                        Very nice mast thingy , your were right to do the alteration you'd never like it.
                        Yours 453.
                        Hospital Wing bed 6.
                        • Allen Dewire
                          • 4741
                          • Allen
                          • Bamberg
                          #57
                          Evening Ron,
                          I have been watching silently on this, but I have to say you have done a fantastic job on the scratcheritus here. Most excellent work Sir!!! I knew deep down that you would finally take that big step to improve this kit and it worked. A tip of me hat to you!!!...
                          If I may, a word to our good friend 453 aka Dude2,
                          John, there is no drain plug under there and you don't have to change the oil in a chair. Maybe the KIA, but not the chair.............
                          Prost and welcome to the dark side Ron
                          Allen
                          • spanner570
                            • 15482
                            #58
                            Thanks ever so much for the excellent comments, boys.
                            Allen, I have it on good authority that the image posted of 453 was taken from a security camera mounted high up in his cell. It shows him looking for a sound devise he is certain has been planted on his Commode and not him working on an imaginary car!
                            570
                              • 22788
                              #59
                              Some cracking work Ron, great alterations.
                              • spanner570
                                • 15482
                                #60
                                Thanks Ian.
                                The front breakwater thing was way too 'Heavy', so I cut it down by half, reshaped it and added smaller wings and a couple of access doors.
                                The kit one. You can just make out my pencil line where I will cut it to. Then add more of an angle to the face of it.
                                Modified.
                                Fitted, along with a second set abutting 'B' Turret.
                                Cheers.
                                Ron
