Mirage Hobby 1/350 HMS Spiraea - Flower Class Corvette
    I've stalled on my Golden Hind - I can't get round to finish the decals.............
    Anyway, I've decided to start another floaty thing:
Name:	Mirage Spiraea.jpg
    These Mirage models are hard to come by - they aren't expensive, but there doesn't seem to be a UK distibutor. There are several other Flower Class in the range - this one has PE parts with it.
    Sprue shots
ID:	1154550Click image for larger version
ID:	1154551Click image for larger version
    There are quite a lot of tiny parts, and the sprue attachment points are rather chunky, luckily there doesn't seem to be any flash.
    Decals rather disappointing, as the Spiraea had coloured bands around it's funnel, which I thought would be included
    The instructions aren't that good - they're annotated computer renders, which aren't printed in high quality ( unlike the colour profiles ), but I dare say I'll manage.
    The Flower Class have been modelled pretty well: in 1/72 by Revell ( ex Matchbox ) and 1/144 as well - and a number of 1/700 resin kits.
    Spiraea is more commonly known as 'Meadowsweets' - so many of these Flower Class corvettes were built, some of the names are pretty obscure!
    As is my fad at the moment, I'm going to waterline this, with perhaps a rough sea - it's only small, about 180mm long, so it'd be easy to over do it. I won't need any of my MDF bases for this - plastic card will be rigid enough.
  • PaulTRose
    • Jun 2013
    • 6464
    • Tattooine
    look forward to seeing this go together cos i keep looking at these mirage hobby flowers, but keep chickening out lol
    Per Ardua
    • rtfoe
      • 9086
      Dave, this looks interesting. I've not come across a Flower class corvette in 1/350 scale and also the brand so I'll get chair and sit for this if you don't mind.
        I've had a bit of a browse of pictures of the Flowers at sea...............................
Name:	flower sea 01.jpg
ID:	1154592Click image for larger version
Name:	flower sea 02.jpg
ID:	1154593Click image for larger version
Name:	flower sea 03.jpg
ID:	1154594Click image for larger version
Name:	flower sea 04.jpg
        These are all later Flowers ( mast aft of the bridge ), but same hull form.
        Some ideas there - even if some are a little too dramatic!
          Richard,
          Mirage Hobby can't be a big model company, and their availability is very patchy - they make 4 Flower Class Corvettes & a few U-boats in 1/350 ( also some Polish torpedo boats ). They do make some interesting models in 1/400 ( why the difference in scale, I don't know ) - Pauk & Tarantul Class modern corvettes - Polish WWII destroyers, and USN 4-piper destroyers in various guises ( Airfix reboxed two of these, St Albans & Montgomery ). Mirage also produce 1/35 AFV, 1/72 & 1/48 aircraft - all with a strong Polish flavour! From the few I've seen, quality can be variable, but the ships look OK
            • 15702
            Hi Dave
            I've not come across Mirage models before. I like that first reference photo.
            • rtfoe
              • 9086
              I've seen the two US Four stackers by Airfix at the LHS and I think they're still there. Might just get one of them since I liked the old HMS Campbeltown.
              Dave, the images of the corvettes are great. These corvettes were unsuited for high seas with their curved keel making them roll all over and uncomfortable for the crews but they established themselves well in the conflict in the Atlantic.
                • 18907
                They are some great images Dave. Not sure I’d want to serve in one of those ships though, an attack of seasickness could prove terminal :money-face:
                  Tim,
                  the corvettes were crewed almost exclusively by 'hostilities only' the officers, as well, maybe having a reservist as skipper ( As in 'The Cruel Sea' classic book & film ). 294 Flower class were built - based on a pre-war whale catcher! They were slow & lightly armed, but could be built quickly in commercial yards. They saw service with many navies, including the USN, both during & after the war.
                    • 18907
                    Hi Dave
                    I’ve both read and watched the cruel sea many times. Fantastic as both a book and a film. One day I might build one of these as Compass Rose! Never realised they were hostilities only crewed though, that makes the seasickness even worse…..imagine sailing through North Atlantic winter in one of these as your first commission! I don't get seasick as a rule, but wouldn’t want to test myself in one of those images!
                      Hi Dave
                      Tim,
                      In my time in the MN, I was never seasick! ( though through booze - OK ). I'm not so sure about something so small, though. I've experienced Force 11 in the Atlantic - for several days, and the main bad feature is tiredness, you can't sleep properly, you have to use one hand to hold on, and no hot food ( other than drinks ), as it was far too dangerous to use ranges. Everything loose had to be lashed down & checked regularly - we had to reduce speed - to minimise wave effect ( and the propeller racing! ), in the engine room, it was just clinging on and doing the minimu needed to keep everything going - Ah - Happy Days!!!!
                        Construction begins - some careful clean up needed, some nasty ejector pin marks ( luckily proud ). The plastic is rather soft................
                        Just a few bits of filler on the deck edge & under the stern - otherwise fit is OK
                        I knocked up a base from plastic card - it's only a short model, so there won't be any problems with the base flexing.
                        The hull itself has some detail....................
                        I've read somewhere that the portholes were permanently welded shut on some ships - but otherwise deadlights would be in place when the ship was at sea ( a metal plate that backed up the glass port ).
                        Next, I'll mark up the hull with masking tape to give a waterline, this'll take a bit of thinking about, as I don't want the deck to lie parallel to the base.............
                          A bit of careful razor saw work, and a bit of sanding
                          It's not that apparent, but the bows are up. In 1/350 a 4.5m wave ( 15ft ) is 13mm, so I think the slight angle will be sufficient. I may paint the hull, before attaching it to the base - the Western Approaches camo may be easier to do off hand......
                            • 18907
                            Progressing nicely Dave.
                              Rather than build up large thicknesses of clay for a large wave - I've laid down layers of plastic card to make a core
                              When I've finished the sea, I'll cut thin plastic card as edging, to make a profile that matches the wave.............
