HMS Hood 1/200 Amati Models
  • Bigfoot57
    • Jun 2015
    • 1103
    #136
    HMS Hood 1/200 Hachette /Amati Wooden kit Build Parts 107-108
    More deck details including the hose pipe housing where the anchor chains goClick image for larger version
ID:	1177600Click image for larger version
ID:	1177601Click image for larger version
ID:	1177602Click image for larger version
    • Bigfoot57
      • Jun 2015
      • 1103
      #137
      HMS Hood 1/200 Hachette /Amati Wooden kit Build Parts 109
      Another lifeboat which we don’t actually do anything with so after all that and with hull still unpainted there is no mention of it in the instructions despite the fact we are now adding major components onto the deck I said sod it I’m painting the hull see the final set of pictures for the result
      After a lot of research I cannot find any reference to Hood having a red anti fouling colour scheme the closest I could find was the one I have used namely a greenish grey for the anti fouling obviously the rubber black dividing line sorry I don’t recall it’s proper name and lastly dark grey for the upper hull etc
      I hope I haven’t offended anyone with this colour scheme that I have chosen as I say this is after researching the remaining D forms that still exist unfortunately those from 1940 to 41 are missing for obvious reasons so the actual colour used in the Denmark straits will remain unknown u less something drastic changes as in with HMS Victory
ID:	1177604Click image for larger version
ID:	1177605Click image for larger version
ID:	1177606Click image for larger version
ID:	1177607Click image for larger version
ID:	1177608Click image for larger version
ID:	1177609Click image for larger version
ID:	1177610Click image for larger version
ID:	1177611Click image for larger version
ID:	1177612Click image for larger version
      • Bigfoot57
        • Jun 2015
        • 1103
        #138
        HMS Hood 1/200 Hachette /Amati Wooden kit Build Parts 110-111
        Building more lifeboats relativity simple same as before
ID:	1177953Click image for larger version
ID:	1177954Click image for larger version
ID:	1177955Click image for larger version
ID:	1177956Click image for larger version
ID:	1177957Click image for larger version
ID:	1177958Click image for larger version
ID:	1177959Click image for larger version
ID:	1177960Click image for larger version
        Regards
        Colin
        • Bigfoot57
          • Jun 2015
          • 1103
          #139
          HMS Hood 1/200 Hachette /Amati Wooden kit Build Parts 112 Rubber Rafts
          Another simple section not much to do the oars we’re troublesome to say the least as they are pe they bend easily as you can in some of them
ID:	1177987Click image for larger version
ID:	1177988Click image for larger version
ID:	1177989Click image for larger version
ID:	1177990Click image for larger version
ID:	1177991Click image for larger version
          • Bigfoot57
            • Jun 2015
            • 1103
            #140
            HMS Hood 1/200 Hachette /Amati Wooden kit Build Parts 113-116
            More Deck fittings added I won’t bore you with the detailed instructions on this as they are all the same as before when fitting deck items suffice to say I’ve added around 200 separate pieces from ventilators tool & weapons cabinets bollards and fairleads see the pictures of the model for these additions
            You now have to be very careful how you handle the model for fear of snapping something off and still they don’t mention painting the hull which is ridiculous given the amount of deck detail added which is why I painted mine already
ID:	1177993Click image for larger version
ID:	1177994Click image for larger version
ID:	1177995Click image for larger version
ID:	1177996Click image for larger version
ID:	1177997Click image for larger version
ID:	1177998Click image for larger version
ID:	1177999Click image for larger version
ID:	1178000Click image for larger version
ID:	1178001Click image for larger version
            • Bigfoot57
              • Jun 2015
              • 1103
              #141
              HMS Hood 1/200 Hachette /Amati Wooden kit Build Parts 117-119
              Ok we’ve finished added deck details for now and returned to using wooden pieces to start construction of the bridge of the ship this was fairly straight forward and I’m now waiting for the paint to dry on the brass parts before I can precede any further
ID:	1178003Click image for larger version
ID:	1178004Click image for larger version
ID:	1178005Click image for larger version
ID:	1178006Click image for larger version
ID:	1178007Click image for larger version
ID:	1178008Click image for larger version
ID:	1178009Click image for larger version
ID:	1178010Click image for larger version
ID:	1178011Click image for larger version
ID:	1178012Click image for larger version
ID:	1178013Click image for larger version
              • Bigfoot57
                • Jun 2015
                • 1103
                #142
                HMS Hood 1/200 Hachette /Amati Wooden kit Build Parts 120-121 Prop Shafts fitting
                Hello again been doing loads of sub assemblies this time and marking out and fitting the prop shafts also how I decided on my colour scheme using the latest info from the net via Sovereign Hobbies which I think is the closest you will get to Hoods last known colour scheme
                The final set show the sub assemblies completed so far obviously the main turrets pom-poms and lifeboats rubber dinghy’s were all prior constructions but everything else is new
                I’ve only shown the Starboard side for the props the port is identical due to amount of photo stages this post will be in 3 sections this section 1
                Regards
                Colin
ID:	1178331Click image for larger version
ID:	1178332Click image for larger version
ID:	1178333Click image for larger version
ID:	1178334Click image for larger version
ID:	1178335Click image for larger version
ID:	1178336Click image for larger version
ID:	1178337Click image for larger version
                • Bigfoot57
                  • Jun 2015
                  • 1103
                  #143
                  HMS Hood 1/200 Hachette /Amati Wooden kit Build Parts 122 Section 2 Sub Assemblies
                  I had a major issue here part 723 in part 123 was either not in the kit or I’ve managed to loose it over the 10 year tenure that this kit has endured so I’ve fashioned a replacement using 2 bits of spare deck planking and 4 pieces of scrap sprue brass 1mm in diameter and a home made door from another piece of scrap planking just to be awkward it had to be oval the other side had the mouldings for the surround and the door already moulded onto it
ID:	1178339Click image for larger version
ID:	1178340Click image for larger version
ID:	1178341Click image for larger version
ID:	1178342Click image for larger version
ID:	1178343Click image for larger version
ID:	1178344Click image for larger version
ID:	1178345Click image for larger version
ID:	1178346Click image for larger version
ID:	1178347Click image for larger version
ID:	1178348Click image for larger version
ID:	1178349Click image for larger version
ID:	1178350Click image for larger version
                  • Bigfoot57
                    • Jun 2015
                    • 1103
                    #144
                    HMS Hood 1/200 Hachette /Amati Wooden kit Build Parts 124-125 Sub Assemblies Section 3
                    So here’s the latest section of the build as you can see from the last pictures a lot of sub assemblies have now been constructed some still need painting as can be seen by brasswork still showing
                    Regards
                    Colin
ID:	1178352Click image for larger version
ID:	1178353Click image for larger version
ID:	1178354Click image for larger version
ID:	1178355Click image for larger version
ID:	1178356Click image for larger version
ID:	1178357Click image for larger version
ID:	1178358Click image for larger version
ID:	1178359Click image for larger version
ID:	1178360Click image for larger version
                    • adt70hk
                      • Sep 2019
                      • 10428
                      #145
                      Outstanding work!! A real labour of love. Very well done.
                      • Bigfoot57
                        • Jun 2015
                        • 1103
                        #146
                        HMS Hood 1/200 Hachette /Amati Wooden kit Build Parts 126
                        Here we add more brass work to parts already constructed as you can see some of the brasswork needs to be curved to fit around the structure I used a pencil as a rough curve radius and added slight adjustments using needle nosed pliers to get the final curve shape
                        After that it was a case of assembling the side panels onto the structure as per instructions
                        Next came the 2 black wooden cubes I’ve previously constructed this had brass panels glued to them using pva as I wanted time to slide each piece into position something the ca I’m using doesn’t allow I also prefitted the doors whilst the panels were still on the brass fret as it’s a lot easier to fit fiddly parts like these while there flat and firmly attached to something than afterwards as per the instructions
                        And finally added 2 cranes to another deck piece using Tamiya extra thin quick dry cement
                        Also you’ll notice two type cupola fittings where I substituted thin card for the outer walls this is because the brass supplied refused to stick even after it was annealed to make it more flexible I think that made the glue not want to stick even more so in the end I binned the 2 brass pieces to the spares box and went with card instead besides once painted no one will notice the difference
                        Regards
                        Colin
ID:	1178441Click image for larger version
ID:	1178442Click image for larger version
ID:	1178443Click image for larger version
ID:	1178444Click image for larger version
ID:	1178445Click image for larger version
ID:	1178446Click image for larger version
ID:	1178447Click image for larger version
                        • Bigfoot57
                          • Jun 2015
                          • 1103
                          #147
                          HMS Hood 1/200 Hachette /Amati Wooden kit Build Parts 127-128
                          Good morning not much to do here this time glue a couple plastic pieces together add some pe panels and a bit of painting and finally add some railings to a deck
                          Pictures will explain better than I can
                          Regards
                          Colin
ID:	1178554Click image for larger version
ID:	1178555Click image for larger version
ID:	1178556Click image for larger version
ID:	1178557Click image for larger version
ID:	1178558Click image for larger version
ID:	1178559Click image for larger version
ID:	1178560Click image for larger version
ID:	1178561Click image for larger version
ID:	1178562Click image for larger version
                          • adt70hk
                            • Sep 2019
                            • 10428
                            #148
                            Colin
                            Yours really is something else. I really am enjoying this. Keep up the great work.
                            • Bigfoot57
                              • Jun 2015
                              • 1103
                              #149
                              HMS Hood 1/200 Hachette /Amati Wooden kit Build Parts 129-130
                              This time a bit of wood building and 4 more winches as in previous sections and some sort of superstructure assembly z
ID:	1178564Click image for larger version
ID:	1178565Click image for larger version
ID:	1178566Click image for larger version
ID:	1178567Click image for larger version
ID:	1178568Click image for larger version
ID:	1178569Click image for larger version
ID:	1178570Click image for larger version
ID:	1178571Click image for larger version
                              • adt70hk
                                • Sep 2019
                                • 10428
                                #150
                                Colin,
                                If I've got it right, you've got 10 more steps left. Is that right?
                                ATB.
