HMS Hood 1/200 Amati Models
  • Bigfoot57
    • Jun 2015
    • 1103
    #151
    Yep that’s correct so something pretty drastic got to take place in the remaining issues as at the moment Hoods looking like it’s in the middle of a re-fit and they still haven’t said paint the hull which I find is completely illogical as Spock would say given the amount of deck pieces now added
    I painted my hull about 2 weeks ago around issue 100 and in so doing I managed to damage 2 of the 4” secondary guns bending the barrels on one and snapping one the barrels off the other completely
    Regards
    Colin
    • adt70hk
      • Sep 2019
      • 10426
      #152
      Originally posted by Bigfoot57
      Regards
      Colin
      That does sound rather illogical as you say. I hope the barrels were repairable?
      • Bigfoot57
        • Jun 2015
        • 1103
        #153
        Yes I have repaired them unless you look really close they look ok not perfect by passable just one of the joys of modelling I’m sure we’ve all bent and snapped of bits we didn’t want to in our adventures into the miniature world
        Colin
        • adt70hk
          • Sep 2019
          • 10426
          #154
          Colin
          Indeed....actually I did it twice yesterday on one of the two Bf109s I'm doing..... Not sure if it was the same gun each time.....
          • Bigfoot57
            • Jun 2015
            • 1103
            #155
            HMS Hood 1/200 Hachette /Amati Wooden kit Build Part 131
            Ok time to step up if you pardon the pun this entire part was about constructing 10 sets of steps 7 of which are seen here the rubber hosing and wooden blocks are for the motorised water version which this not so the 1st 4 pages of instructions do not apply
            Roughly the same procedure for most with a couple of additional railings and platforms left and right for 2 of them
            They haven’t been painted yet as I’m waiting for some brown paint in various colours and shades to arrive I tried making brown using orange and blue or red and green and the results were not good so I gave up and ordered some instead
            Regards
            ColinClick image for larger version
ID:	1178599Click image for larger version
ID:	1178600Click image for larger version
ID:	1178601Click image for larger version
ID:	1178602Click image for larger version
ID:	1178603Click image for larger version
            • Bigfoot57
              • Jun 2015
              • 1103
              #156
              HMS Hood 1/200 Hachette /Amati Wooden kit Build Part 132 More Steps
              Yep along with a wooden piece made up of around a dozen pieces and 8 more steps to build they are all sequenced so you have Steps A built Steps B built Steps C not yet used Steps D all 10 built Steps E F G & H not yet used but I think they will be soon
              The actual step building is one of the best I’ve seen you have a staybright metal cast set of steps to which you attach the handrails so much easier than those on the Hachette /Agora metal Bismarck where they were photo etched you had to bend the handrails into place then twist the individual steps through 45 degrees in so doing you buckle the handrail if not carefully done none of that on this build
              The wooden structure needs a good clean up before it’s painted just to point out its not going to be left in that state once the glue has throughly dried overnight
              Regards
ID:	1178610Click image for larger version
ID:	1178611Click image for larger version
ID:	1178612Click image for larger version
ID:	1178613Click image for larger version
ID:	1178614Click image for larger version
ID:	1178615Click image for larger version
ID:	1178616Click image for larger version
ID:	1178617Click image for larger version
ID:	1178618Click image for larger version
ID:	1178619Click image for larger version
              • Bigfoot57
                • Jun 2015
                • 1103
                #157
                HMS Hood 1/200 Hachette /Amati Wooden kit Build Part 133
                Greetings again so we now start building the components for the bridge I believe although I could be wrong anyway we’re off to the world of filler looking at the 1st piece of the assembly nice big gap and seam line right down the centre
                Next we add some of the previously built sub assemblies to the next set of decks which I call the bridge I’ve also repainted the decking in it’s final colour scheme as well
                Finally I’ve dry fitted the whole assembly onto the main deck to see what it looks like this concludes part 133 only 7 more to go
                Regards
                Colin
ID:	1178715Click image for larger version
ID:	1178716Click image for larger version
ID:	1178717Click image for larger version
ID:	1178718Click image for larger version
ID:	1178719Click image for larger version
ID:	1178720Click image for larger version
ID:	1178721Click image for larger version
ID:	1178722Click image for larger version
                • Bigfoot57
                  • Jun 2015
                  • 1103
                  #158
                  HMS Hood 1/200 Hachette /Amati Wooden kit Build Part 134
                  Apologies for lack of posting but as you can see the parts per issue has increased in some stages to 40 separate sections which take an age to do
                  So on to adding detail to the main bridge this second level is made entirely out of brass sheet pe and as such is stuck with ca I’m not a fan of this type of glue and frankly the amount of brass pe in this model is around 2000 pieces all reliant on ca glue which I believe they could have moulded in plastic allowing the use of Tamiya cement which we know is good and resistant to breakages due to the way it fuses the plastic surfaces together whereas ca glue is like a layer of cement in a course of bricks and seems to have problems after or about 5 years in the open maybe affected by ultraviolet in the atmosphere who knows
                  The last picture in this sequence shows the next level being prepared by gluing and clamping 2 deck pieces together and leaving overnight to set
                  Regards
                  Colin
ID:	1179726Click image for larger version
ID:	1179727Click image for larger version
ID:	1179728Click image for larger version
ID:	1179729Click image for larger version
ID:	1179730Click image for larger version
ID:	1179731Click image for larger version
ID:	1179732Click image for larger version
ID:	1179733Click image for larger version
ID:	1179734Click image for larger version
ID:	1179735Click image for larger version
                  • Bigfoot57
                    • Jun 2015
                    • 1103
                    #159
                    HMS Hood 1/200 Hachette /Amati Wooden kit Build Part 135
                    Here’s where we really start on the brasswork pe in a big way this again constructed totally from brass pe sheets and some of the parts were impossible to shape so I resorted to card those are the white parts you can see in the photos
                    Hopefully when painted you shouldn’t be able to tell the difference between them and the real pe
                    The fit of some of these parts was awful necessitating using ca glue as a filler and smoothing it out as I went it looks a mess at present but once painted should be presentable
                    I also had issues with various ladders not fitting these too had to be persuaded to fit with net result handrails became detached as can be see by the handrail still brass as I had to clean all the paint off it so the glue would take hence the lack of grey on that part
ID:	1179737Click image for larger version
ID:	1179738Click image for larger version
ID:	1179739Click image for larger version
ID:	1179740Click image for larger version
ID:	1179741Click image for larger version
ID:	1179742Click image for larger version
ID:	1179743Click image for larger version
ID:	1179744Click image for larger version
ID:	1179745Click image for larger version
ID:	1179746Click image for larger version
ID:	1179747Click image for larger version
ID:	1179748Click image for larger version
ID:	1179749Click image for larger version
                    • Bigfoot57
                      • Jun 2015
                      • 1103
                      #160
                      HMS Hood 1/200 Hachette /Amati Wooden kit Build Part 136
                      We now take lower bridge and join it to upper part of the bridge where the join is a type of wooden peg into a hole the hole on the underneath of the upper part of the bridge wasn’t big enough to the peg of the lower bridge to fit into requiring it to be enlarged by filing until the peg fitted in so doing another piece from the underneath the upper bridge detached itself and will need regluing
                      Next we measured and cut the start of the tripod mast assembly and that’s as far as I have got as I had to paint one of the decks on the upper lower bridge a sand colour to imitate wood probably and I’m waiting for that to dry before assembling all those rangefinders
                      Regards
ID:	1179751Click image for larger version
ID:	1179752Click image for larger version
ID:	1179753Click image for larger version
ID:	1179754Click image for larger version
ID:	1179755Click image for larger version
ID:	1179756Click image for larger version
ID:	1179757Click image for larger version
ID:	1179758Click image for larger version
ID:	1179759Click image for larger version
ID:	1179760Click image for larger version
                      • minitnkr
                        Charter Rabble member
                        • 7551
                        • Dayton, OH USA
                        #161
                        Unbelievable.
                          • 15737
                          Originally posted by minitnkr
                          Unbelievable.
                          You're not wrong there Paul.
                          • adt70hk
                            • Sep 2019
                            • 10426
                            #163
                            Mind-blowing Colin..... If I got that right was that 2000 pieces of PE alone? How many parts for the whole thing?
                            And if I've got it right, it's about 4' 4" in length?
                            Again great work.
                            PS apologies if you've covered the above questions previously.
                            • boatman
                              • Nov 2018
                              • 14498
                              • christopher
                              • NORFOLK UK
                              #164
                              HI Colin well ive been following your Hood build an its been very instresting an you are doin very good but pity it was not R/C to sail
                              ATB
                              chrisb
                              • Code no 10
                                • Jun 2022
                                • 130
                                #165
                                Great build! Even the instruction pages are :thumb2:
