HMS Hood 1/200 Amati Models
  • Bigfoot57
    • Jun 2015
    • 1103
    #181
    HMS Hood 1/200 Hachette /Amati Wooden kit Build Part 138b more photos 1st off the finished Funnels flowed by the rest
ID:	1180681Click image for larger version
ID:	1180682Click image for larger version
ID:	1180683Click image for larger version
ID:	1180684Click image for larger version
ID:	1180685Click image for larger version
ID:	1180686Click image for larger version
ID:	1180687Click image for larger version
ID:	1180688Click image for larger version
ID:	1180689Click image for larger version
ID:	1180690Click image for larger version
ID:	1180692Click image for larger version
ID:	1180693Click image for larger version
ID:	1180694Click image for larger version
ID:	1180695Click image for larger version
ID:	1180696Click image for larger version
    • Mickc1440
      • 4786
      #182
      That's more great work on this monster Colin
        • 15817
        Amazing work Colin.
        • Bigfoot57
          • Jun 2015
          • 1103
          #184
          HMS Hood 1/200 Hachette /Amati Wooden kit Build Part 139
          Here’s what’s coming in 139 including rigging the funnels
          Regards
          Colin
ID:	1180757Click image for larger version
ID:	1180758Click image for larger version
ID:	1180759Click image for larger version
ID:	1180760Click image for larger version
ID:	1180761Click image for larger version
ID:	1180762Click image for larger version
ID:	1180763Click image for larger version
ID:	1180764Click image for larger version
ID:	1180765Click image for larger version
ID:	1180766Click image for larger version
          • Bigfoot57
            • Jun 2015
            • 1103
            #185
            Whilst I’m waiting for paint to dry I went through the magazines to do a pe sprue count the normal Pontus tops out around 15 to 20 for ships in this scale in some cases this models pe sprue count according to the instructions was 78 so you can see why there is around 2000 to 2100 pieces of Brasswork
            • Bigfoot57
              • Jun 2015
              • 1103
              #186
              HMS Hood 1/200 Hachette /Amati Wooden kit Build Part 139 Build photos
              So I’m roughly halfway through stage 139 having sorted and glued all the railings along with the associated DeGausing strips
              Then retrieved some previously built sections and further enhanced them with more detail this also gave me a chance to try out my pe bender pliars I have 2 types one with a straight edge and one with a curved edge I used the straight edge ones to bend yet more hose reel supports
              Next came fitting the 1st funnel into place and carefully marking out the holes to be drilled for the eyebolts using a pair of dividers to mark their positions on both sides of the decking piece the funnel is mounted on finally drilling the holes using an archimedes mini pin vice brilliant piece of kit so long as you let the drill work at its own pace and not press down to hard as I did 1st time result buckled drill bit
              Finally for this section I have shown a fully rigged funnel and the spaghetti junction you start with prior to attaching the funnel
              Note the central lower eyebolt does not have thread attached as the top central eyebolt will attach to the deck eyebolt then loop through said eyebolt to finish on the lower central eyebolt on the funnel hence the lack of a rigging thread for that area
              Regards
              Colin
ID:	1181763Click image for larger version
ID:	1181764Click image for larger version
ID:	1181765Click image for larger version
ID:	1181766Click image for larger version
ID:	1181767Click image for larger version
ID:	1181768Click image for larger version
ID:	1181769Click image for larger version
ID:	1181770Click image for larger version
ID:	1181771Click image for larger version
ID:	1181772Click image for larger version
ID:	1181773Click image for larger version
ID:	1181774Click image for larger version
ID:	1181775Click image for larger version
ID:	1181776Click image for larger version
ID:	1181777Click image for larger version
ID:	1181778Click image for larger version
              • Bigfoot57
                • Jun 2015
                • 1103
                #187
                HMS Hood 1/200 Hachette /Amati Wooden kit Build Part 139 Finally Finished just 140 to go
                Hello again not heard from me in nearly a month well that’s how long it’s taken to complete stage 139 although a week was lost due to extreme temperatures the glue and paint were drying before it could be applied to the model
                Anyway we started by gluing on the remaining degaussing strips to the base of the railings then fitted all the railings with the exception of 2 small platforms which will probably get snapped off if fitted at this stage they will be one of the last items along with the jackstaff on the bow for the same reason
                After fitting the railings it was back to adding details to decking including various platforms and loads of eyebolts presumably for the rigging attachment points
                I then made up some ladders etc to fit to various structures around the ship so here a few detail shots of the work in progress and in the second part is the completion of part 139 so you can see all the additional items added such as cranes davits and another batch of searchlights in the mid stern structure etc
                Regards
                ColinClick image for larger version
ID:	1183023Click image for larger version
ID:	1183024Click image for larger version
ID:	1183025Click image for larger version
ID:	1183026Click image for larger version
ID:	1183027Click image for larger version
ID:	1183028Click image for larger version
ID:	1183029Click image for larger version
                • Bigfoot57
                  • Jun 2015
                  • 1103
                  #188
                  HMS Hood 1/200 Hachette /Amati Wooden kit Build Part 139 Glory shot photos
                  Here’s part 2 as indicated this set reveals a whole new lot of additions and assemblies
                  Regards
                  Colin
ID:	1183032Click image for larger version
ID:	1183033Click image for larger version
ID:	1183034Click image for larger version
ID:	1183035Click image for larger version
ID:	1183036Click image for larger version
ID:	1183037Click image for larger version
ID:	1183038Click image for larger version
ID:	1183039Click image for larger version
ID:	1183040Click image for larger version
ID:	1183041Click image for larger version
ID:	1183042Click image for larger version
ID:	1183043Click image for larger version
ID:	1183044Click image for larger version
ID:	1183045Click image for larger version
                  • scottie3158
                    • 14253
                    • Holbeach
                    #189
                    Colin,
                    Some really nice work going on.
                    • Mickc1440
                      • 4786
                      #190
                      Wow it’s looking superb Colin
                      • Bigfoot57
                        • Jun 2015
                        • 1103
                        #191
                        HMS Hood 1/200 Hachette /Amati Wooden kit Build Part 140 stages 1-10
                        So we’ve reached the last issue and this has 41 sections to it my next stage the rear tripod mast is a kit on its own comprising of around 100+ pieces of plastic brass & wood
                        Construction wise it’s a fairly simple task it’s just takes a long time as you do a stage then have to wait until the glue has set and the the section you’re doing is straight and level / upright or at a 45 degree angle
                        I used my flat nose pliers to bend the tabs on the ladders these are an absolute must if your doing a lot of pe work much easier than the speed bender I normally use
                        And there’s a few pieces of brass rodding to be added here I’m using my micrometer to mark out the lengths prior to cutting and gluing these pieces onto the assembly you can see them as the 2 45 degree angled pieces and the 2 bits sticking out from the platform
                        I see the right hand ladder is slightly bucked that will need levelling out before painting commences
                        The last pictures show the mast standing upright on its own so hopefully it will transfer to deck in a similar fashion the last pic is a detail shot of the entire assembly prior to painting which comes after it has had 24 hours to set the glue
                        Regards
ID:	1183484Click image for larger version
ID:	1183485Click image for larger version
ID:	1183486Click image for larger version
ID:	1183487Click image for larger version
ID:	1183488Click image for larger version
ID:	1183489Click image for larger version
ID:	1183490Click image for larger version
ID:	1183491Click image for larger version
ID:	1183492Click image for larger version
ID:	1183493Click image for larger version
ID:	1183494Click image for larger version
ID:	1183495Click image for larger version
ID:	1183496Click image for larger version
ID:	1183497Click image for larger version
ID:	1183498Click image for larger version
ID:	1183499Click image for larger version
                        • Bigfoot57
                          • Jun 2015
                          • 1103
                          #192
                          HMS Hood 1/200 Hachette /Amati Wooden kit Build Rear mast update
                          Mast has now been painted Click image for larger version
ID:	1183550Click image for larger version
ID:	1183551Click image for larger version
                          • boatman
                            • Nov 2018
                            • 14498
                            • christopher
                            • NORFOLK UK
                            #193
                            HI that mast is a work of art very well done m8 as is the whole ship i love it an look forward to your posts but it would be nice to see some overall pics of what you have got so far as thats what i do with my tiger as to see it mostly togeather helps the mojo no end
                            chrisb
                            • adt70hk
                              • Sep 2019
                              • 10439
                              #194
                              Colin,
                              Apologies got behind on this. Pleased to see you're on the final section..... Even if there are 42 steps. That really is a work of art.
                              Very well done indeed.
                              ATB
                              • Bigfoot57
                                • Jun 2015
                                • 1103
                                #195
                                chrisb
                                Chris look at post HMS Hood 1/200 Hachette /Amati Wooden kit Build Part 139 Glory shot photos these show the whole model from bow to stern
                                Colin
