HMS Hood 1/200 Amati Models
    • 15815
    So nice to see this back on the go. Glad you're feeling up to it again. Looking excellent.
    • Bigfoot57
      • Jun 2015
      • 1103
      #212
      HMS Hood 1/200 Hachette /Amati Wooden kit Build Main Guns Now Fitted
      So a relatively easy stage this just had to file out the holes in the barbets and the bottom of the turrets to fit in the pin that allows the turrets to be rotated the fit is so tight no glue is needed
      Next I got a1/32 roundel from a Revell 1/32 Spitfire for some reason must have been Far Eastern pacific as it had a white centre I believe this was to avoid confusion with the Japanese aircraft carrying the red circular roundel anyway I mounted this onto the turret and after several applications of Micro Sol the decal settled down onto the surface I then painted the inside white area red to represent the aerial indentication roundel whether the Hood had it at the time of the battle of the Denmark Straits I don’t know but I’ve seen several depictions of it so I decided to include it as it gives a splash of contrast to the two tone grey colour scheme
      After this it was a simple case of push fitting the turrets into place the higher of the two on the front in the instructions it’s labelled as turret 3 has to have a multiple Pom Pom gun set added to it but appart from that the turrets are now complete next we move onto the main mast at the stern end of the ship
      Regards
      Colin
ID:	1193587Click image for larger version
ID:	1193588Click image for larger version
ID:	1193589Click image for larger version
ID:	1193590Click image for larger version
ID:	1193591Click image for larger version
ID:	1193592Click image for larger version
      • Mickc1440
        • 4786
        #213
        Glad to see you're able to resume this one Colin, it really is looking very good
          • 18955
          Great to see this back on the build Colin. Detail is fantastic and the whole build is quite superb. Hope your health issues stay under control.
          • Bigfoot57
            • Jun 2015
            • 1103
            #215
            Correction not a Pom Pom but one of those primitive rocket launchers they were supposed to be fired at any incomming aircraft and as they climbed they spew out a long trailing wire which I suppose was to snag anything vital from the incoming airborne threat presumably the propellers
            • Airborne01
              • Mar 2021
              • 4038
              • Steve
              • Essex
              #216
              Are you thinking that it's a TOW (Tracked Optical Wire) system mate? If so the wire is not designed to snag enemy aircraft, it's a command system. I suspect that's a little too early for TOW - I stand to be corrected however!
              • Bigfoot57
                • Jun 2015
                • 1103
                #217
                Steve you could be correct I seem to remember words similar to that in the text I read although according to the picture below both of us are wrong see Wikipedia attachment below
                Colin
                • Steve-the-Duck
                  • Jul 2020
                  • 1731
                  • Chris
                  • Medway Towns
                  #218
                  The box-thing that sits atop B turret is an 'Unrotated Projectile Launcher,' UP. The rocket they launched carried a small charge attached to a parachute, trailing a long length of wire. The attacking 'plane was, indeed, supposed to snag the wire and pull the charge onto itself.
                  They were about as rubbish as they sounded, but apparently Winston thought they were a wizard wheeze as, no prizes for guessing, they were another of Professer Lindemann's ideas. There's no record of one ever having any effect at all, other than injuring three rratings when they spontaneously fired while in Gibraltar in July 1940. They were supposed to be removed before she sailed to meet Bismarck. Worse yet, one of Prinz Eugen's hits detonated in the ready-use magazine for the 4" and UP ammo, killing many of the AA crews where they were sheltering, as related by Bob Tillman, one of the survivors.
                  • Airborne01
                    • Mar 2021
                    • 4038
                    • Steve
                    • Essex
                    #219
                    Colin
                    That's interesting, never heard of those!
                    • Bigfoot57
                      • Jun 2015
                      • 1103
                      #220
                      HMS Hood 1/200 Hachette /Amati Wooden kit Build Fully rigged Port side Starboard to follow just the insulators and lifeboats to fit to finish model
ID:	1194508Click image for larger version
ID:	1194509Click image for larger version
ID:	1194510Click image for larger version
ID:	1194511Click image for larger version
ID:	1194512Click image for larger version
ID:	1194513Click image for larger version
ID:	1194514Click image for larger version
ID:	1194515Click image for larger version
ID:	1194516Click image for larger version
ID:	1194517Click image for larger version
ID:	1194518Click image for larger version
                      Regards
                      Colin
                        Great progress Colin, sorry to read about the health problems.
                        • minitnkr
                          • 7574
                          • Dayton, OH USA
                          #222
                          Some outstanding work on display.
                          • Bigfoot57
                            • Jun 2015
                            • 1103
                            #223
                            HMS Hood 1/200 Hachette /Amati Wooden kit Build Fully Rigged Starboard Side
                            As I said in previous post Starboard to follow so here it is
                            Regards
                            Colin
                            • boatman
                              • Nov 2018
                              • 14498
                              • christopher
                              • NORFOLK UK
                              #224
                              HI Colin what a fab build an the riggin also how long did she take to build in the end ? an dont the letters HOOD get painted in a different colour like on modern R/N ships like my tiger name is in red outstandin letters ?
                              chrisb
                              • Mickc1440
                                • 4786
                                #225
                                A really stunning build
