HMS Hood 1/200 Amati Models
  • Bigfoot57
    • Jun 2015
    • 1103
    #46
    HMS Hood Amati 1/200 Parts 33-34 Hull Sanding
    Hello again well I had a good weekend the hull has been sanded smooth after applying approx 600 planks this took 12 issues and about 3 months of work at around 50 planks per issue can now move onto superstructure at last
    See photos below hopefully showing how smooth the hull is now
    I used the finger tip to detect blemishes raised planks etc and then sanded that area till it was smooth and level with next and so on until I had gone down one side and up the other so to speak the only area left is the bow where apparently the end pieces are not fitted yet which is strange as the stern ones were the 1st items applied before the planking began oh well suppose they know best
ID:	1167167Click image for larger version
ID:	1167168Click image for larger version
ID:	1167169Click image for larger version
ID:	1167170Click image for larger version
ID:	1167171Click image for larger version
ID:	1167172Click image for larger version
ID:	1167173Click image for larger version
ID:	1167174Click image for larger version
ID:	1167175Click image for larger version
ID:	1167176Click image for larger version
      • 15813
      Hi Colin
      Looking good. Planking and sanding must be time consuming and rather tedious but has to be done.
      • adt70hk
        • Sep 2019
        • 10439
        #48
        Colin
        Great work, that sanding effort seems to have paid off very nicely.
        Keep up the great work.
        • Bigfoot57
          • Jun 2015
          • 1103
          #49
          HMS Hood 1/200 Hachette /Amati Wooden kit Build Part 35
          Here we are again with next instalment only a short one this time and no planking in sight
          So this is the 1st of a huge amount of brass work to be applied to this model from now on
          Regards
          Colin
ID:	1167356Click image for larger version
ID:	1167357Click image for larger version
ID:	1167358Click image for larger version
ID:	1167359Click image for larger version
ID:	1167360Click image for larger version
ID:	1167361Click image for larger version
ID:	1167362Click image for larger version
ID:	1167363Click image for larger version
          • Bigfoot57
            • Jun 2015
            • 1103
            #50
            HMS Hood 1/200 Hachette /Amati Wooden kit Build Parts 36-40
            I won’t bore you with numerous pictures of what’s has preceded this entry suffice to say more of the same namely gluing brass pe around the wooden structures and adding an occasional door where needed and don’t forget all structure work will be painted in a battleship grey so all the brass work will merge into the rest of the ship unless that actual piece being modelled is actually brass
            So instead here are a couple of pictures 1 port 1 starboard showing the brass pe glued into place so far hopefully issue 41 will be more interesting
ID:	1167544Click image for larger version
            Regards
            Colin
            • adt70hk
              • Sep 2019
              • 10439
              #51
              This is clearly a real labour of love Colin.
                • 15813
                Hi Colin
                The brass is a lot of work but certainly looks good when done.
                • Bigfoot57
                  • Jun 2015
                  • 1103
                  #53
                  HMS Hood 1/200 Hachette /Amati Wooden kit Build Part 41
                  I was wrong part 41 consisted of 4 squares of wood which you glue together into 2,s which are apparently are a couple of spacers here’s hoping for part 42 though down hold your breath
                  Regards
                  Colin
                  • Bigfoot57
                    • Jun 2015
                    • 1103
                    #54
                    HMS Hood 1/200 Hachette /Amati Wooden kit Build Parts 42-44
                    Hello everybody to my continuing build of the Amati HMS Hood this time we are moving into brasswork pe big time as all the issues apart from 42 up to 47 contain nothing but pe so 1st off part 42 which consists of several wood side pieces that the pe will be glued to from issue 43 onwards
ID:	1167811Click image for larger version
ID:	1167812Click image for larger version
ID:	1167813Click image for larger version
                    Now onto the pe from 43 to 46 I have included a couple of pictures of 1/64 scale model of the Hood built before the ship was laid down this model now or at the time of this publication resided in the Transport museum in Glasgow
                    Most of the pe is simply a case of sticking it on top of the wooden frame work then add additional pe on top of that a case in point the hose reel brackets and tiny eyebolts and cleats each at around 1mm in diameter I also had to glue 26 buttressing ribs to a long piece of pe walling presumably there’s a second one at a later stage for the other side to look forward to after 46 we don’t touch the hull or decking for about 10 issues as from 47 to 57 are only dealing with the 4 main gun turrets and additional add on items all pe again oh joy
                    Regards
                    Colin
ID:	1167815Click image for larger version
ID:	1167818Click image for larger version
ID:	1167816Click image for larger version
ID:	1167817Click image for larger version
ID:	1167819Click image for larger version
ID:	1167820Click image for larger version
ID:	1167821Click image for larger version
                    Images for Parts 44 to 46 will follow shortly along with pictures of my build
                    • scottie3158
                      • 14247
                      • Holbeach
                      #55
                      Colin,
                      Coming on very nicely, really starting to take shape.
                      • Bigfoot57
                        • Jun 2015
                        • 1103
                        #56
                        HMS Hood 1/200 Hachette /Amati Wooden kit Build Parts 44 to 46
ID:	1167830Click image for larger version
ID:	1167831Click image for larger version
ID:	1167832Click image for larger version
ID:	1167833Click image for larger version
ID:	1167834Click image for larger version
ID:	1167835Click image for larger version
ID:	1167836Click image for larger version
ID:	1167837Click image for larger version
ID:	1167838Click image for larger version
ID:	1167839Click image for larger version
ID:	1167840Click image for larger version
                        • Bigfoot57
                          • Jun 2015
                          • 1103
                          #57
                          And finally my build progress obviously some filler will be needed in places which will be my next job
ID:	1167842Click image for larger version
ID:	1167843Click image for larger version
ID:	1167844Click image for larger version
ID:	1167845Click image for larger version
ID:	1167846Click image for larger version
ID:	1167847Click image for larger version
ID:	1167848Click image for larger version
                          • peterairfix
                            • Jul 2012
                            • 11087
                            #58
                            That's a lot of pe I should know I had that with my bismarck.
                            • Bigfoot57
                              • Jun 2015
                              • 1103
                              #59
                              HMS Hood 1/200 Hachette /Amati Wooden kit Build Parts 47 1st main gun turret
                              Three postings in one evening your being spoilt anyway I thought I’ll crack on and have a go at building the 1st turret which had should we say issues not with the parts me I got the 1st section done namely gluing the turret together and the main guns which had a seam line running down both sides so this has been removed using a blade in a scraping motion all well and good then came the dreaded pe got the front right side done easily no problem the rear was a different kettle of fish suffice to say it took me 4 attempts to get it looking right and that was after I did some surgery on one part as it wouldn’t fit whatever way I tried so in the end I chopped off the offending piece and went with that
                              Next off doing the rangefinder I glued the pe the wrong way round and wondered why I couldn’t see the rivet detail along the top edge whoops out with the scalpel prise off the piece and re-attach it the correct way round after that I thought that’s enough for tonight and it will give the glue a fighting chance of setting firm to boot
                              Regards
                              Colin
                              PS
                              Why does the Hoods turret resemble an old 15amp round pin plug which means I’m showing my age and it’s time to stop
ID:	1167857Click image for larger version
ID:	1167858Click image for larger version
ID:	1167859Click image for larger version
ID:	1167860Click image for larger version
ID:	1167861Click image for larger version
ID:	1167862Click image for larger version
ID:	1167863Click image for larger version
ID:	1167864Click image for larger version
ID:	1167865Click image for larger version
                              • Bigfoot57
                                • Jun 2015
                                • 1103
                                #60
                                HMS Hood 1/200 Hachette /Amati Wooden kit Build Parts 48 The Rangefinder
                                Sorry forgot to include this
ID:	1167867Click image for larger version
ID:	1167868Click image for larger version
ID:	1167869Click image for larger version
