HMS Hood 1/200 Amati Models
  • Bigfoot57
    • Jun 2015
    • 1103
    #61
    HMS Hood 1/200 Hachette /Amati Wooden kit Build Parts 49 & 50
    Latest small update almost a duplicate of 47 & 48 with exception of a tiny pe piece at the front top of the turret & no pe work on the side and a different configuration for the ladder the rangefinder is exactly the same as part 48 once again scrapped the seam lines off the gun barrels as per previous entry
    Regards
    Colin Click image for larger version
ID:	1168024Click image for larger version
ID:	1168025Click image for larger version
ID:	1168026Click image for larger version
ID:	1168027Click image for larger version
ID:	1168028Click image for larger version
ID:	1168029Click image for larger version
ID:	1168030Click image for larger version
ID:	1168031Click image for larger version
      Colin I can now see why these kits cost so much ! A tremendous amount of work and well worth it.
      Where on earth are you going to display it ?
      • Bigfoot57
        • Jun 2015
        • 1103
        #63
        I have a large table in the living room in front of the T V it can go on when finished the problem will be where’s the Metal Titanic going to go as I have if you count the wooden one from 2010 I think and highly detailed card model from Poland 3 of them then there’s HMS Victory The Cutty Sark Sovereign of the seas if I ever get parts 1 & 2 as I seem to have lost them another wooden Bismarck and again a highly detailed card model from Poland each if you count the bowsprits from the galleons are nearly 4ft long plus 2 smaller models HMS Bounty & the Endeavour + and these are the killers as I have nowhere to put them at present all in 1/32 scale Lancaster B17 B29 B52 & Vulcan BMk2 the B52 wingspan is around 5ft+ The 1/46 scale
        Millennium Falcon a Dragon Saturn V Skylab 1/72 3 1/8 scale cars Aston Martin DB5 Jaguar E Type & The Back To The Future Delorean a 1/18 Spitfire Mk1 and about 30 other kits in my stash ranging from 1/144 &1/72 scale Concorde & TU144’s 15 or so 1/32 aircraft about 10 1/48 aircraft & a 1/72 Space Shuttle which again is on the large size I think that just about covers it
        Regards
        Colin
        • boatman
          • Nov 2018
          • 14498
          • christopher
          • NORFOLK UK
          #64
          WOW Colin what a stash its nr a model shop an must have cost a fortune but id love to see the B29 -B52 - Vulcan- an the 1/72 concorde built but what you need is a home exstenshion lol an could you if possible put on a few pics of the B52 kit on another thread an B29 AS I DINT THINK THEY DID KITS THIS BIG WOW
          chris
            • 15814
            Hi Colin
            Nice work on the turret. I'm a little surprised that on a kit like this turned metal gun barrels weren't included. That's quite a lot of very large models you have
              Regards
              Colin
              Colin would you mind posting some photos of them, sure many would love to see them.Thanks.
              • Bigfoot57
                • Jun 2015
                • 1103
                #67
                HMS Hood 1/200 Hachette /Amati Wooden kit Build Parts 51-54
                Hello again continuing the turret build same as before but I’ve noticed each turret is slightly different with way of the pe applied to them as you can see from the pictures the 4th turret having tiny pieces of pe added to it see the part against my index finger I’ve not included any mag shots this time as they are all the same as previous ones with only slight variations for the different pe fittings which you can from the attached picture
                Regards
                Colin
ID:	1168106Click image for larger version
ID:	1168107Click image for larger version
                • adt70hk
                  • Sep 2019
                  • 10439
                  #68
                  Sorry Colin, got behind on this... So just had a catch up.
                  This really is some amazing work on display. Hadn't appreciated that the turrets would be plastic.
                  What will you use for primer?? Rattle can I assume given the size and mixture of materials?
                  Keep up the great work.
                  • Bigfoot57
                    • Jun 2015
                    • 1103
                    #69
                    HMS Hood 1/200 Hachette /Amati Wooden kit Build Parts 55-56
                    The main turret barbets construction here again there’s not much to do to start with just glue some discs together to make structures the main guns will sit on there’s a 1disc a 2 disc a 4 disc & finally a 5 disc after the glue has dried overnight they are painted a white primer before adding more pe to them then painting them a medium grey if the colour is accurate as I have done research into the hood colour scheme for the Denmark Straits action and it turns out parts of the ship has a grey with a blue tinge to them
                    Also Hood never had red anti fouling paint it was supposedly a greyish colour so why does every model of it show a red bottom ? Anyway I have to obtain light stone for the blast bags on the turrets and medium grey for the turrets guns and finally the white barbets see photos below with my parts of the build as well bit short this time but there’s lots more to do after the glue and paint have dried
                    Regards
                    ColinClick image for larger version
ID:	1168222Click image for larger version
ID:	1168223Click image for larger version
ID:	1168224Click image for larger version
ID:	1168225Click image for larger version
ID:	1168226Click image for larger version
ID:	1168227Click image for larger version
ID:	1168228Click image for larger version
ID:	1168229Click image for larger version
ID:	1168230Click image for larger version
ID:	1168231Click image for larger version
ID:	1168232Click image for larger version
                    • Bigfoot57
                      • Jun 2015
                      • 1103
                      #70
                      HMS Hood 1/200 Hachette /Amati Wooden kit Build Parts 55-56 Main Gun Turret's Painted
                      Good Evening
                      Here is the latest update regarding the main gun turrets they have now been primed in white as instructed the additional pe has been added the ring on the bottom of the single disc was a right pain as it wouldn’t stick to start it then decided to make its own ring which was different to the circumference of single wooden base so eventually I got it there but it took 4 attempts and lots of cursing
                      The other 2 additions were ladders added to the side of the 4 & 5 piece bases no dramas here
                      After the glue had dried overnight I then gave them the 1st of 3 coats of paint then moved onto assembling the guns into the blast bags then adding these to the now painted turrets I then wedged all 4 turrets up against my cutting mat so that the gun angle would be the same for all as these turrets will turn by won’t elevate it was then a case of touching up the paint work
                      The blast bags at present are way to prominent and need dulling down considerably with a grey wash
                      Finally I have placed the turrets in their approximate positions on the model to keep them out of harms way hopefully
                      Anyway part 57 is assembling a ack ack gun with loads of PE oh joy look forward to that one as that will be tonight’s work
                      Regards
                      Colin
ID:	1168368Click image for larger version
ID:	1168369Click image for larger version
ID:	1168370Click image for larger version
ID:	1168371Click image for larger version
ID:	1168372Click image for larger version
ID:	1168373Click image for larger version
                      • Bigfoot57
                        • Jun 2015
                        • 1103
                        #71
                        HMS Hood 1/200 Hachette /Amati Wooden kit Build Parts 57-58 1st Anti Aircraft Gun
                        Sorry for long delay in posting but this part has taken me 3 days to complete its not perfect but it’s the best I can do so it’s off glue the 2 guns together no problem there next comes nothing but pe to be mounted on the gun or the gun platform some of the pieces are 1mm or less access I have included a photo of a long grain of rice next to one of the small parts so as is normal 1st the magazine showing you what to do including a bit about the HMS Hood association and NASA Space Shuttle Program after this will follow my build photos
                        Regards
ID:	1168592Click image for larger version
ID:	1168593Click image for larger version
ID:	1168594Click image for larger version
ID:	1168595Click image for larger version
ID:	1168596Click image for larger version
ID:	1168597Click image for larger version
                        • Bigfoot57
                          • Jun 2015
                          • 1103
                          #72
                          HMS Hood 1/200 Hachette /Amati Wooden kit Build Parts 57-58 1st Anti Aircraft Gun Build Photos
ID:	1168608Click image for larger version
ID:	1168609Click image for larger version
ID:	1168610Click image for larger version
ID:	1168611Click image for larger version
ID:	1168612Click image for larger version
ID:	1168613Click image for larger version
ID:	1168614Click image for larger version
ID:	1168615Click image for larger version
ID:	1168616Click image for larger version
ID:	1168617Click image for larger version
ID:	1168618Click image for larger version
ID:	1168619Click image for larger version
ID:	1168620Click image for larger version
ID:	1168621Click image for larger version
                          • boatman
                            • Nov 2018
                            • 14498
                            • christopher
                            • NORFOLK UK
                            #73
                            hi Comin none of the pics show
                            chris
                            • boatman
                              • Nov 2018
                              • 14498
                              • christopher
                              • NORFOLK UK
                              #74
                              chris
                              • Bigfoot57
                                • Jun 2015
                                • 1103
                                #75
                                Chris I’ve reattached them can you see them now
