HMS Hood 1/200 Amati Models
  • boatman
    • Nov 2018
    • 14498
    • christopher
    • NORFOLK UK
    #76
    Originally posted by Bigfoot57
    Chris I’ve reattached them can you see them now
    YEP THANKS Colin
    chris
      • 15735
      Hi Colin
      Fiddly little bugger ain't it Well done Sir.
      • Bigfoot57
        • Jun 2015
        • 1103
        #78
        HMS Hood 1/200 Hachette /Amati Wooden kit Build Parts 59-60 4thAnti Aircraft Gun Build Photos
        Hello again well we’re up to the end of part 60 that’s made 4 Anti Aircraft Guns not sure how many Pom Pom sets it had but from issue 61 were building the the 4.5 secondary armament so anyway I won’t bore you the same sort of pictures as before here’s the 4 completed along with some sort of turret mounting
        They all look a bit rough the moment that’s because they are this is my 1st time using photo etch extensively as here so I’m still learning as I go so when I get round to building Bismarck I will be better equipped skill wise to deal with the pe that no doubt more extensive than the hoods if my look at the kit is anything to go by
        Regards
        Colin
ID:	1169127Click image for larger version
ID:	1169128Click image for larger version
        • Steve-the-Duck
          • Jul 2020
          • 1731
          • Chris
          • Medway Towns
          #79
          Well, only just found this. Nice to see yours is about as far along as mine was, until my build stalled a while back!
          And so, she sits on a shelf in my conservatory, right outside the kitchen window - as a constant source of shame
          One thing I will say, is check your references for the stern, because I'm pretty sure the model is wrong in having the 'step' go all the way back
          • Bigfoot57
            • Jun 2015
            • 1103
            #80
            Thanks for that I will I know Hood had several refits during the 20 or so years prior to 1941 so they may have altered it somewhat and depending on what diagrams Amati used to produce the model might explain that step you are referring to
            Didn’t they have trouble with anything other than a moderate swell with water washing over the rear decks as they were so low in the water which also was used as an excuse not to increase the deck armour from I think it was 3” to 5” which had it been the case the battle of the Denmark Straits could have had a different outcome
            Regards
            Colin
            • Bigfoot57
              • Jun 2015
              • 1103
              #81
              Colin would you mind posting some photos of them, sure many would love to see them.Thanks.
              I tried posting some photos but they ended up in the middle of my Hood build so how do you want to play this a new thread in the general chit chat as I see the acquisitions thread appears to be locked for any further additions at least that’s how it seemed to me last time tried
              Colin
              • JR
                • May 2015
                • 18273
                #82
                Strange that the thread appeared locked ? Suppose you could post them under completed builds in a new thread Colin , as I think many of us would like too see them .
                • Bigfoot57
                  • Jun 2015
                  • 1103
                  #83
                  HMS Hood 1/200 Hachette /Amati Wooden kit Build Parts 61-64
                  All this consists off is 7x 4.5” secondary guns must be 1 missing or 1 too many as 7 seems weird anyway they are all built the same way so issue 61 will illustrate that along with my 1st 2 completed after that it just repeat 5 more times so it’s pointless just posting further mag shots until we reach something different around part 65 where I believe we actually glue the bow piece onto the hull so here come the pictures
                  Regards
                  Colin
ID:	1169298Click image for larger version
ID:	1169299Click image for larger version
ID:	1169300Click image for larger version
ID:	1169301Click image for larger version
ID:	1169302Click image for larger version
ID:	1169303Click image for larger version
ID:	1169304Click image for larger version
                  • adt70hk
                    • Sep 2019
                    • 10422
                    #84
                    Colin
                    Just had a catch-up. That's coming on very nicely indeed!!
                    Very well done.
                    • Bigfoot57
                      • Jun 2015
                      • 1103
                      #85
                      HMS Hood 1/200 Hachette /Amati Wooden kit Build Parts 61-62 Correction
                      Sorry I thought this would conclude at Part 63 but the secondary armament finished at 62
                      Part 63 is for the Lewis guns construction so here’s the 7x 4” Guns still seems odd to me
                      You can also see my version of Hachette’s 1/200 deck for the titanic which if you follow their instructions is completely the wrong colours and detail how they could have got this so completely wrong is beyond me don’t they do research
                      Regards
                      Colin
ID:	1169508Click image for larger version
                      • Bigfoot57
                        • Jun 2015
                        • 1103
                        #86
                        Hachette’s version of the deck
                        • stillp
                          • 8097
                          • Pete
                          • Rugby
                          #87
                          https://en.wikipedia.org/wiki/HMS_Hood states she had 7 of the 4" guns when she was sunk. It does seem an odd number. Looking forward to seeing them fitted.
                          • Bigfoot57
                            • Jun 2015
                            • 1103
                            #88
                            HMS Hood 1/200 Hachette /Amati Wooden kit Build Part 63 The Lewis Guns
                            So here we are again this time with the Lewis Machine Guns
                            Really tiny and fiddly to boot as well this made me resort to my helping hands for the 1st time in this build but in the end I used my own as I had more control when placing the pin head sized magazines for the guns
                            After this came ubiquitous pieces of pe not to bad this time basically a single piece which is bent to form the shoulder pads / rest of the gun and a small wheel is added to the end with a control rod extending from the other wheel the other end
                            See pictures below which should illustrate this
                            Regards
                            Colin
                            PS
                            what a twat I forgot to add the gunsights to the Lewis Guns
ID:	1169820Click image for larger version
ID:	1169821Click image for larger version
ID:	1169822Click image for larger version
ID:	1169823Click image for larger version
ID:	1169814Click image for larger version
ID:	1169815Click image for larger version
ID:	1169816Click image for larger version
ID:	1169817Click image for larger version
ID:	1169818Click image for larger version
ID:	1169819Click image for larger version
ID:	1169824Click image for larger version
                            • Bigfoot57
                              • Jun 2015
                              • 1103
                              #89
                              HMS Hood 1/200 Hachette /Amati Wooden kit Build Part 64 Rocket Launchers
                              Well this is a new one on me according to the Partworks our next stage is to construct 5 rocket launchers so her goes
                              These are made up of 2 side pieces joined together to form the rocket housings then a small bottom end cap is added before this section is glued onto the main base along with 3 bits of pe some sort of control panel a door and the top of the rocket tube compared to the previous this was a doddle to do the wooden decking you can see is not used at this stage
                              Regards
                              Colin
ID:	1169838Click image for larger version
ID:	1169839Click image for larger version
ID:	1169840Click image for larger version
ID:	1169841Click image for larger version
ID:	1169842Click image for larger version
ID:	1169843Click image for larger version
ID:	1169844Click image for larger version
ID:	1169845Click image for larger version
ID:	1169846Click image for larger version
ID:	1169847Click image for larger version
ID:	1169848Click image for larger version
                              • Bigfoot57
                                • Jun 2015
                                • 1103
                                #90
                                HMS Hood 1/200 Hachette /Amati Wooden kit Build Part 65-66 Fitting the Bow and pipework
                                Good afternoon here’s my next update been delayed waiting for epoxy glue to arrive with which to attach the bow piece so here we go
                                Glued the bow piece into place waited for a day before adding filler to any resulting gaps then another day to let the filler set properly then cleaned it up and proceeded to stage 66 which is the tiny pipes attached to various bulkheads next we will be doing our 1st primer on these bulkheads no doubt that will throw up numerous other filling jobs afterwards anyway here’s stages 65 to 66
ID:	1170471Click image for larger version
ID:	1170472Click image for larger version
ID:	1170473Click image for larger version
ID:	1170474Click image for larger version
ID:	1170475Click image for larger version
ID:	1170476Click image for larger version
ID:	1170477Click image for larger version
ID:	1170478Click image for larger version
