HMS Hood 1/200 Amati Models
  • Bigfoot57
    • Jun 2015
    • 1103
    #91
    HMS Hood 1/200 Hachette /Amati Wooden kit Build Part 67 1st primer
    Well I was right after the 1st primer coat I had loads of filling to do there the yellowish areas you can see in the painted surfaces also had some major filling where the rear bulkhead with the word HOOD inscribe on it meets with the hull all in all though not as bad as I expected during the priming I managed to ping on of the the tiny pipes off the bulkhead luckily it landed on the deck and was easily visible
    I’m not to worried about the paint on the main decking as we have wooden decking to glue down on top of it and as a by product it should remove all the little gaps at the bottom of the bulkheads once fitted anyway I’m now waiting for the filler to set then sand it down and then add another layer of paint afterwards
    Regards
    Colin
ID:	1170495Click image for larger version
ID:	1170496Click image for larger version
ID:	1170497Click image for larger version
ID:	1170498Click image for larger version
ID:	1170499Click image for larger version
ID:	1170500Click image for larger version
    • boatman
      • Nov 2018
      • 14498
      • christopher
      • NORFOLK UK
      #92
      HI Colin its comin on keep up this good work comin as ive never built a hood an dont really know much about her so all the building you re doin is a learning result for me
      chris b
      • Bigfoot57
        • Jun 2015
        • 1103
        #93
        HMS Hood 1/200 Hachette /Amati Wooden kit Build Part 67 1st set of Decking
        Hello again with superstructure resanded and primed then top coated we are now ready for the 1st sets of decking
        These were very thin laminate is it coconut bark or similar that they use anyway the bottom line is you have to cut it out as there’s no laser cutting these pieces so with trepidation I made my 1st cut using a model knife brand new blade and steel straight edge I soon gave this up as it was impossible to do curves and besides you have to custom fit the decking to your model necessitating several fittings and cuttings to get an exact fit they have allowed for this by giving you a 3 mm waist border around each piece which you trim to fit your arrangement
        With this in mind I resorted to some very fine scissors the type that look like tweezers but have blades instead of pointed tips this allowed me to cut the curves where required
        After that it was a case of gluing each section into place there not perfect but hopefully the decking above will conceal most of the errors etc anyway here’s what we have at present you’ll also notice I managed to ping off a inner door during the deck fitting so that will be re glued after the decks have dried and set firm
ID:	1170789Click image for larger version
ID:	1170790Click image for larger version
ID:	1170791Click image for larger version
ID:	1170792Click image for larger version
ID:	1170793Click image for larger version
        • Bigfoot57
          • Jun 2015
          • 1103
          #94
          HMS Hood 1/200 Hachette /Amati Wooden kit Build Part 67 1st set of Decking Pictures
          Sorry wasn’t enough room to include these on 1st part of this section
          Regards
          Colin
ID:	1170796Click image for larger version
ID:	1170797Click image for larger version
ID:	1170798Click image for larger version
ID:	1170799Click image for larger version
ID:	1170800Click image for larger version
          • boatman
            • Nov 2018
            • 14498
            • christopher
            • NORFOLK UK
            #95
            HI Colin the model is comin on great can we see an over all veiw of her
            an just wondered why you havnt finished off the hull an painted it ? or is this how the instruchtions tell you to build this bueaty
            chris b
            • Bigfoot57
              • Jun 2015
              • 1103
              #96
              Chris as requested here’s some overall pictures of where I’m at as regards painting the hull nothing in the instructions so far with regard to this section
ID:	1170809Click image for larger version
ID:	1170810Click image for larger version
ID:	1170811Click image for larger version
ID:	1170812Click image for larger version
              • boatman
                • Nov 2018
                • 14498
                • christopher
                • NORFOLK UK
                #97
                CHEERS Colin its looking brilliant pity she isnt R/C AN COULD SAIL as when i build my hulls have to get them treated with sandin sealer an painted so the hull dont warp but as yours goin in a glass case i dont suppoce it matters an yes in my opinion looking at your bismark hood was clearly outdated an all ready an old ship an the bismark was brand spankin new no wonder she dint stand a chance against bismark ps im really enjoyin your build keep at it :thumb2: :thumb2: :thumb2: :thumb2:
                chris b pps an do you make your own glass cases as they look big an from what ive seen they are fairly exspensive in this size ?
                  • 15815
                  Hi Colin
                  Really taking shape now. Those last few photos show just how big this model is. Great work on all the fiddly detail parts.
                  • Bigfoot57
                    • Jun 2015
                    • 1103
                    #99
                    Reply the case the Bismarck is in came from Hachette cost £169.99 + £40.00 for the coffee table it’s stood on checking on various suppliers separate Perspex to do a similar thing come in at around £120.00 and that doesn’t include the base or another coffee table as i like them as support units so you’re looking at about £200.00 per display case either way there is no cheaper alternative other than a wooden one with a clear front panel which would lend itself to a painted background and possibly a foil seascape might try that for the Hood who knows
                    Regards
                    Colin
                    • Bigfoot57
                      • Jun 2015
                      • 1103
                      #100
                      HMS Hood 1/200 Hachette /Amati Wooden kit Build Part 68 Decking Lockers & more pipe / conduit work
                      Hello so here is more of these pieces although not as a small as previous but still small enough this time we are fitting deck lockers and storage cases into the various markings printed on the decking as before here’s the instructions followed by my actual build
                      Regards
                      Colin
ID:	1171041Click image for larger version
ID:	1171042Click image for larger version
ID:	1171043Click image for larger version
ID:	1171044Click image for larger version
ID:	1171045Click image for larger version
ID:	1171046Click image for larger version
ID:	1171047Click image for larger version
ID:	1171048Click image for larger version
ID:	1171049Click image for larger version
ID:	1171050Click image for larger version
ID:	1171051Click image for larger version
                      • Bigfoot57
                        • Jun 2015
                        • 1103
                        #101
                        HMS Hood 1/200 Hachette /Amati Wooden kit Build Part 69 More Decking pieces and Hose Reels
                        Good morning this time we have more deck details to add and the hose reels mounted on the various bulkheads not much to add other than anyone building this kit or contemplating building it then I would recommend doing the hose reel holders in parts 40 44 and then jump to this stage ie 69 and fit the hoses into the holders then stick the holders and hoses as one piece in this stage as measuring and cutting them as I had to was a right pia
                        Regards
                        Colin
ID:	1171184Click image for larger version
ID:	1171185Click image for larger version
ID:	1171186Click image for larger version
ID:	1171187Click image for larger version
ID:	1171188Click image for larger version
ID:	1171189Click image for larger version
ID:	1171190Click image for larger version
ID:	1171191Click image for larger version
ID:	1171192Click image for larger version
ID:	1171193Click image for larger version
                        • boatman
                          • Nov 2018
                          • 14498
                          • christopher
                          • NORFOLK UK
                          #102
                          Comin on lovely Colin im enjoyin watching this come togeather but will be happy when that hull is painted
                          chris
                          • Bigfoot57
                            • Jun 2015
                            • 1103
                            #103
                            HMS Hood 1/200 Hachette /Amati Wooden kit Build Part 70 Support pillars
                            Well we’ve reached halfway stage 70 this time it involved painting 3 lengths of wooden poles and cutting them then gluing them onto the deck I didn’t bother adding instructions photos for this section as it was a case of paint the poles then measure off 18.5mm and cut to that length 18 times for the thin ones and 6 for the thick one so here goes making sure each one is level in both planes ie not leaning left or right and not backwards or forwards
ID:	1171340Click image for larger version
ID:	1171341Click image for larger version
ID:	1171342Click image for larger version
ID:	1171343Click image for larger version
                            • Bigfoot57
                              • Jun 2015
                              • 1103
                              #104
                              HMS Hood 1/200 Hachette /Amati Wooden kit Build Part 71 Front side panels leading to the forecastle part of the ship
                              Good evening so here’s another small section completed and I was very surprised by the way these 2 deck pieces fitted into place so tight no glue was needed only to secure the outer wall panels in place
                              I see I have a gap on the starboard side when it’s dry and set I will attend to that with a bit of plastic card or more likely spare brass work
                              Regards
                              Colin Click image for larger version
ID:	1171370Click image for larger version
ID:	1171371Click image for larger version
ID:	1171372Click image for larger version
ID:	1171373Click image for larger version
ID:	1171374Click image for larger version
ID:	1171375Click image for larger version
                              • adt70hk
                                • Sep 2019
                                • 10439
                                #105
                                Hi Colin
                                Apologies got behind on this. It's coming on very nicely indeed.
                                I don't think I've come across such a 'hybrid' model in terms of materials before.
                                I've obviously seen lots of plastic with a heap of PE thrown at it and the odd wooden deck for a plastic kit but never a kit were the wood is such such an integral part of the main structure, with the plastic providing the 'detail'.
                                It's been very interesting to follow.
                                Keep up the great work.
