HMS Hood 1/200 Amati Models
  • Bigfoot57
    • Jun 2015
    • 1103
    #106
    HMS Hood 1/200 Hachette /Amati Wooden kit Build Part 72-74 More deck details and finally the next decking layer
    Hello again sorry for the sporadic nature of my updates work has dictated this at present anyway here’s where I’m at
    So we add some deck detail including what look like lifeboat davits to me along with the 2 side panels built back in issue 47 I think
    Next they tell you to add the 5 separate deck pieces to the top of all those upright supports previously installed now if you do it the instruction way you’ll be left with gaps to fill in the uneven joints
    So I’ve joined all the pieces together beforehand and strengthened them with thin card strips on the rear which will effectively become the ceiling o n top of the supporting structure this I have 5 good flat perfect no gap joins and the deck just rests on top of the supports with minimum of adjusting required it will be glued into position prior to stage 76 taking place
    As always please see attached photos of instructions followed by my actual build
    RegardsClick image for larger version
ID:	1172139Click image for larger version
ID:	1172140Click image for larger version
ID:	1172141Click image for larger version
ID:	1172142Click image for larger version
ID:	1172143Click image for larger version
ID:	1172144Click image for larger version
ID:	1172145Click image for larger version
ID:	1172146Click image for larger version
ID:	1172147Click image for larger version
ID:	1172148Click image for larger version
    Colin
    • Bigfoot57
      • Jun 2015
      • 1103
      #107
      HMS Hood 1/200 Hachette /Amati Wooden kit Build Part 75 next decking layer
      So here is the very minor part of issue 75 ie 5 pieces of thin wood and a small brass detail that has to be saved for later
      As you can see as mentioned previously I’ve glued all the deck panels together to make one homogenous flat & even piece of decking instead of 5 individuals which I think looked terrible
      Regards
      Colin
ID:	1172150Click image for larger version
ID:	1172151Click image for larger version
ID:	1172152Click image for larger version
ID:	1172153Click image for larger version
ID:	1172154Click image for larger version
ID:	1172155Click image for larger version
ID:	1172156Click image for larger version
ID:	1172157Click image for larger version
ID:	1172158Click image for larger version
      • Bigfoot57
        • Jun 2015
        • 1103
        #108
        HMS Hood 1/200 Hachette /Amati Wooden kit Build Part 76-77 Fitting next decking layer Sanding 78
        So again not much to do in these 2 sections basically glue the deck pieces to the supports and then build some more hose reels and mountings and finally sand the hull down fill any imperfections re sand and repeat as necessary ready for the primer coat
        Regards
        ColinClick image for larger version
ID:	1172860Click image for larger version
ID:	1172861Click image for larger version
ID:	1172862Click image for larger version
ID:	1172863Click image for larger version
ID:	1172864Click image for larger version
ID:	1172865Click image for larger version
ID:	1172866Click image for larger version
ID:	1172867Click image for larger version
ID:	1172868Click image for larger version
ID:	1172869Click image for larger version
        • Bigfoot57
          • Jun 2015
          • 1103
          #109
          HMS Hood 1/200 Hachette /Amati Wooden kit Build Part 78-79 Sanding & Filling
          Hello
          So did my 1st primer coat on the hull and all those lighter patches are where filler has been added this will all need sanding smooth and the whole process repeated until we have a completely smooth surface
          I also finished of the hose reels that will be mounted onto the main decks
          Regards
ID:	1173019Click image for larger version
ID:	1173020Click image for larger version
ID:	1173021Click image for larger version
ID:	1173022Click image for larger version
ID:	1173023Click image for larger version
ID:	1173024Click image for larger version
            • 15815
            Hi Colin
            She's looking good and huge. Lots of different materials and techniques on this. Filling and sanding the hull will be time consuming but worth it to get a perfectly smooth finish.
            • Bigfoot57
              • Jun 2015
              • 1103
              #111
              HMS Hood 1/200 Hachette /Amati Wooden kit Build Parts 80 to 82 Fitting the centex decking onto the ship
              Hello again with the continuing build of HMS Hood this time were adding the Centex deck areas I believe that’s what they are called as it was a special non slip type of surface and was a dark grey from the look of it according to Amati anyway that’s the colour I have used
              After this test fitted & any areas that weren’t level were shimmed up to bring them level using thin card on the tops of the structure below before gluing down using pva glue this was were the joins were as this decking was in 6 parts
              I also added card bracing along the joins on the underneath to give it more stability so as usual here’s the mags photos followed by my own
ID:	1173584Click image for larger version
ID:	1173585Click image for larger version
ID:	1173586Click image for larger version
ID:	1173587Click image for larger version
ID:	1173588Click image for larger version
ID:	1173589Click image for larger version
ID:	1173590Click image for larger version
ID:	1173591Click image for larger version
ID:	1173592Click image for larger version
ID:	1173593Click image for larger version
ID:	1173594Click image for larger version
              • Bigfoot57
                • Jun 2015
                • 1103
                #112
                Now here are my build photos for this section
ID:	1173596Click image for larger version
ID:	1173597Click image for larger version
ID:	1173598Click image for larger version
ID:	1173599Click image for larger version
ID:	1173600Click image for larger version
ID:	1173601Click image for larger version
ID:	1173602Click image for larger version
ID:	1173598[ATTACH alt="41D2D01E-C1EF-46CB-ACDF-D165C67D90F1.jpeg"]450706[/ATTACH]
                  • 15815
                  Hi Greg
                  There's a lot in that stage. Adding shims and strengtheners is extra work but well worth doing. Looking very good.
                  • Bigfoot57
                    • Jun 2015
                    • 1103
                    #114
                    HMS Hood 1/200 Hachette /Amati Wooden kit Build Parts 83 to 85 Adding bulkhead walls to the Centex decking
                    In this section we are adding bulkhead walls to the Centex decking this involved fitting dozens of tiny buttressing pieces on to the bulkheads before bending them into the correct shapes then adding them to the decking as shown
                    The hull is also now ready for whatever comes next it is smooth and contoured I would think it would be its 1st proper colour but we still got the the exterior details to be added such as the propeller mountings etc
                    So here’s the mags my build photos will follow as normal
ID:	1173603Click image for larger version
ID:	1173604Click image for larger version
ID:	1173605Click image for larger version
ID:	1173606Click image for larger version
ID:	1173607Click image for larger version
ID:	1173608Click image for larger version
ID:	1173609Click image for larger version
                    • Bigfoot57
                      • Jun 2015
                      • 1103
                      #115
                      Here’s my build photosClick image for larger version
ID:	1173611Click image for larger version
ID:	1173612Click image for larger version
ID:	1173613Click image for larger version
ID:	1173614Click image for larger version
ID:	1173615Click image for larger version
ID:	1173616Click image for larger version
ID:	1173617Click image for larger version
ID:	1173618Click image for larger version
ID:	1173619Click image for larger version
ID:	1173620Click image for larger version
ID:	1173621Click image for larger version
ID:	1173622Click image for larger version
                      • scottie3158
                        • 14247
                        • Holbeach
                        #116
                        Colin,
                        Cracking work mate keep it up.
                        • Bigfoot57
                          • Jun 2015
                          • 1103
                          #117
                          HMS Hood 1/200 Hachette /Amati Wooden kit Build Parts 86-87 Motor launches
                          Yep this time were building 5 Motor Launches 3 x25ft & 2x 40ft these were incredibly fiddlesome to build and the end result is far from perfect but it’s the best I’m able to achieve so I’ll live with itClick image for larger version
ID:	1174172Click image for larger version
ID:	1174173Click image for larger version
ID:	1174174Click image for larger version
ID:	1174175Click image for larger version
ID:	1174176Click image for larger version
ID:	1174177Click image for larger version
                          Next set are my builds for this section
                          • Bigfoot57
                            • Jun 2015
                            • 1103
                            #118
                            Build Photos Parts 86 & 87
ID:	1174179Click image for larger version
ID:	1174180Click image for larger version
ID:	1174181Click image for larger version
ID:	1174182Click image for larger version
ID:	1174183Click image for larger version
ID:	1174184Click image for larger version
ID:	1174185Click image for larger version
ID:	1174186Click image for larger version
ID:	1174187Click image for larger version
                            • adt70hk
                              • Sep 2019
                              • 10439
                              #119
                              Colin,
                              Apologies for behind on this. That's coming on beautifully. Great work all round and at 1/200 if have no complaints about your motor launches.
                              Keep up the great work.
                                • 15815
                                Hi Colin
                                Nothing wrong at all with those motor launches.
