HMS Hood 1/200 Amati Models
  • scottie3158
    • 14247
    • Holbeach
    #121
    They turned out rather well mate.
    • minitnkr
      • 7574
      • Dayton, OH USA
      #122
      Your patience & skills know no bounds.
      • Bigfoot57
        • Jun 2015
        • 1103
        #123
        Many thanks for your kind words and comments I did forget to mention that each motor launch had to be custom made in that the side panels were too long to fit into the slots on the hulls this necessitated the cutting of each brass panel to size which is why in some cases the fit is not as it should have been
        This in turn meant that the bulkheads were now too wide and they to had to be trimmed to fit back into the hull another pia as the net result was loads of scratched off white paint that had to be redone with the panels in place which meant white paint also went onto the buff coloured decking as well which then also had to be redone
        And finally just for good measure I redid the grey on the hulls outer sides & then the support stands in white prop shaft and rudder in grey and the propeller blade I left in the brass colour it was made from
        As I said they are still not perfect the front windows of the 2x 40ft are completely wrong but due to the side panels being too long in the 1st place I cannot get the windows to fit how they should hence my frustration with this section of the build
        Regards
        Colin
        Next to come more decking & fixtures
        • adt70hk
          • Sep 2019
          • 10439
          #124
          Colin,
          A long litany of problems and knock on effects. To be honest I'm surprised they didn't find their way into the bin....
          Well done for persevering.
          ATB.
          • Bigfoot57
            • Jun 2015
            • 1103
            #125
            HMS Hood 1/200 Hachette /Amati Wooden kit Build Parts 88-90
            Ok so after the struggle with the launches in part 88 we don’t do anything except dry fit some decking so with that done we move onto part 89 where we actually fit down the decking which as you can a handy bottle of orange juice Click image for larger version
ID:	1174397Click image for larger version
ID:	1174398Click image for larger version
ID:	1174399Click image for larger version
ID:	1174400Click image for larger version
ID:	1174401Click image for larger version
ID:	1174402Click image for larger version
ID:	1174403Click image for larger version
ID:	1174404Click image for larger version
ID:	1174405Click image for larger version
ID:	1174406Click image for larger version
ID:	1174407came into as a press overnight to ensure the glue had taken again I had fit issues but this might be my fault this time & add a few more deck details onto this
            Then part 90 consists of nothing but building the admirals launch which compared to the previous was a pleasure to actually build so here are the requisite photos
            • Bigfoot57
              • Jun 2015
              • 1103
              #126
              HMS Hood 1/200 Hachette /Amati Wooden kit Build Parts 90 Admirals Motor launch
ID:	1174408Click image for larger version
ID:	1174409Click image for larger version
ID:	1174410Click image for larger version
ID:	1174411Click image for larger version
ID:	1174412Click image for larger version
ID:	1174414Click image for larger version
ID:	1174415Click image for larger version
              • Bigfoot57
                • Jun 2015
                • 1103
                #127
                HMS Hood 1/200 Hachette /Amati Wooden kit Build Parts 91 Scuppers Template & Bilge Keels
                So we’re now back to the main model after several issues building launches
                1st off we have to cut out the templates for the scuppers holes to be drilled these are going to have pe afterwards
                As you can see the templates are attached with tape only no glue I then used my usb powered mini drill which I think they are brilliant expect for one thing the spin so fast that anything drilled into plastic melts the resulting slag producing a plug which you have to remove afterwards if they could add variable speed control to these they would make pin vices obsolete in my opinion anyway I have drilled the holes for both sides the ship and marked them with a sharpie pen for easy identification
ID:	1174430Click image for larger version
ID:	1174431Click image for larger version
ID:	1174432Click image for larger version
ID:	1174433Click image for larger version
ID:	1174434Click image for larger version
ID:	1174435Click image for larger version
                • Bigfoot57
                  • Jun 2015
                  • 1103
                  #128
                  HMS Hood 1/200 Hachette /Amati Wooden kit Build Parts 91 Keel Strips
                  This next part of the build required me to dig out my set square and a bit of brain power for measuring where the keel strips actually fit
                  They were chamfered along the bottom edge and also at the ends & then tacked down with ca glue after which I then ran pva along both seems and tape the keels to the hull whilst the glue set
                  Next again using various rules to measure where the upper keel strips fitted and again chamfered at each end & then tacked down with ca followed by pva which brings us to where we are now
ID:	1174437Click image for larger version
ID:	1174438Click image for larger version
ID:	1174439Click image for larger version
ID:	1174440Click image for larger version
ID:	1174441Click image for larger version
ID:	1174442Click image for larger version
ID:	1174443Click image for larger version
ID:	1174444Click image for larger version
ID:	1174445Click image for larger version
ID:	1174446Click image for larger version
ID:	1174447Click image for larger version
                  • Bigfoot57
                    • Jun 2015
                    • 1103
                    #129
                    HMS Hood 1/200 Hachette /Amati Wooden kit Build Parts 94 DeGausing Strips
                    Apologies for lack of entries I do have a excuse Gastroenteritis for a week then recovering for another only just returned to the bench
                    Parts 92 & 93 were more lifeboat / launches construction same as before so I didn’t bother showing them
                    Onwards part 94 is the start of the degausing strips if I’m not mistaken I know there’s a lot of controversy over should they be singles or a double I can only go with what the kit has supplied anyway fairly simple process as you can see from the attached photos
ID:	1175747Click image for larger version
ID:	1175748Click image for larger version
ID:	1175749Click image for larger version
ID:	1175750Click image for larger version
ID:	1175751Click image for larger version
                    Regards
                    Colin
                    • Bigfoot57
                      • Jun 2015
                      • 1103
                      #130
                      HMS Hood 1/200 Hachette /Amati Wooden kit Build Parts 95 -96 More Decking
                      Hello again so now we come to adding more decking onto the model and then adding details on top of this
                      One major problem was the rear superstructure already fitted prevented me in sliding the rear decking underneath it as the instructions would have you do it so I had to cut my decking in 2 and custom fit it to the plywood decking afterwards
                      Thinking about this I reckon once you have all the base decks in place before adding any further details you should glue the wooden planking decking on top of the plywood decks that way you get a continuous flat surface devoid of obstacles with which you can work with will test this out on the Bismarck build after this one
                      So we eventually got all the decking down and in place with a few bodges ready for more details to be added
                      Used the good old 2 litre bottles of juice to weigh down the glue overnight before continuing
                      Regards
                      Colin
ID:	1176030Click image for larger version
ID:	1176031Click image for larger version
ID:	1176032Click image for larger version
ID:	1176033Click image for larger version
ID:	1176034Click image for larger version
ID:	1176035Click image for larger version
ID:	1176036Click image for larger version
ID:	1176037Click image for larger version
ID:	1176038Click image for larger version
ID:	1176039Click image for larger version
ID:	1176040Click image for larger version
ID:	1176041Click image for larger version
                      • Bigfoot57
                        • Jun 2015
                        • 1103
                        #131
                        HMS Hood 1/200 Hachette /Amati Wooden kit Build Parts 97-98 yet More Decking
                        So continuing on from previous post there’s more decking to add and then construct 5 more hose reels along with 2 chimney type vents fairly short and simple this section the gap at the front I’m not too worried about as the turret will conceal this error which as I stated previously could have been avoided by gluing the wooden upper decking onto the plywood before adding additional fixtures and fittings then gluing the planking decking around these
ID:	1176043Click image for larger version
ID:	1176044rClick image for larger version
ID:	1176045Click image for larger version
ID:	1176046Click image for larger version
ID:	1176047Click image for larger version
ID:	1176048Click image for larger version
ID:	1176049Click image for larger version
ID:	1176050Click image for larger version
ID:	1176051Click image for larger version
ID:	1176052Click image for larger version
                        • Bigfoot57
                          • Jun 2015
                          • 1103
                          #132
                          HMS Hood 1/200 Hachette /Amati Wooden kit Build Parts 99-100
                          Well we’ve got to 100 on this build and the centenary is pretty boring actually as you can see we stick on the anchor chain guides and a load of tiny eyebolts and mushroom ventilators which I drilled out the holes into the wooden decking cause all the kit wanted was them to be stuck onto the surface only yea ready to snap off at a moments notice at least by drilling them it gives to my way of thinking a much stronger fixing so with that in mind here’s where I’m at on this build
                          Regards
                          Colin
ID:	1176770Click image for larger version
ID:	1176771Click image for larger version
ID:	1176772Click image for larger version
ID:	1176773Click image for larger version
ID:	1176774Click image for larger version
ID:	1176775Click image for larger version
ID:	1176776Click image for larger version
ID:	1176777Click image for larger version
ID:	1176778Click image for larger version
ID:	1176779Click image for larger version
ID:	1176780Click image for larger version
                          • Bigfoot57
                            • Jun 2015
                            • 1103
                            #133
                            HMS Hood 1/200 Hachette /Amati Wooden kit Build Parts 101-102
                            More lifeboats and some deck details this time
ID:	1177578Click image for larger version
ID:	1177579Click image for larger version
ID:	1177580Click image for larger version
ID:	1177581Click image for larger version
ID:	1177582Click image for larger version
                            • Bigfoot57
                              • Jun 2015
                              • 1103
                              #134
                              HMS Hood 1/200 Hachette /Amati Wooden kit Build Parts 103-104
                              Yet more deck details what I find unbelievable at this time is we are now adding loads of parts to the deck upwards of 200 yet we still haven’t painted the hull stay tuned for that after the next 2 sets of magazine photos
ID:	1177585Click image for larger version
ID:	1177586Click image for larger version
ID:	1177587Click image for larger version
ID:	1177588Click image for larger version
ID:	1177589Click image for larger version
ID:	1177590Click image for larger version
ID:	1177591Click image for larger version
                              • Bigfoot57
                                • Jun 2015
                                • 1103
                                #135
                                HMS Hood 1/200 Hachette /Amati Wooden kit Build Parts 105-106
                                Now we’re building the stand and nameplate which I elected to do Red then carefully sand back the paint of the raised areas to give the brass look to the writing Click image for larger version
ID:	1177593Click image for larger version
ID:	1177594Click image for larger version
ID:	1177595Click image for larger version
ID:	1177596Click image for larger version
ID:	1177597Click image for larger version
ID:	1177598Click image for larger version
