USS Constipation 1/120 scale Imai long suffering build
  • rtfoe
    • 9125
    Hi me fellow Laddies,
    This USS Constitution build is long in the tooth with many interruptions along the way therefore it is aptly renamed the USS Constipation. My wife got me this kit almost 35 years ago before we were married. It's a beauty of a kit that I said to myself that I would build it when my skills were better. I really only started this when we moved into our second home in '96. I referenced from a lot of ship builds to get my sea legs. That took part of 10 years of doddeling and fiddling with the parts and was putting the hulls together when the house got flooded. Water rose to just the edge of the table top so it didn't get launched from the slipways. It has since been shelved with occasional tinkering especially the ratlines but recently having seen Jim's cross section of Victory's deck got me fired up to tackle this mighty ship again.
    Some of you may have seen it's progress in the last forum so here are some refreshed images and where I will start...
    The state of the box show it's years being on the shelf and getting a bit wet from the flood.
    The white strip along the gun deck still looks white in these images.I would soon regret not lightening the deck which you will see soon. The gun ports were just holes molded into the hull so careful masking was taken to create the thickness of the hull even painting the drawing in the joints.
ID:	1164087Click image for larger version
    You can clearly see the mud stains left from the flood. I didn't do a good enough cleaning of the stand. I only managed the rear of the hull after the flood by painting up the windows, lines, stars and the embossed lettering. The rudder comes solid attached to the hull with no gaps in between the hinges.
    I weathered the lower hull copper plating with green streaks.
    This is where I went crazy and decided that the given ratlines were too thick and redid them with a jig made from plywood and hundreds of nails patiently tacked into place.
    It survived the flood although the corners threaten to peel off.
ID:	1164092Click image for larger version
ID:	1164093Click image for larger version
    From this point on is current having masked the panels on the top deck only yesterday. I did this at the LHS while having a great get together with fellow modelers I haven't seen for some time.
    By the time I got home some of the masking were popping up so just before spraying I pressed them down.
ID:	1164096Click image for larger version
ID:	1164097Click image for larger version
    Results of the spraying today were satisfactory using Testors Enamels Radom Tan and Afrika Braun.
    I chose these lighter shades so that when the dark washes are applied, the overall shade won't be too dark eventually.
    At least now the green on the inner sides of the deck can be distinguished and everything else pops out.
    Hope the constipation ends and this sees the light at the end of the tunnel. Hope to surprise my wife when she sees it on the mantle of the living room.
  • Mini Me
    • Jun 2018
    • 10711
    Hi Richard........there'll be a surprise alright! I tried that once, found out completed models are NOT considered art forms and are NOT welcomed by management in any quarter of living spaces occupied by "Herself"!! :tongue-out3: :tongue-out2::tongue-out: Rick H.
    • rtfoe
      • 9125
      Rick, actually on the contrary as she bought it explicitly to be displayed in our new house 34 years ago (hope she remembers). The others of course are strictly to be kept in the man cave. :tongue-out3::smiling5::tears-of-joy:
        • 18958
        That’s looking super Richard. Agree with the lightened deck planking, it looks much more in keeping. The ratlines will be a thing of great beauty when completed and fitted.
          • 15820
          Hi Richard
          Well if your good lady has been patient for 34 years she deserves to see it completed. Tim is right - the deck looks much nicer. The ratlines look good, worth all the time and effort.
          • rtfoe
            • 9125
            Thanks Tim, had I just built and finished this kit many years back I'd have to live with the wrong color finish of the deck, sometimes a delay can fix things right but not this late. :smiling2: Keeping my fingers crossed that the decision on the ratlines will come out looking better.
            Originally posted by Jim R
            Hi Richard
            If she recognises it then it will be great but safe to say I don't make many sail boats. Appreciate your comment as well Jim.
            I have only just sprayed the Future varnish over the deck after letting the enamel layer cure properly for a day and a half. Also checked over the rest of the parts and found the gun and carriages which I had thought were missing and was contemplating to cast them.
              That's a lot of fiddly work Richard, and looking at the hull with the new paint work it will be well worth it .
              34 Years , Mrs R tells me she's had to wait even longer for some jobs to be done !
              • rtfoe
                • 9125
                John, I think she knows the Constipation needs to be done with love so she's willing to wait...other jobs are chop chop get to it and done within the hour. :smiling6:
                • rtfoe
                  • 9125
                  Hi, made a little progress today with a dark wash over the deck using my trusted watercolor technique. Mixed up a batch of black and brown with a little dab of detergent and applied liberally over the deck...
                  I then let it dry for about an hour...
                  Using a moist cloth and damp cutip, I rubbed off the wash and what remained was left in the grooves and in between the raised details.
                  Even the wood panelling detail showed up and I might enhance further by dry brushing a lighter shade of the Radom Tan.
                  At the time of this I was halfway done removing the wash.
                  I smoothen out and blended the the shades by rubbing with a dry cutip. Pics of the finish deck later when I'm done.
                    • 18958
                    [ATTACH=CONFIG]n1164221[/ATTACH]
                    [ATTACH=CONFIG]n1164222[/ATTACH]
                    [ATTACH=CONFIG]n1164223[/ATTACH]
                    [ATTACH=CONFIG]n1164224[/ATTACH]
                    [ATTACH=CONFIG]n1164225[/ATTACH]
                    That wash looks fantastic. A light dry brush now will really make it pop….
                      • 15820
                      Hi Richard
                      That looks very good. I suppose the secret to a water based wash is the addition of detergent. Water based washes are prone to leaving an 'edge mark'. Going back over it has really worked.
                      • rtfoe
                        • 9125
                        Thanks Tim, yes can't wait to dry brush and see the results. As it is now it also looks okay.
                        Hi Richard
                        Thank you Jim, detergent breaks the surface tension and lets the water spread and adhere to the surface. It takes getting used to and there's no fear it will ruin the underlying paint work.
                        I've cleaned up all the wash and preparing for a layer of varnish for protection...
                        The black calking in between the planks is now more visible...
                        The cutip not only helps with blending but also gets into the tight spaces.
                        The wash was also applied to the steps and side gangway pillars. I wonder if I should paint the nails black or dark metal...
                          • 18958
                          [ATTACH=CONFIG]n1164260[/ATTACH]
                          [ATTACH=CONFIG]n1164261[/ATTACH]
                          [ATTACH=CONFIG]n1164262[/ATTACH]
                          Not sure the nails were dark metal. They were continually soaked in salt water in heavy seas, so would rust really quickly if they were iron. I would guess they were copper or wooden pegs….
                          • minitnkr
                            • 7576
                            • Dayton, OH USA
                            Holy stoning would lighten any deck. Would assume pegs but don't know as the description of how spar deck planking was fastened is unclear if they would be visible regardless.
                            • adt70hk
                              • Sep 2019
                              • 10445
                              Outstanding Richard. Top notch work!!
                              Just looking at that rigging is giving me to the heebie-jeebies!! :surprised: :loudly-crying:
                              Keep up the great work.
                              ATB.
