Very nice job Richard. I suspect that the restored version is not 100% original since it is designed for the public to climb around on not for sea action. I see you have fitted the Channels for the shrouds you might just check that the shrouds when installed do not foul the top of the hammock netting, as they go up to the tops. If you do run into a problem then you could just bend the outer stanchions inwards a little. This would be accurate since on the original the stanchions do follow what is called the "Tumblehome" or the inward slope of the hull.
