Trumpeter 1/200 titanic.
  • peterairfix
    • Jul 2012
    • 11083
    It had to happen because I couldn't wait to get my pass on one.
    I have had a look under the lid and found five other boxes and one long one that I assume contains the Hull I haven't gone any further as I will cove what's in each individual box as I get to them.
    The led set I will not using as it only lights the upper Hull and I don't fancy drilling all those portholes (one ship is enough).
    Some pictures
ID:	1165097Click image for larger version
ID:	1165098Click image for larger version
ID:	1165099Click image for larger version
ID:	1165100Click image for larger version
    The first I will be doing is sorting out the mould seem. Click image for larger version
ID:	1165102Click image for larger version
    Some of the Hull detailClick image for larger version
ID:	1165104Click image for larger version
ID:	1165105Click image for larger version
ID:	1165106Click image for larger version
  • peterairfix
    • Jul 2012
    • 11083
    Started on the Hull the first to be done are the two piece propshafts and the rudder. Click image for larger version
ID:	1165159Click image for larger version
    The first pieces of peClick image for larger version
ID:	1165161and Hull painting. Click image for larger version
ID:	1165162Click image for larger version
    • peterairfix
      • Jul 2012
      • 11083
      I won't showing what's in each box as it's a case of one part in one box and the other in another box.
      But no construction yet as its the Hull painting has taken two days but its now finished and the next up will be the well decks. Click image for larger version
ID:	1165203Click image for larger version
ID:	1165204Click image for larger version
ID:	1165205Click image for larger version
ID:	1165206Click image for larger version
ID:	1165207Click image for larger version
      • adt70hk
        • Sep 2019
        • 10438
        Great work already Peter. That really is something.
        ATB.
        • peterairfix
          • Jul 2012
          • 11083
          Forward well deck painted and in placeClick image for larger version
          And two steam winches and I found it easier to construct them on the spure.Click image for larger version
ID:	1165236Click image for larger version
          And in place. Click image for larger version
          • scottie3158
            • 14245
            • Holbeach
            Nice start.
              • 15799
              Hi Peter
              Nice start. Neatly painted hull. Certainly a very big model.
              • stillp
                • 8105
                • Pete
                • Rugby
                Coming on well Peter. Nice of the cat to let you borrow their climbing frame!
                • stillp
                  • 8105
                  • Pete
                  • Rugby
                  I don't know why I posted that twice!
                  • peterairfix
                    • Jul 2012
                    • 11083
                    Started on the fire deck as yet no construction as it all consists of painting.
                    One annoying thing is there are no rigging plans. Click image for larger version
ID:	1165268Click image for larger version
                      • 18272
                      Have you seen this Peter:
                      Some very helpfull info including the shackle and ties, even the types of wires and the size!
                      Very tidy work on that huge hull.
                      • peterairfix
                        • Jul 2012
                        • 11083
                        Brilliant thanks very much.
                        • peterairfix
                          • Jul 2012
                          • 11083
                          Still on the painting I have finished the act well deck and the poop deckClick image for larger version
ID:	1165375Click image for larger version
ID:	1165376Click image for larger version
ID:	1165377Click image for larger version
                          • adt70hk
                            • Sep 2019
                            • 10438
                            Coming on very nicely indeed Peter.
                            A great job.
                            ATB.
                            • peterairfix
                              • Jul 2012
                              • 11083
                              Finally got round to actual construction I have put the upper side walls on and some inner walls and pe windows. Click image for larger version
ID:	1165657Click image for larger version
ID:	1165658Click image for larger version
ID:	1165659Click image for larger version
