Tamiya 1/350 KGV plus extras
  • BattleshipBob
    • 6803
    • Bob
    • Cardiff
    #196
    Well the tape is off, looks a bit better than I thought it would, but could / should have much better
ID:	1179998Click image for larger version
ID:	1179999Click image for larger version
ID:	1180000Click image for larger version
    Cheated by using the black Mr color surfacer primer as the boot topping, masked over it with 5mm tape, worked yes and no, not to happy
    There are a few places where paint has got under the tape.
    Around the props the paint needs redoing, i must have been to far away, it's very grainy. With Most of the many issues I will try to brush paint over.
    Today I have removed the booths and paint from the garage plus its far to hot. Should not have tried painting in the first place as my mind has a lot going on at the moment. Hopefully the new room will get rid of most of the painting issues
    What do you think, will leave and not strip
    • Code no 10
      • Jun 2022
      • 130
      #197
      [ATTACH=CONFIG]n1179998[/ATTACH][ATTACH=CONFIG]n1179999[/ATTACH][ATTACH=CONFIG]n1180000[/ATTACH][ATTACH=CONFIG]n1180001[/ATTACH]
      Looking at the painting......I'm also pretty undecided on the next course of action.
      Normally, it helps when I walk-away for a few days. then look at it again and decide that is best thing to do.
        • 15745
        Hi Bob
        It will be fine. A light sanding and then careful touch up. Weathering, even just light weathering, will tend to blend things together. You're gonna get stains down from port holes and general fading of the paint etc.
        • BattleshipBob
          • 6803
          • Bob
          • Cardiff
          #199
          Well it's been a while! But the workers have returned.
          Added the wooden decks and had a go at tidying the mistakes in the hull. Decided to stick with Mr Color and not enamels although I will finish KGV with the enamels
ID:	1187518Click image for larger version
          Had to boot a cat off the bed, he's not happy lol
          • BattleshipBob
            • 6803
            • Bob
            • Cardiff
            #200
            Bit more
            Fitted rear shelter deck and test fitted bridge base, lovely fit just snaps into place, next dreaded PE. Then deck painting
ID:	1187910Click image for larger version
            I can now see why ships can take so long!
              • 18932
              Bit more
              [ATTACH=CONFIG]n1187910[/ATTACH][ATTACH=CONFIG]n1187911[/ATTACH]
              Looking very good Bob. As to time, just look on it as lots of little kits added together, a bit like a diorama…….
              • scottie3158
                • 14221
                • Holbeach
                #202
                This is coming on a treat mate.
                • BattleshipBob
                  • 6803
                  • Bob
                  • Cardiff
                  #203
                  It's taken me a while to work that out Tim! Brush painted the shelter deck, not too bad, but will spray paint the bridge funnels etc. Always meant this to be a learning/experimental build and my god its turned out that way lol
                  Cheers Paul, appreciated
                  • boatman
                    • Nov 2018
                    • 14498
                    • christopher
                    • NORFOLK UK
                    #204
                    BLOOMIN GOOD SHOW m8ty am glad you are back on that battlewagon nice work cant but help admire your work an skill
                    chrisb
                    • adt70hk
                      • Sep 2019
                      • 10428
                      #205
                      Loving it Bob! But rather you than me!
                      • BattleshipBob
                        • 6803
                        • Bob
                        • Cardiff
                        #206
                        chrisb
                        Gradually improving Chris, a very steep learning curve!!
                        • BattleshipBob
                          • 6803
                          • Bob
                          • Cardiff
                          #207
                          Cheers Andrew, it's like Tim says, many small kits and all within a large box lol. This is basic compared to others I have planned, pallet load of headache tablets on the way
                          • boatman
                            • Nov 2018
                            • 14498
                            • christopher
                            • NORFOLK UK
                            #208
                            WELL Bob m8ty they are quite difficult to build but ive been building them for 30 odd yrs so i know a bit on how to go about building these ships but you goin from a stuggie to a big ship is to me amazeing an you have done it to very well done m8ty
                            chrisb
                            • BattleshipBob
                              • 6803
                              • Bob
                              • Cardiff
                              #209
                              chrisb
                              Far to kind Chris, must find my chq book!!
                              • boatman
                                • Nov 2018
                                • 14498
                                • christopher
                                • NORFOLK UK
                                #210
                                YEA BOYO make that chq a biggee lol an did you find them guns up again ?
                                chrisb
