Tamiya 1/350 KGV plus extras
  • BattleshipBob
    • 6803
    • Bob
    • Cardiff
    #226
    Not a good idea 'Admiral' Bob. If you hide behind the sofa, most of the time the parts will end up getting stuck there and not on the ship model. Just take your time, follow the guy's advice, take a deep breath and you will finally succeed with PE. But......Then you have to have to be extra careful when handling the parts afterwards so not to ping them off again.......
    Allen
    I hate that ping Allen, I really hope new 3d printed parts take over and asap
    • BattleshipBob
      • 6803
      • Bob
      • Cardiff
      #227
      Has anybody got a photo of the loctite superglue gel please
      Got one and it comes with a activator as well??
        • 15745
        Hi Bob
        No doubt PE can be a real test of ones patience but is often worth while for the added detail. The idea of tacking the PE in place with PVA, letting it dry and then wicking thin CA along the join does work well in many situations.
        Keep at it, all's looking good.
        • BattleshipBob
          • 6803
          • Bob
          • Cardiff
          #229
          Originally posted by Jim R
          Hi Bob
          Thanks Jim, refitting the hair I pulled out, not got much left anyway!!
            • 18932
            This one Bob
            You will find that the added “dispenser” doesn’t dispense all of the glue. It leaves about half a tube. When you can’t get any more out just take it off and use the tube as normal.
            • BattleshipBob
              • 6803
              • Bob
              • Cardiff
              #231
              This one Bob
              [ATTACH=CONFIG]n1188533[/ATTACH]
              Thanks Tim, sorry to be a pain
              I assume as its a gel you have to use a cocktail stick not a looper ??
                • 18932
                I use a thin wire, but then, I haven’t got a looper
                • boatman
                  • Nov 2018
                  • 14498
                  • christopher
                  • NORFOLK UK
                  #233
                  This one Bob
                  WELL Tim ive treid this yes the c/a is good but in my opinion you pay more for the fancy outer casein than the small tube of glue inside it an i do a lot of modeling as you have seen on my tiger build an i use the cheepo c/a from pound land an you get 3 bottle an some very nice thin add on tube just right for you Bob m8ty as it controlls the flow to a very small flow so glue not everywhere but this is just my opionin an Bob m8ty when you come to glue on that pesky p/e just rough up the area with a small bit of sand paper on both bits an it will stick so get to it boyo
                  chrisb
                  • scottie3158
                    • 14221
                    • Holbeach
                    #234
                    Bob, a cheap but very effective way of placing glue is to get a sowing needle hold the pointy end in a pin vice or spare exacto handle then snip of the end of the eye to leave a fork. When it gets clogged just bun the residue in a flame but avoid breathing in the fumes.
                    • minitnkr
                      Charter Rabble member
                      • 7551
                      • Dayton, OH USA
                      #235
                      I have two as above, one a regular sewing needle for thin CA & a large one from a turkey sewing (w/twine) needle for thicker gel CA. Work great.
                        • 18932
                        chrisb
                        I just posted it because Bob asked for it Chris. If you look around, it’s just over three quid a pot, hardly expensive……
                        To be honest, I don’t use CA much because I find the bonds are suspect under load. Most of them hold, but for no real reason at all, one can shear off when you least expect it. In my case, anything that will be regularly handled, and that can’t be mechanically reinforced, gets stuck on with 5 minute Devcon if possible because it‘s bond is far superior.
                        Trouble with adhesives is that we all think one size fits all, especially with CA. There are lots of grades and types, and some are better at certain jobs than others.…….flexible types being good where shock loading is expected, and the Locktite bearing retainer range being great for holding gears on shafts…..as examples.
                        Whatever Sauron says, there just isn’t “One glue to rule them all, and in the darkness bind them”………horses for courses, that’s the watchword.
                        • BattleshipBob
                          • 6803
                          • Bob
                          • Cardiff
                          #237
                          Very true Tim, I should know lol
                          • boatman
                            • Nov 2018
                            • 14498
                            • christopher
                            • NORFOLK UK
                            #238
                            WELL Tim i was just tryin to save ow m8 Bob some money is all but up to him on that an 4 grams wont go far on a model like my tiger as i have found out to my cost so i started to buy locktigh 10 gram bottles an that is exspensive nr 7 pound a bottle here in the shops an yes i had a good look around before i bought may be it cheaper where you live
                            ATB
                            Chrisb
                              • 18932
                              Chris mate, if you are using that much an alternative like Devcon might be more cost effective for certain larger joints……..just use the CA to tack the part in place while the Devcon goes off……
                              • boatman
                                • Nov 2018
                                • 14498
                                • christopher
                                • NORFOLK UK
                                #240
                                HI Tim what is devcon ? an if it takes time to go off then no good to me i need an instand bond like im gettin with that glue im usin now but each to his own eh
                                chrisb
