Tamiya 1/350 KGV plus extras
Looking good Bob. Confused me a bit for a second or two though….I was thinking how did they get the hull sides in that box…..then I realised the box was for Graff Spee, not KGV lol….
PE starting to be tamed as well……Comment
Slow by steady, I hope!Comment
Used PVA to refit some wonky PE, worked a treat, gave me plenty of time to align, and seems a good join!
Had a worrying thought, would the wooden deck fit over the PE, phew it does lol.
Fitted bow deck after some fettling, also added a strip of plastic between middle and bow decks, stopped the flexing. Also removed and drilled out anchor areas.
bit more tidying to do then Mr surfacer to fill in the deck edge gaps
Note a lot of red Ammo glue, finding the brush can hold a lot of glue, so difficult to remove the right amount, so had my one in five yrs brainwave!!!! Yes I do have them. Found a brush from Deluxe materials glue, hay presto perfect.
Does not hold a lot of glue and very fine point, much, much better control!
Hope I am not posting to much, do not want to be boring you all to sleep ??Comment
[ATTACH=CONFIG]n1171294[/ATTACH]
[ATTACH=CONFIG]n1171295[/ATTACH]
[ATTACH=CONFIG]n1171296[/ATTACH]
[ATTACH]447968[/ATTACH]
[ATTACH]447969[/ATTACH]
[ATTACH]447970[/ATTACH]
chris bComment
Thank Jack try to stay awake lol
Cheers Pete, need a kip have a look!!!
Cheeky bugger!!
Thanks Jim, appreciatedComment
