Airfix 1/600 Bismarck becomes Tirpitz....and then disappears!
  • spanner570
    • 15428
    I've just had a couple of weeks away camping and as the days are now getting shorter, I took a kit away with me for summat to do in the evenings. - Before opening some refreshment!
    I chose the ancient Airfix Bismarck. It is a dog of a kit and almost every part needs serious cleaning up, and I mean serious. Some parts are almost impossible to tell just what they are until they are filed and scraped.
    Having built one on here already, I knew what to expect. However, building this kit is not really the main reason for the exercise.
    On we go.....
ID:	1185416Click image for larger version
ID:	1185417Click image for larger version
ID:	1185418Click image for larger version
ID:	1185419Click image for larger version
ID:	1185420Click image for larger version
    Cheers.
    Ron
  • Mark1
    • Apr 2021
    • 4156
    They could have made two kits with all that plastic!
    • Gern
      • 9222
      And I thought my PST Russki fire engine was bad! When you say disappeared, I hope you mean something other than all the parts disappearing among all the flash?
      Mind you, thinking about it, all that cutaway flash should keep the carpet monster fed for a while!
      PS Welcome back.
      • spanner570
        • 15428
        Most excellent and funny observations chaps. A bad kit indeed!
        Luckily for anyone tough enough to be following, this will be a 'Quicky' build. Simply because I finished the ship whilst away and not many pictures, so I will only show the salient points - Of which there are precious few.
        I completed the 'other stuff' I needed to finish the thing, at home over the last two days.......
        Thanks Dave, it's nice to be back, although the wife's birthday is approaching later this month, and she wants to spend it by the seaside, so we will no doubt be off again...NEEEEOWWWW!
        Thanks for the input boys.
        Ron
          • 18926
          Now that’s what I call flash…….did they actually bother with the second half of the mould?
          • spanner570
            • 15428
            Thanks Tim. makes you wonder, that's for sure!
            The strange thing is, all the large parts are of good quality with very little cleaning up and are an excellent fit.
            Hull and main deck joined.
            Excellent deck planking. The joint 'caulking' is almost invisible. Which is how it should be. As the real caulking was only about 15mm wide, even on a 1/350, this detail should be very feint.
            I haven't done any weathering of the main deck for reasons that will soon be made clear........
            Cheers.
            Ron
              • 15734
              Welcome back Ron. That's what I call flash! It's like chipping away at a rock in the hope of finding a fossil or a precious stone inside. Bet your camper needed a lot of hoovering.
                • 18926
                Must admit, the deck detail looks very good Ron. I think I built this when was about ten……so it’s knocking on a bit….
                • scottie3158
                  • 14216
                  • Holbeach
                  Ron,
                  I guess the quality guys Labrador must have nipped out for a smoke break. That flash is shocking. But if someone can beat this into shape it will be you.
                  • stillp
                    • 8096
                    • Pete
                    • Rugby
                    More flash than parts!
                      • 18926
                      What, Ron or the kit?
                      • BattleshipBob
                        • 6803
                        • Bob
                        • Cardiff
                        That's one very old mould!!
                        • PaulTRose
                          • Jun 2013
                          • 6489
                          • Tattooine
                          I think that tooling is well past its use by date
                          Per Ardua
                          • Gern
                            • 9222
                              To misquote Michelangelo " Every block of plastic has a model inside it and it is the task of the modeller to discover it." - I'm afraid I gave up on Airfix 1/600 models a while ago - far too much part preparation for what are pretty crude models...............
