1/72 HMS Iron Duke - Type 23 Frigate
  • boatman
    • Nov 2018
    • 14498
    • christopher
    • NORFOLK UK
    #226
    HI Garry she's lookin good in that grey an how did you paint it hairy stick ' A/B
    OR rattlecan ? an have you fitted in your R/X yet an any servo ? as be nice to see inside with pics
    chrisb
    • Tworrs
      • Jan 2022
      • 1982
      • Garry
      • New Zealand
      #227
      chrisb
      All painting is with an airbrush Chris, with the odd awkward bit done using a paintbrush.
      I'm still waiting on bits to connect the servos etc, as you can imagine the festive season has played havoc with deliveries.
      • Tworrs
        • Jan 2022
        • 1982
        • Garry
        • New Zealand
        #228
        I've been plodding on over the festive season and here are the fruits of my labour.
        Firstly the motors and ESC's
        Then the rudders and servo
        The main battery compartment, and also the stabilisers and servo.
        Then the power distribution area.
        • Mini Me
          • Jun 2018
          • 10711
          #229
          Nice tidy work Garry......next up, operational check. :thumb2:
          • boatman
            • Nov 2018
            • 14498
            • christopher
            • NORFOLK UK
            #230
            LIKE Rick said VERY TIDY WORK like very much :thumb2: :thumb2: :thumb2: :thumb2: :thumb2: Garry
            chrisb
            • Tworrs
              • Jan 2022
              • 1982
              • Garry
              • New Zealand
              #231
              Thank you Rick and Chris, much appreciated.
              • flyjoe180
                • Jan 2012
                • 12440
                • Joe
                • Earth
                #232
                Thesis looking Great Gary, very nice workmanship
                • boatman
                  • Nov 2018
                  • 14498
                  • christopher
                  • NORFOLK UK
                  #233
                  HI Garry ive been studyin your stabilizer layout an i cannot see how the stabs will work from that servo as the servo will pull an push left an right from what i see but your stabs arms need to be pulled an pushed up an down SORRY Garry this is not critisuim of your build its just an observation
                  chrisb ps GARRY HERE IS A SHOT OF MY TIGERS STABILIZERS AN THE PUSH RODS THAT WORK THEM FROM THE RUDDER Click image for larger version
                  • Mickc1440
                    • 4779
                    #234
                    More great work Garry, this really is looking superb
                    • Tworrs
                      • Jan 2022
                      • 1982
                      • Garry
                      • New Zealand
                      #235
                      Thank you so much Joe
                      Very kind of you to say Mick.
                      chrisb ps GARRY HERE IS A SHOT OF MY TIGERS STABILIZERS AN THE PUSH RODS THAT WORK THEM FROM THE RUDDER [ATTACH]470895[/ATTACH]
                      Thanks for your observation Chris, and no exception taken. I had noted your method of connecting the rudders and stabilisers which I had seen on your build log, but when I saw that my new TX could do mixes I went a different route.
                      I have set up a mix for the rudder/servo operation, in that the rudders connect to a servo which is the master and the stabilisers connect to another servo which is the slave, both connected to seperate channels on the RX, and mixed, to allow only 50% of the rudder movement to be used for the stabilisers. Dry testing has shown it to be roughly proportional, however I will make any adjustment that needs to be made once she is launched and I can see how she responds to rudder input.
                      The angle of the rods from the servo to the stabiliser arms is sufficient to turn the stabilisers as the round servo "arm" is low enough to operate them correctly.
                      I hope all that makes sense.
                      Garry
                        • 15746
                        All looking very neat and sorted Garry. I wouldn't know where to start and when you and Chris get chatting it's like a foreign language :rolling: :smiling:
                        • boatman
                          • Nov 2018
                          • 14498
                          • christopher
                          • NORFOLK UK
                          #237
                          OK Garry but i to me the servo looks as if its just tryin to pull the stabs leavers accross the hull instead of up an down an will you get enough movement on the stabs ? as mine need to travel at least an inch either way but if yours do then well done my freind
                          ATB
                          Chrisb
                          • Tworrs
                            • Jan 2022
                            • 1982
                            • Garry
                            • New Zealand
                            #238
                            I decided to spray the underside of the hull, and am pretty disappointed, I used Vallejo Air Hull Red, and to my eyes it looks brown, after two light coats.
                            I'll have to look for an alternative, any suggestions?
                            • Mini Me
                              • Jun 2018
                              • 10711
                              #239
                              If it were my ship build Garry, I think I would opt for an Enamel based paint and lay down several coats to give it a good seal against moisture penetration. Rustoleum (other brands are available) comes to mind.......relatively inexpensive and available in "rattle" cans in quantities large enough to knock this bad boy out. They also have a pretty extensive range of colors. Hope this helps.:smiling3:
                              • Tworrs
                                • Jan 2022
                                • 1982
                                • Garry
                                • New Zealand
                                #240
                                Many thanks for the suggestion Rick, I am not concerned with moisture penetration as I sealed the hull, both inside and out, with epoxy resin.
                                I will have a look at enamel based paints and see what colours they have locally in rattle cans.
                                Thanks again
                                Garry
