1/72 HMS Iron Duke - Type 23 Frigate
  • Mini Me
    • Jun 2018
    • 10711
    #241
    Pretty sure enamel will produce a more durable finish, which I think would work well for your purposes. :thumb2:
      • 18932
      The colour issue happens because some red pigments are transparent. It’s why artists grade paints are graded in terms of transparency.
      Not sure, but it looks like you first primed the hull in black. If so, the brown colour is what I would expect. If you mix black and red you get brown .
      If you want the hull painted red I would first prime in a red oxide colour primer. Just take a trip to your local car factors and buy a couple of touch up rattle cans, one a red primer and the other in the colour you want.
      • Tworrs
        • Jan 2022
        • 1982
        • Garry
        • New Zealand
        #243
        Thanks for your observations Tim, however the ship was undercoated in light grey rattle can primer, and as grey is a pretty neutral colour I figured it would be a good base for any colour topcoat..
        Personally I think that Hull Red is just more brown than red.
        I will have to re-prime the model by the looks of it, and then find a suitable red.
        Your input is appreciated though.
        • boatman
          • Nov 2018
          • 14498
          • christopher
          • NORFOLK UK
          #244
          HI Garry well i just use red car primer on my hulls an it dont look far out in a big rattle can spray about 4 coats pic of my hull below Click image for larger version
ID:	1192348Click image for larger version
          • boatman
            • Nov 2018
            • 14498
            • christopher
            • NORFOLK UK
            #245
            HOPE these pics help you Garry an when sprayed with the car red primer i then spray it over with a clear laquer car spray to harden the paint finish
            chrisb ps dint think but here are some shots of my type 23 norfolk done in the same couloure an its holts auto spray paint red primer rattle can sorry pics not very good Garry
            chrisb
ID:	1192350Click image for larger version
            • boatman
              • Nov 2018
              • 14498
              • christopher
              • NORFOLK UK
              #246
              HI again Garry before you spray any differnt paints over this valejo try the new paint on a littlle area which cant be seen as the rattle can paint may attack your old paint an cause it to craze as ive had this happen when you swop to differnt paints
              chrisb
              • Tworrs
                • Jan 2022
                • 1982
                • Garry
                • New Zealand
                #247
                Great advice there Chris, thank you.
                  • 18932
                  I’ve had sprayed red top coats go purple over a grey primer Garry :sleeping2: Since then I always underpaint in a red shade before putting on the topcoat. Even when brush painting small areas I always underpaint in Vallejo cavalry brown (a very red shade of brown) to improve coverage. The only Vallejo model colour red I have that doesn’t do this is Amaranthe red.
                  • Tworrs
                    • Jan 2022
                    • 1982
                    • Garry
                    • New Zealand
                    #249
                    Thanks for the warning Tim.
                    • Mark1
                      • Apr 2021
                      • 4156
                      #250
                      Ive just painted my lifeboat with mr hobby aqueous red gloss h327 over grey primer,covers well and is a proper red Click image for larger version
                      • Tworrs
                        • Jan 2022
                        • 1982
                        • Garry
                        • New Zealand
                        #251
                        I took the paint on the hull back to light grey, then applied a rattle can primer, sort of a red oxide, which is the colour I was looking for.
                        Thanks to everyone for the suggestions and advice.
                          • 22771
                          #252
                          Looking good
                            • 18271
                            As odd as it sounds Cavalry Brown is a better colour than Hull Red. Another idea could be Vallejo's Red Primer, which can be had in large bottles. A couple of coats clear once cured and she'll be fine. As an aside Vallejo Acrylics are 100% water fast once cured/hardened. Several I know that only build RC Boats use them with no problems at all. (My only dislike for them on large ship models is the size of the bottles! )
                            • boatman
                              • Nov 2018
                              • 14498
                              • christopher
                              • NORFOLK UK
                              #254
                              AH Garry thats more like it red primer is spot on as have you sprayed the grey sides yet an an if you have now for that fun bit the black water line as if its like on your ship like mine the whatch out as that water line is bigger at the bow end than the stern an i used tisue paper to get it right but it was a bugger all the same as the black water line is dead straight along the bottom but not the top as it curves up at the bow an my swear box was full after doin this but she comin on great very well done
                              ATB
                              Chrisb
                                • 18932
                                Looking good Garry, glad it’s sorted out :thumb2:
