This just gets better and better. A really fine job Garry. Love the helicopter.
1/72 HMS Iron Duke - Type 23 Frigate
Thanks Paul, every added bit livens things up a bit.
Don't get cocky now Steve.Strength isn't about what you can do, rather it's about overcoming what you thought you couldn't do.Comment
Well, I'm al caught up. (3 Hours). Well worth the time reading it all. Superb build. Excellent likeness. I can almost smell the grey paint!!!!
There was mention of a something about elephants ass or sonar unit. It is actually a towed array for long range detection of underwater contacts. Probably retro fitted during an upgrade dockyard refit. Which means whe deployed the vessel would be veeerrrrrry Sloooooow!
Digressing. Yup, agree with everyone. Brilliant job - more so considering you hadn't had a crack previously!! As they say in the RN. BZ (Bravo Zulu - well done!)Comment
Steve!Comment
chrisbComment
VMT
GarryStrength isn't about what you can do, rather it's about overcoming what you thought you couldn't do.Comment
VMT (I picked this abbreviation up from a Commander that I worked with, which I assume must be common in the RN)
Just had a look at the upgrade programme. The ‘Duke’ class were designed to be all fitted with sonar 2087, (towed array), however, at the mid life upgrade it was decided the last 5 would not install towed array. Iron Duke being one of the last five!!Comment
chrisbComment
Just had a look through again Garry , a build of a life time . So much time, skill and effort has gone into this.
Of course love the use of ply and the foam board, beautifully made with those intricate angles.The electrics are beyond me to comment!
As an aside Matron does take to the air but not as Chris thinks by broom ( she will have "words " with you Chris I hear ) but flies first class so can arrive much quicker than your parcels !
Great work and thoroughly enjoyable following .Comment
