HMS Amagenon, a mojo buster, i hope!
    This coming from a man that said his PE building was terrible !
    Bob If I could do PE as half as good I'd be happy .:smiling3:
      • 18958
      Looking very good Bob. Here’s info on the night lifebouy…..
      • boatman
        • Nov 2018
        • 14498
        • christopher
        • NORFOLK UK
        #138
        VERY TRUE John Bob must be happy with his work on p/e or his mojo will take a dive so Bob be confident as you are a good moddeller
        chrisb
        • BattleshipBob
          • 6821
          • Bob
          • Cardiff
          #139
          Originally posted by boatman
          NOTHING up with that p/e Bob as that p/e ladder looks very good well done you are winning now keep up the good work brilliant work my freind when are we gonna see some paint on her ? an ive been doin an fitting the main railings on my tiger done quite a bit on her an mine was brass work very hard work on the ole eye balls
          chrisb
          Thanks Chris, as I said Chris room for improvement, but getting better. Not ready for primer, trying to avoid painting bits then finding more to do, so trying to do it all in one painting session!
          Originally posted by adt70hk
          Very good indeed Bob! A very nice PE attack!
          Thanks Andrew, still working thanks to you!!
          PE still fun though!
          Thanks Tim, also for the nightbouy info, very interesting. Wonder how many kits have these. Thought they were a pre dreadnought thing!
          • BattleshipBob
            • 6821
            • Bob
            • Cardiff
            #140
            Many thanks John, getting there but still making mistakes, like sticking tweezers to the pe lol
            • Airborne01
              • Mar 2021
              • 4038
              • Steve
              • Essex
              #141
              And I bet he was charged for being naked on duty, oh ere misses
              Improperly dressed - put him front of the Old Man Master at Arms!!
              • BattleshipBob
                • 6821
                • Bob
                • Cardiff
                #142
                Finished to the main mast but leaving the yards ( correct name?? ) Until ready to prime, incase I knock the buggers off! Bit more complex this time. Railings to add on the searchlight platform
ID:	1194867Click image for larger version
ID:	1194868Click image for larger version
ID:	1194869Click image for larger version
                Need more practice with the railings next time, one side is slightly longer than the other side, nuts!!
                Otherwise I think I am finally getting there with PE, feel more confident, until the more complex bits lol. Will have to spray at low pressure just incase I blow the pe off!!
                • boatman
                  • Nov 2018
                  • 14498
                  • christopher
                  • NORFOLK UK
                  #143
                  WELL done Bob MATEY that p/e is lookin good see you can do it
                  chrisb
                  • Mark1
                    • Apr 2021
                    • 4156
                    #144
                    Dont stress over a gnats c@#k Bob your pe work is MORE than acceptable keep up the good work.
                      • 18958
                      Looks excellent Bob, very competently handled build. PE holds no more terrors….
                      • BattleshipBob
                        • 6821
                        • Bob
                        • Cardiff
                        #146
                        chrisb
                        Cheers Chris, better, ship by shop!!
                        Thanks Mark, appreciated!
                        Thank you Tim, not so sure about the terrors, the Big Ed set for the Bismarck is getting me shaking already lol
                        • adt70hk
                          • Sep 2019
                          • 10444
                          #147
                          Well done Bob..... Very well done indeed!
                          • BattleshipBob
                            • 6821
                            • Bob
                            • Cardiff
                            #148
                            Many thanks Andrew, bit by bit lol
                              The night buoy from what ive read is fitted with a calcium light ,a lid is unscrewed when put in the water, the water ignites the light which burn for about 30 mins.
                              The modern equivalent is the plastic life ring fitted with high intensity strobe lights, that are activated by seawater. They're usually on the bridge level, on either side & have a quick release for dropping. All very well, but someone had to see you go over! In the MN, you often went on deck by yourself, at night, and you wouldn't be missed for quite a while - not a pleasant thought!
                              • BattleshipBob
                                • 6821
                                • Bob
                                • Cardiff
                                #150
                                Almost ready for primer, my god how many ships boats were needed! Took a few hrs, finally got round to being organised. Used my new IKEA storage pots, 3 for £1.50!
                                The numbers on the bits of paper are the boats location on the ship according to the plans, next how on earth to paint them AND what bl**dy colours. Why do they not follow Tamiya and use call out no's on the plans, not a clue listed. Are they white with red bums, wood decks, or like the ship dark sea grey??? I assume white?
                                Added the anchors, rudder and night floats. Leaving off props. The superstructure is going to be a pain as it has to painted in sections, aarghh
                                My biggest mistake, should have fitted the torpedo net booms LAST, one broken by me. One to remember
ID:	1194937Click image for larger version
ID:	1194938Click image for larger version
                                By strange coincidence a new book on British battlecruisers arrived and in a wallet in the inside of the rear hardcover were plans for my favourite battlecruiser, Queen Mary and yes a night float
