HMS Amagenon, a mojo buster, i hope!
    • 15817
    Had a fine time adding the Admirals walk. Not too happy, too many Ca marks.
    Looks fine to me.
    • BattleshipBob
      • 6821
      • Bob
      • Cardiff
      #107
      The admiral would be proud to walk on that Bob. Nice one.
      Thank you Tim, just hope he's not a fat ba****d lol
      Originally posted by adt70hk
      Bob
      Coming on nicely, although I can't help noticing the middle picture is a bit blurry! Not having phone problems again?!?!? :smiling5:
      Seriously though that really is looking very good indeed.
      ATB
      Do not panic Andrew it's my usual c*** photography lol
      Originally posted by Bri62
      Nice one Bob looks great mate
      Brian
      Thank Brian
      Originally posted by Mark1
      Looks good Bob
      Cheers Mark
      Originally posted by Jim R
      Looks fine to me.
      Do not look to close lol, thanks Jim
        • 18272
        Looks good Bob. Two possible fixes
        For them CA splatter things (that I can't see by the way) small flat marks a glassfibre pencil can take care of those. Another good tool to have is
        A bottle of de-bonder and not just for unsticking fingers. A small flat brush xan be used to wash unwanted ca off.
        • BattleshipBob
          • 6821
          • Bob
          • Cardiff
          #109
          Thanks for the tip Ian, will give that a go. Usuall use a very fine sanding stick
          • adt70hk
            • Sep 2019
            • 10440
            #110
            Can only second the de-bonder.... Seen it used many times and used it a couple of times myself!
              Yes Bob the debonder is great, I use it on a cotton bud and dab it on the area . Like Andrew I've also used it to unstick my finger ( No laughing at the back ) from the cutting mat !
              That pe looks very smart , certainly brings it to life .
              • adt70hk
                • Sep 2019
                • 10440
                #112
                Ok, so user error..... Not much I can do about that!!
                • boatman
                  • Nov 2018
                  • 14498
                  • christopher
                  • NORFOLK UK
                  #113
                  AS the guys say Bob mate nothing wrong with your work in fact there is everything right very well done an as for c/a marks well i cant see any
                  chrisb
                  • The Smythe Meister
                    • Jan 2019
                    • 6248
                    #114
                    Some mighty fine braille work there Bobster.....
                    ..... Looks excellent
                      Hello Bob,
                      Just caught up on your build. I use an old scalpel blade to run c/a around the joins, first I touch a bit to hold the etch and if happy then get to work running the c/a into the joint. Clean up is with my own sanders made from thick plasticard, double sided tape and wet'n'dry of choice... Hope this helps... Mike.
                      • BattleshipBob
                        • 6821
                        • Bob
                        • Cardiff
                        #116
                        Never used it but will now lol
                        Cheers John, still a big learning curve
                        chrisb
                        Thanks Chris, still room for improvement
                        ..... Looks excellent :smiling3:
                        Cheers Andy
                        Hello Bob,
                        Good tips there, appreciated
                        Bob
                        • adt70hk
                          • Sep 2019
                          • 10440
                          #117
                          Cheers Andy
                          Bob
                          I think I've seen Night Shift use it
                          • BattleshipBob
                            • 6821
                            • Bob
                            • Cardiff
                            #118
                            Right, bit more pe, made two of these, happy with these simple constructions
                            There are folded to make a box type structure and are mounted on both sides of the rear hull by the Admirals walk. Inside you fit what looks like 4 balloons tide together. Been racking my tiny brain as to what it's for. I assume a rope or chain could be pulled to open the bottom of the cage and release it, but what is it??
                            Early life raft, form of paravine? I have the set of Burt's excellent battleship books and no mention of it and nothing on the drawings??
                            However found this picture, this is a screenshot of Amagemenon
Name:	Screenshot_20230217_143714_Samsung Internet.jpg
                            Looks more like a cross with floats at each end??
                            • boatman
                              • Nov 2018
                              • 14498
                              • christopher
                              • NORFOLK UK
                              #119
                              [ATTACH]474498[/ATTACH]
                              [ATTACH]474499[/ATTACH]
                              Bob mate i think they are marker bouys nice work b t w
                              chrisb
                                • 18958
                                Could be something to do with hanging or recovering the anti torpedo nets Bob? Have you got any rear shots of the ship with the nets deployed?
