Brian's actual 1/200 Yamato build
  • Bri62
    • Jan 2023
    • 1879
    • Brian
    • Widnes Cheshire
    #301
    Originally posted by Ian M
    Is it the walkway on the flight launch deck, the strip two squares wide?
    Yes Ian
    • Bri62
      • Jan 2023
      • 1879
      • Brian
      • Widnes Cheshire
      #302
      Originally posted by Mark1
      Cant get in there with a brush?
      I could but I could also screw it up or knock something off and break it not worth it imo
      Brian
        • 18901
        Brian
        Well, we wouldn’t have known if you hadn’t told us Brian, so I’m sure it can be left alone…….
        • Bri62
          • Jan 2023
          • 1879
          • Brian
          • Widnes Cheshire
          #304
          I have decided to do it, thing is do I mask and airbrush or paint by hand ?
          Brian
            • 18901
            Brian
            Personally, for something that small I would mask and go with a brush, but only if you think your brush skills are up to it….and if you can get proper access with the brush.
            • Bri62
              • Jan 2023
              • 1879
              • Brian
              • Widnes Cheshire
              #306
              Done one side looks ok, I'll post a pic when it's done
              Brian
                • 22770
                #307
                Just caught up again Brian, more outstanding work going on. A very impressive build.
                • Bri62
                  • Jan 2023
                  • 1879
                  • Brian
                  • Widnes Cheshire
                  #308
ID:	1197281Click image for larger version
                  Brian
                  • Bri62
                    • Jan 2023
                    • 1879
                    • Brian
                    • Widnes Cheshire
                    #309
                    Cheers Ian
                      • 18901
                      Nice save Brian. Definitely worth doing.
                      • Bri62
                        • Jan 2023
                        • 1879
                        • Brian
                        • Widnes Cheshire
                        #311
                        Up early this morning :smiling3:
ID:	1197299Click image for larger version
ID:	1197300Click image for larger version
                        She looks a bit shiny once the weathering is done I'll matt clear coat
                        Brian
                        • Bri62
                          • Jan 2023
                          • 1879
                          • Brian
                          • Widnes Cheshire
                          #312
                          All finished apart from the rigging but that's for when I'm in the mood for it, was an interesting build not as straight forward as I thought it might be.
ID:	1197310Click image for larger version
ID:	1197311Click image for larger version
ID:	1197312Click image for larger version
ID:	1197313Click image for larger version
ID:	1197314Click image for larger version
ID:	1197315Click image for larger version
ID:	1197316Click image for larger version
                          What to do next? 1/72 Millennium Falcon 1/200 HMS Hood 1/350 HMS Dreadnaught? help needed
                          Brian
                          • scottie3158
                            • 14201
                            • Holbeach
                            #313
                            Brian,
                            I have just had a good catch up. The work you have put in to this build is outstanding you should be well chuffed with the results so far.
                            • Mark1
                              • Apr 2021
                              • 4156
                              #314
                              Very nice Brian excellent job :thumb2:
                              As for what's next, id like to see you have a crack at the dreadnought
                              • Bri62
                                • Jan 2023
                                • 1879
                                • Brian
                                • Widnes Cheshire
                                #315
                                Got a couple of acrylic stands coming and a sheet for the front.
ID:	1197332Click image for larger version
                                Brian
