Brian's actual 1/200 Yamato build
  • Bri62
    • Jan 2023
    • 1881
    • Brian
    • Widnes Cheshire
    #61
    A bit more progress for you :smiling3:
ID:	1194404Click image for larger version
ID:	1194405Click image for larger version
Name:	IMG20230215090828 - Copy.jpg
ID:	1194406Click image for larger version
Name:	IMG20230215090836 - Copy.jpg
ID:	1194407Click image for larger version
Name:	IMG20230215094346 - Copy.jpg
ID:	1194408Click image for larger version
ID:	1194409Click image for larger version
    The correct shape rudders just arrived
    Brian
    • Neil Merryweather
      • Dec 2018
      • 5185
      • London
      #62
      they look like fun....
      • Bri62
        • Jan 2023
        • 1881
        • Brian
        • Widnes Cheshire
        #63
        Done for the day also won't touch the hull again for some time .....on to the superstructure (tomorrow)
ID:	1194414Click image for larger version
ID:	1194415Click image for larger version
ID:	1194416Click image for larger version
        Thinking about weathering the deck and I found out the Japanese didn't use teak they used Japanese cypress which when weathered turns a pale grey you think I could make my own wash ?
        I have actually ordered this It will need thinning out quite a lot
        Brian
        • spanner570
          • 15401
          #64
          Excellent work, Brian.
          Weathered and scrubbed teak also turned a pale grey in time (perhaps with a hint of yellow), so you are on a 'Win, win'.
          Away to go with your own wash. Just keep it pale to start with. If you go too dark first off, that's it. Game over!
          Keep in mind, a second coat of the first shade will be naturally a bit darker once applied to the first. I hope that makes sense! :upside:
          Try on a bit of scrap deck....
          Ron
          • boatman
            • Nov 2018
            • 14463
            • christopher
            • NORFOLK UK
            #65
            HI Bri them hose reels look very fiddley to build but you have done it good man an the hull looks fab just dont overdo it as 570 says
            chrisb
              • 18269
              Think we have our wires crossed Brian. I ment the large double doors of the hangar deck. as seen in this ;
              On the photo from the book you can also see that the doors open aft. as you had them on this photo:
              Nice rudder, where did you find that?
              • adt70hk
                • Sep 2019
                • 10409
                #67
                Brian,
                That's coming on beautifully. Great work so far.
                ATB.
                  • 18269
                  How do the original rudders compare to those lovely new ones?
                    • 15692
                    Ron's right. You can always darken the deck with more of the same but go too dark initially and it's difficult to correct.
                    • Mark1
                      • Apr 2021
                      • 4156
                      #70
                      The decks were painted black in 1945 so if you go to dark theres always another option .
                      • Bri62
                        • Jan 2023
                        • 1881
                        • Brian
                        • Widnes Cheshire
                        #71
                        The original rudder are the wrong shape and way to thick that's why I ordered these from model monkey in the states ....not cheap though $19 and the same postage, as for the hanger doors as I said I feel with them opening outwards there will not be enough clearance for the plane to fit in the well.
                        Just my take on it :smiling3:
                        Brian
                        • Bri62
                          • Jan 2023
                          • 1881
                          • Brian
                          • Widnes Cheshire
                          #72
                          Really! that would make the whole model too dark I think, but like you say always an option
                          Brian
                          • Bri62
                            • Jan 2023
                            • 1881
                            • Brian
                            • Widnes Cheshire
                            #73
                            Thank you Andrew :smiling3:
                            Brian
                            • Bri62
                              • Jan 2023
                              • 1881
                              • Brian
                              • Widnes Cheshire
                              #74
                              they were m8
                              Brian
                              • Bri62
                                • Jan 2023
                                • 1881
                                • Brian
                                • Widnes Cheshire
                                #75
                                Did a bit more this morning
ID:	1194465Click image for larger version
ID:	1194466Click image for larger version
ID:	1194468Click image for larger version
ID:	1194469Click image for larger version
ID:	1194470Click image for larger version
ID:	1194471Click image for larger version
ID:	1194472Click image for larger version
                                Not even going to bother with that small PE it's less than 0.5mm
ID:	1194474Click image for larger version
Name:	IMG20230216122115 - Copy.jpg
                                Why they didn't mould the bottom like the top I don't get, prob just to pi55 me off
                                Brian
