Hms Cornwall 1/350
    • 18944
    Looking very fine Mark. Nice to see a cruiser on the go as well.
    • BattleshipBob
      • 6820
      • Bob
      • Cardiff
      #17
      Good job mark, on the Tashkent I added the railings last after painting. I assume the superstructure decks are the same colour as the sides?
      • Mark1
        • Apr 2021
        • 4156
        #18
        Ive decided im going to try and add as much of the railings as i can before painting as i would do them after and end up with chipped railings and ca everywhere. If i paint the tops a different colour it will be after the sides and ill just spend some time carefully masking. The instuctions would have me paint the all the top surfaces including decks in dark sea grey,from what ive read online a lot of people suggest this is wrong and if its not im painting the wood decks tan anyway.Click image for larger version
        • Mark1
          • Apr 2021
          • 4156
          #19
          Ive got some deck tan on, this will get a coat of clear then washed and weathered before being sealed and masked for the rest of the hull painting. The deck doesn'look quite so yellow just my rubbish picture taking.
          A couple of structures in colour, again a coat of clear then washed and weathered before fitting to the deck.Click image for larger version
ID:	1194757Click image for larger version
ID:	1194758Click image for larger version
          • Bri62
            • Jan 2023
            • 1900
            • Brian
            • Widnes Cheshire
            #20
            It's a shame when you have to cover all that lovely PE with paint looking good though!!
            Brian
              • 15799
              Excellent PE work Mark. Working out and adjusting the uprights on PE railings is always difficult. Looks as if yours are sorted.
                • 18272
                Looking very good Mark.
                I see you have learnt very quickly the "start at the end of the rails that have the most bends in or the fitted lengths" lol. I learnt this trick AFTER I tried gluing railings to a painted deck. Did not end to bad. Jut had to start again and repaint the deck.
                • Mark1
                  • Apr 2021
                  • 4156
                  #23
                  Brian
                  Thanks Brian at least when the paints on you know its one less bit of pe to worry about.
                  • Mark1
                    • Apr 2021
                    • 4156
                    #24
                    Thanks Jim
                    Thanks Ian, should have been a perfect fit think trumpeter got their measurements wrong,that was the only place i could cut and join,if i folded that end first and cut down the other end i would have been half way between the uprights
                    • BigGrandad
                      • Nov 2022
                      • 155
                      #25
                      Hi Mark
                      i’ve always done ’paint first PE after’ where railings are concerned. Having seen the fit you’ve achieved (despite the obligatory mistake on a long run) I think I will try this approach on my next build. Looking good.
                      • BigGrandad
                        • Nov 2022
                        • 155
                        #26
                        Didn’t mean your mistake. Meant that the PE always throws up a wrong fit somewhere.
                        • Mark1
                          • Apr 2021
                          • 4156
                          #27
                          Originally posted by BigGrandad
                          Hi Mark
                          Cheers,Ive usually done it after painting but i always drop it out the tweezers and end up with a blob of ca somewhere i dont want it,there will be some parts that will have to be fitted after painting but after watching some u tube vids of people doing it this way thought i would give it a try.
                          • BattleshipBob
                            • 6820
                            • Bob
                            • Cardiff
                            #28
                            Superb railings, I sure have catching up to do. Lovely build so far!!
                            • Mark1
                              • Apr 2021
                              • 4156
                              #29
                              Cheers Bob :thumb2:
                              • Mark1
                                • Apr 2021
                                • 4156
                                #30
                                So i got a bit more done,a bit more etch ,not perfect but itll look ok with a coat of paint and put a first wash on the main deck using oils ,first time ive used oils and liked them from the first time the brush touched the deck :smiling: needless to say i need some practise with them, dosnt show up well in the picture but looking ok so far.Click image for larger version
ID:	1195030Click image for larger version
ID:	1195031Click image for larger version
ID:	1195032Click image for larger version
