1/250 USS St Louis ( CL-20 ) my first 3D printed model
    USS St Louis was a protected cruiser, built at the time when the US Navy was expanding. Commissioned in 1907, she was obsolete almost before she was finished
Name:	St Louis C-20.jpg
    The model is from 'World of Warships', and hosted on the Printables website of Josef Prusa. The model is free to download, for private & non-profit use.
    The model is scaled at 1/150 which would make it 860mm long. The hull is in 5 sections, my printer could handle this, but the printing times would be very long, something like 17-18 hours! I decided to scale it down to 1/250 - this gives a hull length of 520 mm - each section takes from 10-12 hours to print. ( I've been hoping that we don't have any power cuts )
    The first two sections - they're printed in the vertical position & don;t need much in the way of supports. After printing the bows, I reduced the infill ratio from 25 to 18%, this reduced the printing time, used less filament & weighed less!
    The instructions are in the form of a 21 page .pdf file - nicely illustrated
    The hull is joined by connectors that have wings, which spring out into slots internally - which can't be test fitted, as it's strictly a one-way operation. I'll use 2-part epoxy adhesive, as it needs a very strong bond between the parts. It will weigh quite a bit & I don't want the thing to come apart. I'll need to print out the stand. Most of the construction will be with CA, although I will use epoxy on the bigger parts, like the funnels. There are a load of small parts that need to be printed out, which will probably take more hours than the hull sections.
    I don't think the model will take a complete 1kg spool of PLA filament, but as this only costs around £12 a spool that's not a lot - the time factor is not something you cannot ignore, it's going to be quite a marathon! After the hull sections are done, I'm going to do a bit of maintenance & tlc on the printer......................
  • JR
    • May 2015
    • 18273
    This will be an interesting venture to follow , good luck Dave .
    • Neil Merryweather
      • Dec 2018
      • 5189
      • London
      Ooh Dave,yes!
        The final hull section printed - I was uncertain whether this would print without supports for the propeller shafts & support brackets.....................
ID:	1197329Click image for larger version
        No problems - I'm printing off the stand at the moment.
        There are a large number of small parts to be printed out - but I may have some news about that!
          All five parts together
          They all line up pretty well, apart from the bow section, the first that I printed. I might be able to correct it by some heavy sanding on the joint face, but otherwise, I'll just have to print off another.
          These are the connectors that join the hull sections together.............................
          Printed in draft mode, they're functional & never will see the light of day again when used.
          I'm now waiting for some epoxy glue, I found that my existing tubes were not good - so I've ordered some - I could use CA, but the jointing areas are so large that you'd need a tube for each joint & with epoxy there's plenty of wiggle time to get everything flush.
          An idea struck me last night, that I might not need to use any putty on the joints - I have the 3D pen & using the same filament could fill any gaps - that's certainly something I will be experimenting with
            Had to bite the bullet & print off another bow section
            Too much work to correct the old bit! This gives me an opportunity to experiment with the 3D pen on an actual printed part - I was doodling with this yesterday & wondered if it were possible to produce a welded seam such as that on a tank. It may be possible, but you'd have to have a very steady hand. The main thing is making good the joints between the hull halves - if I use the same filament in the 3D pen, then hopefully I can get a good surface, without hours of sanding ( I hope )
              • 15698
              Very good Dave and really interesting.
                In case anyone was wondering about the work needed to correct the poor part. It's a large area that needs to be sanded back - no problem with that, BUT PLA has a low melting point, and using anything like a power sander results in the surface melting & burning & scabbing! You can sand it manually ( sanding sticks & files etc ), as you don't generate enough heat to cause problems, OK in comparatively small areas, but not in large flat areas!
                • Neil Merryweather
                  • Dec 2018
                  • 5189
                  • London
                  That should work well Dave
                  • wotan
                    • May 2018
                    • 1150
                    When using the 3D pen, I have found that you can smooth the surface by using a soldering iron with a large flat head on it. Running this down a rough seam line might be an easy answer.
                    • wotan
                      • May 2018
                      • 1150
                      This is far from ideal but this was made entirely with 3D pen and smoothed with a soldering iron.
                        I have a pyrogravure somewhere - that has a number of swappable heads with various shapes that would work - now all I have to do is find it! - I haven't used it for many years.....................
                          My epoxy glue arrived in the post, so I've bonded together all the sections
                          IF - I was going to do this again ( unlikely ) I wouldn't use the bayonet connectors - they're actually too tight a fit- which you only find out when you actually come to assemble it! With the epoxy glue having a few minutes working time you have difficulty in getting the parts together, and are unable to wiggle them for a best fit!, and of course the bayonet fittings mean that you can't get it apart......... The ends were pretty closely matched together, but the connectors were just too tight to allow for any adjustment. I think the 3D Pen will be getting a bit of use in the next few days. The St Louis didn't have much superstructure - but of course the 4 funnels are prominent. Funnels 2 & 3 are the same, but 1 & 4 are both different. They have a grating at the top, and I'm hoping that the printer can cope
                            I'll be working on the hull joints - but the printer will be making the bits for this stage..................
                            How small 'tiny' is remains to be seen!
                            yay! - I found my pyrogravure!
                            • adt70hk
                              • Sep 2019
                              • 10409
                              Interesting Dave. Do you have any idea how much the filament first for a job this size?
