1/350 Jaureguiberry French pre-dreadnought
    I had started building the USS St Louis in 1/250, but this has proved to be a bit too much, too soon.
    The Jaureghiberry was a French battleship, commissioned in 1897. The French Navy was experimenting with their ships & this often resulted in bizarre, if not downright ugly ships
ID:	1198562Click image for larger version
    She suffered from poor stability & the mix of heavy guns made fire control difficult. She served in WWI, and in 1919 became an accommodation ship, being finally scrapped in 1934.
    The model is from Thingiverse, supplied in 1/700 scale by 'PC_Model_Yard ' I've scaled it up to 1/350, and have printed most of the bits out - dry fitted together.............
    As you can see I've had filament changes - most parts were done on the Anet A5 printer, the turrets on the Monoprice Mini V2. The hul halves took about 6 hours to print out each. I've still to successfully print the cranes, I've had several failures, but they'd be easy enough to scratchbuild, but the latet attempt is looking good.
    It's only a small model, and the material cost I reckon will be <£5. The time taken to print out the bits will be longer than the assembly. It will be glued with CA. There aren't any boats in the files, but Thingiverse has a folder with loads of styles of ships' boats that will be scaled to suit. I do have 1/350 PE railings - I'll see how assembly goes before committing to those!
    The dry assembled primed bits - and it does look a lot better than all the multi-coloured raw printed parts!
ID:	1198677Click image for larger version
ID:	1198678Click image for larger version
    The ship had various colour schemes. Black hull & buff superstructure, black hull & mid grey superstructure, and all over light grey, this is purely from looking at images - whether B & W photos, art work, or colorised photos - of course no colour photos at that time. The French Navy is not really well documented ( at least in English ), so there will be a measure of guesswork........
    • stillp
      • 8093
      • Pete
      • Rugby
      Looks a lot better being the same colour all over.
        Originally posted by stillp
        lot better
        'better' being a relative term - it's hardly a thing of beauty!
          • 15698
          These turn of the century battleships certainly have a brutish, beauty about them. This certainly could never be described as graceful.
          The model definitely looks better now all a uniform colour.
            After numerous attempts to print these boat cranes - this is the best I can squeeze out of the printers. I tried combinations of orientations, speed etc, and no more!
ID:	1198721 I will probably end up replacing them with plastic rod........................
              It didn't last long! I've started painting the deck, and then need to paint parts of the superstructure, before adding the boat racks...............
                An hour or so of paint therapy....................
ID:	1198729Click image for larger version
                I'll need to carefully mask, before I can add the black to the lower hull. Colours: Deck - Old Wood, Superstructure - Buff, both Vallejo Model Color
                  The masking was a bit of a pig, but after several touch ups, I'm happy
                  I'm going to have to fit the forward two twin turrets next, as you can't squeeze them in when the forward superstructure is fitted - I'm going to have to consider how many boats will be fitted - quite a lot!
                    All the major parts are added................
ID:	1198838Click image for larger version
                    You may note that one of the twin turrets is missing - I dropped it & put my size 11 on it! I can print another out, when I'm doing the boats - no problems with spare parts!
