Brian's 1/350 1918 Dreadnaught build
  • Bri62
    • Jan 2023
    • 1883
    • Brian
    • Widnes Cheshire
    Afternoon chaps
ID:	1198923Click image for larger version
    Starting the above build today made a slow start drilling out the 100 or so portholes
ID:	1198925Click image for larger version
    Going to try and take my time over this one, it's a bit smaller than what I'm used to.
  • Mark1
    • Apr 2021
    • 4156
    Ill follow along.My fingers been hovering over the buy it now button with this one for a while so interested to see how it goes together.
    • scottie3158
      • 14201
      • Holbeach
      I will follow along if I may.
      • Bri62
        • Jan 2023
        • 1883
        • Brian
        • Widnes Cheshire
        All welcome
        • Bri62
          • Jan 2023
          • 1883
          • Brian
          • Widnes Cheshire
          It went together pretty good just used a bit of dissolved putty to make the join invisible
ID:	1198933Click image for larger version
          • Bri62
            • Jan 2023
            • 1883
            • Brian
            • Widnes Cheshire
            Hull went together nice and a bit of sanding finished it off
              • 15699
              Following with interest Brian. Love these turn of the century monsters.
                I've the Trumpy 1907 Dreadnought in the stash, but as is my habit, I'll be waterlining it - not easy, as all the cross bulkheads will need cutting as well - I did consider buying metal barrels, but I found the kit parts were just as good!
                  • 18907
                  Interested to see this come together……love the WW1 early battlewagons, and this one is the daddy of them all.
                  • JR
                    • May 2015
                    • 18273
                    Brian I'm in as well,not really a floaty but Chris got me interested. Looks impressive.
                    • Bri62
                      • Jan 2023
                      • 1883
                      • Brian
                      • Widnes Cheshire
                      Great to have you along Jim
                      Good luck with yours Dave I'm still a beginner at these so out of the box it is
                      Tim, John your most welcome
                      • Bri62
                        • Jan 2023
                        • 1883
                        • Brian
                        • Widnes Cheshire
                        A bit disappointed with the kit there is only railings for 01 deck and not the main deck, but as you can clearly see from the box art there is railings on the main deck :unamused:
ID:	1198994Click image for larger version
                        The instructions say no railings but box art says railings I have ordered some 1/350 royal navy Eduard railings
                          [ATTACH=CONFIG]n1198994[/ATTACH][ATTACH=CONFIG]n1198995[/ATTACH]
                          I also have the Trumpeter 1/350 HMS Agamemnon in the stash & that has a complete set of railings! I did an inbox review of this https://www.scale-models.co.uk/threa...-review.40622/.
                          I source my 1/350 PE railings from Aliexpress https://www.aliexpress.com/item/1005...d=A34dsKoDpYBl - theyr'e generic railings, but are applicable to all ships! - Cost wise :thumb2:
                          • Bri62
                            • Jan 2023
                            • 1883
                            • Brian
                            • Widnes Cheshire
                            I source my 1/350 PE railings from Aliexpress https://www.aliexpress.com/item/100...3!sea!UK!133278962&curPageLogUid=A34dsKoDpYB l - theyr'e generic railings, but are applicable to all ships! - Cost wise :thumb2:
                            Thanks for that I have ordered some as spare
                            • BigGrandad
                              • Nov 2022
                              • 155
                              Hi Brian
                              i have the trumpeter 1907 version under way (but currently on the back burner), I have water-lined my version and am adding a fare bit of aftermarket product so going at it slowly. Will be watching your build with interest.
