Brian's 1/350 1918 Dreadnaught build
  • Bri62
    • Jan 2023
    • 1902
    • Brian
    • Widnes Cheshire
    #16
    Originally posted by BigGrandad
    Hi Brian
    i have the trumpeter 1907 version under way (but currently on the back burner), I have water-lined my version and am adding a fare bit of aftermarket product so going at it slowly. Will be watching your build with interest.
    Pull up a chair Graham, your 1907 version does it have railings for the main deck ?
    • BigGrandad
      • Nov 2022
      • 155
      #17
      I've the Trumpy 1907 Dreadnought in the stash, but as is my habit, I'll be waterlining it - not easy, as all the cross bulkheads will need cutting as well - I did consider buying metal barrels, but I found the kit parts were just as good!
      Hi Dave
      i am in the process of building the 1907 trumpeter kit< I have water lined my version
      hi Brian
      Not yet, but it will do!!!! Will send you a couple of pics of my build in itโ€™s current state.
      • BigGrandad
        • Nov 2022
        • 155
        #18
        Hi Brian
        My dreadnought in itโ€™s current state.
ID:	1199002Click image for larger version
ID:	1199003Click image for larger version
ID:	1199004Click image for larger version
ID:	1199005Click image for larger version
ID:	1199006Click image for larger version
        I have fitted a veneer deck, a word of warning if you are contemplating this, the โ€˜self adhesiveโ€™ backing only stays put for a few days!!! I had to carefully lift all of the decks and add multiple spots of cyanolite to make sure it stayed put!!!! Just found a few more spots that need attention now that it has been bought back out of storage.
        Itโ€™s going back on itโ€™s work frame now and I may do a bit more in the near future now that I have seen your thread.
        • BigGrandad
          • Nov 2022
          • 155
          #19
          Hi Dave
          i am building the 1907 version, water-lined.
          here is how I sorted it.Click image for larger version
          Might be a bit overkill but better that than a collapse further down the line!
          • Bri62
            • Jan 2023
            • 1902
            • Brian
            • Widnes Cheshire
            #20
            Both very nice indeed
            • Bri62
              • Jan 2023
              • 1902
              • Brian
              • Widnes Cheshire
              #21
              All premiered up.
                I've never had any problems with the veneer lifting - probably just lucky! I do clean the plastic with IPA before carefully applying the veneer, using a paint brush handle to press down firmly in the corners. I also varnish the deck after a couple of days - this seals the wood & you can remove any paint slips that happen subsequently..............
                • BigGrandad
                  • Nov 2022
                  • 155
                  #23
                  OK
                  That might be where I went wrong, the deck did get a coat of primer, and maybe a bit of the base colour, used colour coats for this so I thought it would be OK. I have varnished the veneer but after the original problems.
                  • Mickc1440
                    • 4786
                    #24
                    Like JR Iโ€™m not a ship builder but love watching what you guys do
                    • Bri62
                      • Jan 2023
                      • 1902
                      • Brian
                      • Widnes Cheshire
                      #25
ID:	1199014Click image for larger version
                      • Bri62
                        • Jan 2023
                        • 1902
                        • Brian
                        • Widnes Cheshire
                        #26
                        Had a bit of a mishap although I have/had a wooden deck I left my model room door open and the dog thought it was a chew ....... could have been worse he could of chowed down on my model, anyway I wanted to try to paint a deck.
                        • Mark1
                          • Apr 2021
                          • 4156
                          #27
                          Oh dear!!! Did he get a flying lesson down the garden lol
                          • Bri62
                            • Jan 2023
                            • 1902
                            • Brian
                            • Widnes Cheshire
                            #28
                            Nah ........my fault for leaving the door open he's only a young dog
                            • Bri62
                              • Jan 2023
                              • 1902
                              • Brian
                              • Widnes Cheshire
                              #29
                              Ordered a new deck but it's coming from Aus so will be a week/10 days but there is stuff I can do in the mean time
                              • Bri62
                                • Jan 2023
                                • 1902
                                • Brian
                                • Widnes Cheshire
                                #30
                                Need help I think I'm going mad parts F20 and F21 can't find them there is no F sprue or am I missing something
ID:	1199050Click image for larger version
ID:	1199051Click image for larger version
