Billings boats 1/144 RMS Titanic
  • Mickc1440
    • 4786
    #31
    Excellent work so far, very impressive model
    • peterairfix
      • Jul 2012
      • 11088
      #32
      Some more progress made
      The forward cargo hatch and breakwaters are fitted along with the three steam winches Click image for larger version
      • peterairfix
        • Jul 2012
        • 11088
        #33
        That's the fore deck finished for now I need to some smaller details but I will do that nearer the end of the build Click image for larger version
        Now I just need to find a flat place that is 6 feet long to start the main hull
          • 18272
          A bit of 26mm floor sheeting makes a good building board. Some times you can be lucky and find one that the T&G has been damaged for cheep. Or a cheep counter top that has had a knock on the front or top...
          • peterairfix
            • Jul 2012
            • 11088
            #35
            This afternoon I finally broke wood and started the Hull and I have found a suitable place to build it.
            So far I am up to frame 28.Click image for larger version
ID:	1203461Click image for larger version
ID:	1203462Click image for larger version
            • Neil Merryweather
              • Dec 2018
              • 5208
              • London
              #36
              I assume you've got a place to display it.....?
              • peterairfix
                • Jul 2012
                • 11088
                #37
                Once I have sold my trumpeter titanic I will have the space
                  • 18272
                  More importantly...Do you have a place to make food
                  • peterairfix
                    • Jul 2012
                    • 11088
                    #39
                    All frames are in place and I have started on the prop shafts.Click image for larger version
ID:	1203496Click image for larger version
ID:	1203497Click image for larger version
ID:	1203498Click image for larger version
ID:	1203499Click image for larger version
                    • peterairfix
                      • Jul 2012
                      • 11088
                      #40
                      Let's try this again.
                      I have started on the aft well deck Click image for larger version
                      • boatman
                        • Nov 2018
                        • 14498
                        • christopher
                        • NORFOLK UK
                        #41
                        HI Peter WHATS happening on this build ? an ive been lookin through your build an i see you have fitted the 2 outer prop shafts but what about the main centre shaft as i cant see how you will fit that in as on how far you have proggesed on buildin the hull ? but vey nice work so far
                        chrisb
                        • peterairfix
                          • Jul 2012
                          • 11088
                          #42
                          chrisb
                          She's in dry Dock at the moment
                          The centre prop fits like this
                          And I have been giving serious thought to making her radio controlled but there is issues with the centre prop as credible evidence has surfaced that titanic was fitted with a three bladed one and not four but until a picture surfaces we will never really know because all the pictures claiming to be titanics props are in fact Olympics
                          • boatman
                            • Nov 2018
                            • 14498
                            • christopher
                            • NORFOLK UK
                            #43
                            well Peter i cant help on info about wheather it was a 4 bladed prop or 3 bladed but every model ive seen of her had a 4 bladed prop in the cente but you could make her R/C an have just the 2 outer props workin as you have fitted in the proper prop shaft as they look like it to me so this ship really could sail all you would have to put up with is people sayin wheres the ceberg lol
                            chrisb ps though this would make a fanstaic model to see sailin on the water
                            • peterairfix
                              • Jul 2012
                              • 11088
                              #44
                              Finished planking the aft well deck and added the eyelets for the rigging Click image for larger version
ID:	1205588Click image for larger version
ID:	1205590Click image for larger version
                              • peterairfix
                                • Jul 2012
                                • 11088
                                #45
                                I have now turned my attention to the poop deck witch I planked and started B deck Click image for larger version
ID:	1205699Click image for larger version
ID:	1205700Click image for larger version
ID:	1205701Click image for larger version
