HMS Warspite back on the workbench
  • tigersteve
    • Jan 2018
    • 678
    #16
    Lovely detail....... Base is coming on too!
    • BigGrandad
      • Nov 2022
      • 155
      #17
      Missed a yard arm off!!!!!!! Really should look at the instructions!!!!!!Click image for larger version
      • BigGrandad
        • Nov 2022
        • 155
        #18
        Smothered the base with liquitex. Toooooo shiny, will use a satin varnish to see what that looks like. Some work on the ‘Walrus’ too.Click image for larger version
ID:	1207401Click image for larger version
        • BigGrandad
          • Nov 2022
          • 155
          #19
          Finished the bulk of the detail build now, just moving on to the rigging!!!!!!! Get this out of the way then it’s just finish the ships boats mount her on he base and finish the seascape. Want this one out of the way nowClick image for larger version
ID:	1207500Click image for larger version
ID:	1207501Click image for larger version
          • BigGrandad
            • Nov 2022
            • 155
            #20
            HELP PLEASE
            these just arrived from Black Cat, (1/350 figures for my Warspite), they look sooooo small and fragile.
            How do I get these off the fret without breaking them? Anyone had previous experience?
            How do I paint them!!!!!?
            Might have bitten off more than I can chew here!
            • Bri62
              • Jan 2023
              • 1902
              • Brian
              • Widnes Cheshire
              #21
              Hi all my previous 3d printed stuff just breaks off make sure you hold the whole figure before breaking as for painting all i can offer is get a real detailed brush
              • BigGrandad
                • Nov 2022
                • 155
                #22
                Yup, I think the ‘survival rate’ for these figures may be very low
                • BigGrandad
                  • Nov 2022
                  • 155
                  #23
                  Don’t know how clearly this pic shows the ‘Heath Robinson’ blobs of blue tack holding the various rigging threads out of the way.
                  no way you can let these strands lie loose, they just attract each other and turn into ‘thread spagetti’.Click image for larger version
                    Saw through the sprue underneath their feet with a fine-toothed modeller’s saw.
                    Before taking them from the sprue At least, I think I would paint their main colour before doing that, then paint details like faces when they’re loose.
                    • tigersteve
                      • Jan 2018
                      • 678
                      #25
                      How are you attaching the rigging? Spot of super glue or similar....
                      • BigGrandad
                        • Nov 2022
                        • 155
                        #26
                        Yup, I am using the VMS ‘XT Thin’ And using my home made applicator - an old darning needle (blunted) mounted in a piec of sprue.Click image for larger version
                        • BigGrandad
                          • Nov 2022
                          • 155
                          #27
                          Before taking them from the sprue :smiling3: At least, I think I would paint their main colour before doing that, then paint details like faces when they’re loose.
                          Gently snapped this one off with tweezers, don’t think that will work where there are more than the two location points.Click image for larger version
ID:	1207564Click image for larger version
                            It will work fine as long as the attachment points are weaker than the ankles slightly above them I wouldn’t try it with the sweepers, though, or the ones with supports under their hands.
                            • BigGrandad
                              • Nov 2022
                              • 155
                              #29
                              My thoughts exactly
                              • BigGrandad
                                • Nov 2022
                                • 155
                                #30
                                Right.
                                That’s all of the rigging I am prepared to mess about with, especially as I can’t seem to find 2 references that are the same!!!!
                                She is now going into the base permanently so that I can finish the sea and look at how I deal with the crane and Walrus.
                                Just some weathering work on ships boats, then they can go on as well. Oh, and then the figures!!!!!!!!Click image for larger version
