Brian's 1/200 HMS Hood
  • Bri62
    • Jan 2023
    • 1890
    • Brian
    • Widnes Cheshire
    #16
    This is going very slowly a lot of scraping a bit of filling and loads of sanding hope the degaussing cable is worth it
ID:	1207516Click image for larger version
ID:	1207517Click image for larger version
ID:	1207518Click image for larger version
ID:	1207519Click image for larger version
    • Bri62
      • Jan 2023
      • 1890
      • Brian
      • Widnes Cheshire
      #17
      One side done just got to drill out portholes and a bit a primer to show any imperfections only took 2 days lol
ID:	1207570Click image for larger version
      A bit scary cutting stuff off
      • tigersteve
        • Jan 2018
        • 678
        #18
        Should be done by Christmas then
        • Bri62
          • Jan 2023
          • 1890
          • Brian
          • Widnes Cheshire
          #19
          Bit more done, cleaned all the mouldings off the hull and fitted spars also done some primer and a bit of wet n dry
ID:	1207630Click image for larger version
          • scottie3158
            • 14216
            • Holbeach
            #20
            Chair pulled up.
            • Bri62
              • Jan 2023
              • 1890
              • Brian
              • Widnes Cheshire
              #21
              Some small progress
ID:	1207651Click image for larger version
ID:	1207652Click image for larger version
ID:	1207653Click image for larger version
              • Bri62
                • Jan 2023
                • 1890
                • Brian
                • Widnes Cheshire
                #22
                Thinking about paint atm and am undecided whether to use Tamiya lacquer paints or acrylic, anyone used both ? what's better, what's the difference
                Thanks
                • Bri62
                  • Jan 2023
                  • 1890
                  • Brian
                  • Widnes Cheshire
                  #23
                  Progress is slow P.E. is very delicate
ID:	1207710Click image for larger version
ID:	1207711Click image for larger version
ID:	1207712Click image for larger version
ID:	1207713Click image for larger version
ID:	1207716Click image for larger version
ID:	1207715Click image for larger version
                  Got some super thin CA on order should be here tomorrow
                  • Scratchbuilder
                    • Jul 2022
                    • 2689
                    #24
                    Originally posted by Jim R
                    An iconic ship. Looks like a great, long term build. Lots of aftermarket stuff. I'll enjoy seeing how you get on.
                    I have a 1/700 Hood in the stash. I bought a wood deck and a load of pe but now I'm afraid to start. Your build may encourage me to open the box.
                    Ditto Jim,
                    I have a 1/350 'Montrose' destroyer living in the shed (modelling annex)....
                    • Scratchbuilder
                      • Jul 2022
                      • 2689
                      #25
                      Chair pulled up and notebook at the ready...
                      • Bri62
                        • Jan 2023
                        • 1890
                        • Brian
                        • Widnes Cheshire
                        #26
                        Fitted the plate over the Houser and started the Port side, need a rest P.E. is mentally draining lol
ID:	1207747Click image for larger version
ID:	1207748Click image for larger version
ID:	1207749Click image for larger version
                          • 18271
                          Nicely done Sir.
                          • Bri62
                            • Jan 2023
                            • 1890
                            • Brian
                            • Widnes Cheshire
                            #28
                            went to start painting the hull and my airbrush air Vv has seized up stripped it down and nothing obvious apart from a tiny seal damaged, no air can get through so give up and ordered another.
                            anyway fishing today so back at it tomorrow :smiling3:
                            • Bri62
                              • Jan 2023
                              • 1890
                              • Brian
                              • Widnes Cheshire
                              #29
                              Finding it difficult to choose colours for the superstructure and hull bottom (grey) I would like to use Tamiya acrylic there Isn't a lot of info out there, Help appreciated
                              • peterairfix
                                • Jul 2012
                                • 11079
                                #30
                                I use tamiya acrylic for nearly all my painting very good needs a good stir I always thin mine just upto the bottom of the neck others may have a different take
