Tamiya 1/350 IJN Destroyer Kagero
  • BattleshipBob
    • 6791
    • Bob
    • Cardiff
    Yes I am still here!!
    With a lot on my mind I really need a hopefully quickish build to get the mojo up and running!
    Plan to hopefully do more IJN ships!
    So off evilbay Tamiya's lovely Kagero. Usual quality, not over the top and great instructions.
ID:	1211029Click image for larger version
ID:	1211030Click image for larger version
ID:	1211031Click image for larger version
    Not building as water line so lower and upper hull plus 3 X decks in place.
    However went for a coffee and glue had crept under the tape, bugger
    Have sanded but still more to do, not happy
    Regarding mum, cannot visit as her ward is closed due to a outbreak of sickness and the runs. Waiting for the hospital infection control team to allow it to open. Mum's had it and had not eaten for 3 days, so worried over this now
  • stillp
    • 8087
    • Pete
    • Rugby
    Sorry about your mum Bob. Kagero looks good so far.
    • boatman
      • Nov 2018
      • 14451
      • christopher
      • NORFOLK UK
      HI BOYO yes we are to sorry about your mum an hope she gets a bit better as i know she has her probs oh dear an yes jap destroyer looks good an your little boo boo hardley noticable so keep this build comin bob an nice to see you on here again
      chrisb
        • 18890
        Sorry about your mum Bob, but glad to see you posting something :thumb2:
          • 18264
          Sorry your still going through it mate! Hope that you mum is doing well.
          Not enough IJN ships in here, looking forward to this one.
          As for the glue boo boo, wet sanding and filler, rinse and repeat.
          • BattleshipBob
            • 6791
            • Bob
            • Cardiff
            Thanks Pete, appreciated
            chrisb
            Hi Chris, just messaged you, thank you!
            Thank you Tim, at least you all know I am breathing lol
            Hi Ian
            Thanks for the advice!
            I now have a few Fujimi kits in stock, I blame a sale in the UK stockist and interest free on PayPal
            • BattleshipBob
              • 6791
              • Bob
              • Cardiff
              Started on the funnels and bridge which also has a pe deck. Now there's many, many seams.
              There's four in total plus other parts and of course the dreaded funnels.
              Along with pe, seams are my biggest dread lol. Was going to try the superglue method? But worried about destroying the what I assume are railings for standing on or communication tubes?
              Could also try Mr surfacer?
              Does anybody have a better idea, sorry to be missing in action then back on the bum again lol
              To be fair the newer kits are now coming with many superstructure in one piece, so I assume slide moulding?
                • 18890
                Personally i would use tape to mask off the sensitive areas when filling, and again to protect the sensitive areas when sanding. I would just use normal filler on the seams.
                  • 15653
                  Sorry about your mum. It's the feeling of not being able to do anything that is so stressful.
                  Ship is coming on. Sometimes scraping a seam with a sharp blade before filling makes later sanding easier.
                  • BattleshipBob
                    • 6791
                    • Bob
                    • Cardiff
                    Thanks both, things I should know! But StuG's do not have seams lol so been lazy in my builds and I still rush but slowly slowing down!
                    • boatman
                      • Nov 2018
                      • 14451
                      • christopher
                      • NORFOLK UK
                      YOULL make a nice job of it bob just take your time an enjoy the build
                      chrisb
                      • BattleshipBob
                        • 6791
                        • Bob
                        • Cardiff
                        chrisb
                        I'll try lol
                        • BattleshipBob
                          • 6791
                          • Bob
                          • Cardiff
                          Bit more work on the bits and bobs
                          Main turrets, the barrels with moulded blast bags come separate so easy to paint the bags and then fit to the turrets plus the torpedo tubes with the dreaded long lance torpedoes.
                          Rear superstructure done, however like the bridge I have dropped a boo boo with the seams. Thanks to Ian I have only now discovered that you need two types of glues, thin for most work but thicker like contacta for seams to ensure its oozes out for a sanding to ensure a seamless finish!
ID:	1211514Click image for larger version
                          The kit comes with two simple jigs to make mast construction easier
ID:	1211516Click image for larger version
ID:	1211517learning a lot, simple things like using sanding sticks which were too rough so now using 400 / 800 plus very smooth. So not damaging parts by aggressive sanding!
                          Not sure what to do with the bridge as i used my normal very thin glue for a neat finish, however useless for seams!!
                          Not far off priming
                          Bit more happy now, thanks Ian!
                            • 18890
                            Only thing I can suggest for that bridge is old style filler (not acrylic). Build up the filler slowly then dress it back with a sanding stick to smooth out the step. Might have to replace that raised bit around the bridge with plastic rod though Bob, because you will lose some when cleaning up.
                            • boatman
                              • Nov 2018
                              • 14451
                              • christopher
                              • NORFOLK UK
                              youre gettin there Bob matey looks good an glad you are sortin out them seams
                              chrisb
