Brian's 1/100 HMS Victory
A bit confused It says I need 18 x 13mm loops but on the plan I see 4 required?
I have ordered the admirals entrance and steps (3D printed) so I need to take the existing steps off and cut a hole but I will wait till I get it.
Can't use Tamiya extra thin quick setting has a bad reaction to the plastic similar to the reaction I got from the Millennium falcon (the shock breaks the plastic)
Good start Brian. I will be following this with interest. If you need any help with French translation or any other ship details just give me a shout. In your place I would wait until the channels (the boards that hold the lower shroud deadeyes) are fitted and then it will be clearer which length of loops are necessary.
JohnComment
It's a bit hard to see which colour the loops have as they are on shadow. Would it be better if you wrote by the loop the size it should be. Could save a confusion along the way.Comment
