Trumpeter HMS Kent
  • andy55
    • Sep 2023
    • 325
    #46
    Not HMS Kent
    What have I ever done to pi** the universe off. Just adding the anchors and chains, decided to have a look and see how far the anchors go into the hull. That's interesting Kent only has 1 ONE starboard anchor, maybe added one later. No Kent only had One starboard anchor when she left the shipyard, she only had One when she went to the scappers. Then why does my model have TWO starboard anchors.
    If the window was open would be tempted to see if it flies. Not laughing...
    • andy55
      • Sep 2023
      • 325
      #47
      Well this is as far as it goes, tried doing the railings but don't have enough control of left arm. At least I didn't find out if it could fly...Click image for larger version
      • BattleshipBob
        • 6803
        • Bob
        • Cardiff
        #48
        Very nice Andy. Looks the business
        • andy55
          • Sep 2023
          • 325
          #49
          Thanks, would look better with the railing though.
          • spanner570
            • 15436
            #50
            Nice neat build, Andy
            Very well done.
            These ship models can sometimes try the patience of a Saint, so good for you for seeing it through - And Not fitting wings and a propeller!
            Seascape?
            • andy55
              • Sep 2023
              • 325
              #51
              Very well done.
              Seascape?
              Would have seen if it could fly without wings.
              The seascape will have to wait untill the railings are fitted. Depends how long it takes to get control back of my arm after surgery.
              • BattleshipBob
                • 6803
                • Bob
                • Cardiff
                #52
                Originally posted by andy55
                Well my early Xmas pressie arrived today, armourment for the Kent. Brilliant 3d printing from Micro Master. OK the older modellers will probably already be aware of them, but anyone returning like me, well have a look at their site. Micromaster.co.nz the below pic is of their pompoms with with kit one. Just annoyed I didn't get the 8 inch guns as well.
                Oh yer, ordered on the 7th Dec arrived today.[ATTACH=CONFIG]n1214662[/ATTACH]
                Well chuffed.
                Andy, was there much hassle cutting them away from there base and then cleaning up? Tempeted to buy some myself
                • andy55
                  • Sep 2023
                  • 325
                  #53
                  Hi, the pictures I put up were pretty rubbish, but if you've been on the site, yep they are as good as their pics. OK breaking them away, I only used a pair of needle nosed pliers, as per th sites pics everything is attached from underneath, so take your time and snap or cut the 'stays' away. I found my snips were to big so used the pliers. The only thing I would say (and they say on the site) it is a very hard resin they use so it is fragile.
                  Would I buy from them again. A very big yes. Oh sorry didn't mention, cleaning up. There wasn't any. The stays are so fine that they break away without leaving anything behind. On the ones that I got.
                  Andy
                    • 18271
                    Nice work Andy. Odd about the anchor mistake. Good job on the paint. I hope that the arm gets fixed up and you can do the rails.
                    • andy55
                      • Sep 2023
                      • 325
                      #55
                      Noticed when I started that moulded into hull and deck, HMS Cornwall. Didn't think anything of it at the time as both County Class. Not till I looked closely at pics of Kent did I notice, and sure enough Cornwall has the 3 anchors.
                      • Waspie
                        • Mar 2023
                        • 3488
                        • Doug
                        • Fraggle Rock
                        #56
                        It's an easy enough mistake to make. I'm sure only the seriously pedantic will notice the lack of anchor!! Doesn't in any way detract from a great build Andy.
                        As an aside and just an example. I served on two Tribal class frigates. (Type 81 for those that use class numbers). HMS Ashanti, excellent warship but quite basic being of a lower modification state. Although having a VDS on the stern. Due to a serious mechanical failure which rendered it knackered!!! Permanently. We transferred to HMS Tartar, another Tribal class. We needed retraining on the newer equipment, no VDS either.
                        Even the new Daring Class differ!!!
                          During my time in the MN, I stood by a new ship being built, and did her maiden voyage - I then served on one of her sister ships, All were built in the same yard, to the same plans, but there were differences - OK, minor ones, but enough to give you moment's pause - electrical boxes at different heights, pipes in slightly different positions. light switches on the wrong side. There were 'empty' mounting beds on one ship - a case of 'fitted for', but 'not with' - the other fitted with a fancy filter system. A visual difference was the spare anchor stowed on deck, on one it was fwd. at the break of the fo'c'sle, on the other it was aft on the maindeck. If this was the same builders, then I'm not surprised that there were differences when several dockyards built ships to nominally the same design...........
