Trumpeter German navy destroyer Z30
  • BattleshipBob
    • 6792
    • Bob
    • Cardiff
    Well folks another attempt at improving my floaty builds?
    Fletcher is all but done and will then be binned. Kagero is drying in primer.
    Was planning to do a battleship next but still need to show improvement in a few areas.
    So next is Trumpeters 1/350 German destroyer Z30 comes with a fair bit of PE, so ideal further practice
ID:	1220548Click image for larger version
ID:	1220549Click image for larger version
ID:	1220550Click image for larger version
    Drilled out portholes and additional holes on the deck. Fair bit of fettling to do but both decks fitting much better. So next is to glue decks into place
    Bob
    • 18266
    That's a smart paint job Bob.
      • 15655
      As Ian says the box art paint job is eyecatching. Sitting comfortably.
        • 18266
        I hope that I am not to late but I would paint the hull and most likely paint and build the deck and sheds THEN glue them together. That paints scheme on the hull looks like a lot of masking and holding...
        Those German destroyers are long skinny thing! lol
        • BattleshipBob
          • 6792
          • Bob
          • Cardiff
          Thanks Ian and Jim, was beginning to think I was on my own!
          Going to have a go at the paint job, most of the ships I have, do have various schemes. This is the scheme
          So quicker I learn how to do these patterns the better!
          Good thing which helps is the deck is one colour. Might follow your advice Ian, paint the hull and stripes, paint the single colour deck then fit? Have used a Tamiya stand and drilled two holes to mount the hull.
          Can finally see the advantage of mounting the Hull asap.
          So today built the 4 main gin battery and the main long superstructure, right pain to build and some tidying up to do Inc filler.
          Made the mistake on other builds of adding pe and small bits and bobs early then yes knocked them off. So leaving a lot of stuff until close to painting.
          More confident now.
          Bob
            • 18266
            Loving the camouflage design,
            • adt70hk
              • Sep 2019
              • 10400
              Looking very good indeed Bob....although at 1/350, a tad on the small side - even for me!! :smiling3:
              • JR
                • May 2015
                • 18273
                Looking fwd to the camo part Bob, just take your time and enjoy it.
                • boatman
                  • Nov 2018
                  • 14451
                  • christopher
                  • NORFOLK UK
                  HI Bob mate yes Ian is right as thats how i did my tiger AN all my other ships by building an painting the parts before fixen em on the ship as its a lot easyiery to mask up the parts when seperate
                  CHRISB
                  • Scratchbuilder
                    • Jul 2022
                    • 2689
                    Got a chair and sitting as close as the crowd will let me, hands in pockets so that I do not touch....
                    • BattleshipBob
                      • 6792
                      • Bob
                      • Cardiff
                      Yep it slightly crazy!! Should be a laugh trying to do lol
                      Hi Andrew, to be fair it not that small, thankfully lol.
                      Thanks John, appreciated
                      CHRISB
                      Sound and hard earned advice, ta!!
                      Hi not a big crowd yet so grap a seat your more than welcome
                      • BattleshipBob
                        • 6792
                        • Bob
                        • Cardiff
                        Today's progress
                        Added more decks to the rear superstructure, plus filler. Then started on the bridge bits, not happy with the fit, all the superstructure was very fiddly to hold together and glue. Most new kits thankfully use slide moulds and these items now tend to be in one part, yippee
                        To be fair Tamiya supply small bars to hold the large sections together, so much easier. Had to use filler in a good few places. Used the stuff ( forgot the name) then quickly removed the excess with a lightly damp cotton bud, so hopefully no sanding
ID:	1220839Click image for larger version
                        Ta ta for now
                        Bob
                        • JR
                          • May 2015
                          • 18273
                          Nice Bob, whats life with out filler :smiling:
                          • BattleshipBob
                            • 6792
                            • Bob
                            • Cardiff
                            Ploughing through the superstructure and what a pain. As it's a earlier kit it has I think no slide moulding? So small superstructure bits are made up of often 5 small fiddly bits, 4 walls and roof. Experimented by using blue tac on a small hand clamp. So I could rotate the bits
ID:	1221710Click image for larger version
                            Worked ok as the tac held the bits reasonably well. Could not think of a easier method? All I can say is god bless slide moulds lol. Just had HMS Exeter arrive and phew, almost everything is slide moulds, so my nails can grow back.
                            Right some progress. Most superstructure is done with a fair bit of filler. Everything is loose. Not a great fit in most areas.
ID:	1221712Click image for larger version
                            Next trying to see what can be fitted or painted off the ship. Then the dreaded PE bits. Then the strippy hull!
                              • 18266
                              It is an older kit so will put up a bit of a fight. Small sheds like you show here I find double sided tape handy. Or just stick them one part at a time. Tamiya extra thin is super quick for that. By standing them on the tape they don't run away when you try to glue them.
