Build the bismarck 1/200 scale (full build)
  • peterairfix
    • Jul 2012
    • 11074
    As my previous two attempts have got a bit wayward I am starting fresh with a complete set so I know I have everything with no hunting for missing issues.
    So I have 140 issues and starting with the first issue that starts with the first couple of frames.
    Frames marked.
ID:	1228024Click image for larger version
    And the first construction stage finished Click image for larger version
    • 15668
    A 1/200 scale Bismarck. Now that will be some model, a real stunner.
    No excuses then :smiling3:
    • Bri62
      • Jan 2023
      • 1879
      • Brian
      • Widnes Cheshire
      Chair pulled up, looking forward to this build.
      • HAWKERHUNTER
        • Feb 2012
        • 1562
        • Steve
        • Halifax, West Yorks.
        Good luck Peter. This will be worth following.
        • peterairfix
          • Jul 2012
          • 11074
          Frame complete up to issue 3 not very difficult just having to make sure that the frames are square Click image for larger version
ID:	1228157Click image for larger version
ID:	1228158Click image for larger version
          And making sure that the deck beams are flush with the tops of the framework Click image for larger version
ID:	1228159Click image for larger version
ID:	1228162Click image for larger version
          • scottie3158
            • 14201
            • Holbeach
            Chair pulled up no sugar in the tea please.
            • boatman
              • Nov 2018
              • 14451
              • christopher
              • NORFOLK UK
              SAME HERE
              • peterairfix
                • Jul 2012
                • 11074
                The main skeletal structure is complete ready for sanding and planking Click image for larger version
                  • 15668
                  Looks good.
                  ..... just having to make sure that the frames are square
                  I image that time spent on accuracy at this stage will avoid problems later.
                  • peterairfix
                    • Jul 2012
                    • 11074
                    I have now started on the first layer of planking I should take a week or two depending if I have any problems Click image for larger version
ID:	1228419Click image for larger version
                    • simontie
                      • Jan 2010
                      • 1506
                      Looking really good my chair is pulled and the kettle is on
                      simon
                      Why is common sense not so common?
                      • peterairfix
                        • Jul 2012
                        • 11074
                        I am about 1/3 into the planking Click image for larger version
ID:	1228480Click image for larger version
ID:	1228481Click image for larger version
ID:	1228482Click image for larger version
                        And I know I have got the planking equal each as the planks are in the exact same place either side Click image for larger version
                        • adt70hk
                          • Sep 2019
                          • 10400
                          Cool! That will look brilliant once done!
                          • BattleshipBob
                            • 6792
                            • Bob
                            • Cardiff
                            Got to amend the skill and patience Peter. Great start
                            • boatman
                              • Nov 2018
                              • 14451
                              • christopher
                              • NORFOLK UK
                              HI Peter this is just goin to be a static model is'nt it ?
                              chrisb
