Looking again Chris, I think that's right. Sorry Bob - your barrels do match :smiling3:
Ironclad IJN NACHI 1943
YES Jim the chappie is doin well isnt he an i think the reson the gun barrels look differnt lenghts is due to one gun barrel is pointin downwards so the barrel looks longer well done my freind keep the pics comin Bob mate an them guns look very detailed for their size
ATB my freind
chrisb
Thanks Ian
You may have noticed the seams on the curve of the bridge. Now I was planning to just do a no messing about build but that seam sure stands out, so might scrape seam and try filler
Any opinions or suggestions
BobComment
Oh! That one. I thought it was a panel detail LOL.
Yep. you might want to fil that. Sorry for not seeing that for what it was. I really thought that something else, a conduit or a vent of some kind would be placed there.Comment
Could not build a ship to save my life, got two in the stash and they will be there 'till my bones turn to dust...
BUT, I do love to watch you guys turn plastic into masterpieces, and this will be another.Comment
Masterpiece I think not lol. Others not me! Go on give it a go!Comment
Made a start on that seam, was originally going to leave but it's a bit obvious and nothing covers it! So going to do it small stages, starting at the bottom on starboard
So using tape to protect the hand rail
Left to dry and made a start on the hull and decks, dry fitted and the fit looks OK. Surprised how big it's about 28cm! Going to be fiddly to assemble.
The box is to keep it all together lol
Mind you it looks impressive
Built the hull today and first fit issues. The hull is in two parts and has 7 internal bracing pieces, i fitted them nice and tight otherwise the decks would have large gaps around the edge! After fitting them I noticed that lower hull is not the best fit, so might need a bit of filler. On the plus side the decks fit well. Also drilled the hull to fit the kit supplied plastic pedestals, wish all kits came with these!
Seriously thinking of painting the decks before fitting. The middle section really has to be painted first, it contains the torpedo tubes but has another deck on top
BobComment
Right bit more progress
Started on parts of the superstructure
Seams to fix
Added the front of the bow where the chrsythanum ( spelt wrong?) Was located. Not a good fit so filler drying
Finally sorted out of section of the nasty seam on the bridge
Before
 After
Bit of overspray to tidy up so on the rest on both sides
BobComment
