Brian's Caldercraft 1/72 HMS Victory
  • Bri62
    • Jan 2023
    • 1879
    • Brian
    • Widnes Cheshire
    #46
    this mornings work was critical to get right so took my time and checked levels.
ID:	1230925Click image for larger version
ID:	1230926Click image for larger version
ID:	1230927Click image for larger version
ID:	1230928Click image for larger version
ID:	1230929Click image for larger version
    You can never have enough clamps/clips
    • flyjoe180
      • Jan 2012
      • 12378
      • Joe
      • Earth
      #47
      This is looking superb Brian :thumb2:
      • Bri62
        • Jan 2023
        • 1879
        • Brian
        • Widnes Cheshire
        #48
        Cheers Joe, got a feeling the hard stuff is still to come
        • Bri62
          • Jan 2023
          • 1879
          • Brian
          • Widnes Cheshire
          #49
          Done for the evening
ID:	1230948Click image for larger version
          • Peter Gillson
            • 2594
            #50
            That is coming along nicely. My only criticism is that your bench is far too tidy!
            Peter
            • Stefee
              • Feb 2023
              • 780
              #51
              Brian take no notice of the bench club of the untidy, I thought my bench was clean but now I'm not so sure.
              The build is coming along beautifully.
              • Bri62
                • Jan 2023
                • 1879
                • Brian
                • Widnes Cheshire
                #52
                Hi, did some more today but had to wet the wood clamp it and let it dry so looks like I did very little
ID:	1231003Click image for larger version
ID:	1231004Click image for larger version
ID:	1231005Click image for larger version
ID:	1231006Click image for larger version
                And I got Tangoed
                  • 15652
                  Originally posted by Bri62
                  ....had to wet the wood clamp it and let it dry
                  Was that due to the part being slightly warped or just to get a part to fit?
                  • Bri62
                    • Jan 2023
                    • 1879
                    • Brian
                    • Widnes Cheshire
                    #54
                    Just to get it to fit properly I have no doubt it would have split If I had tried it dry
                      • 18264
                      Just went to make a cup of coffee and your halfway through the hull! Better get some instant in!
                      A good trick if you have a bit of wood that need bending is to let it have a bath in some ammonia for a while. It really softens the wood up. and easier than steaming. Rinse out under running cold water to get the pong off it. An old trick used for planking wooden ship models, does smell a bit. Clears the sinuses though.
                      • Bri62
                        • Jan 2023
                        • 1879
                        • Brian
                        • Widnes Cheshire
                        #56
                        Yes Ian I know about Ammonia but the smell, I would rather use water and a bit of heat. That was some cup of coffee
                        • Waspie
                          • Mar 2023
                          • 3488
                          • Doug
                          • Fraggle Rock
                          #57
                          HMS Victory - was going to be named HMS Clamp-it!!
                          It's just as well you have sufficient Brian. My 6 wouldn't do at all!!!!!
                          You have certainly made a super start to the iconic warship. :thumb2:
                          • minitnkr
                            Charter Rabble member
                            • 7513
                            • Dayton, OH USA
                            #58
                            That's a serious pair of clamps there......can never have too many......
                            • Bri62
                              • Jan 2023
                              • 1879
                              • Brian
                              • Widnes Cheshire
                              #59
                              Afternoon, let it all dry removed and then glued and pinned, on to the first planking when this is properly dry got to admit I have not planked anything before so a bit uncertain how it will go.
ID:	1231019Click image for larger version
ID:	1231020Click image for larger version
ID:	1231021Click image for larger version
                              • wotan
                                • May 2018
                                • 1150
                                #60
                                Brian
                                Just some little tips for your planking. Firstly try to sand the edges of the hull profile formers (ribs) so that they correspond to the curvature of the hull. This is important at the stern and around the bows. Some people even fill in the gaps between the stern ribs and the bow ribs with some blocks of balsa wood sanded to the round form of the hull. This helps the planks to stick more solidly where the curvature is at its greatest.
                                Just take it slowly and I am sure you will have no problems.
