Looking good,I find the PE add a lot to model boats.
papa 695's Bronco 1/350 Ting Yuen
Got the decks fitted
[ATTACH]91115.IPB[/ATTACH]
[ATTACH]91116.IPB[/ATTACH]
Also weathered the hull
[ATTACH]91117.IPB[/ATTACH]
[ATTACH]91118.IPB[/ATTACH]
[ATTACH]91119.IPB[/ATTACH]
[ATTACH]91120.IPB[/ATTACH]
Painted the little dragons, there are also two on the front
[ATTACH]91121.IPB[/ATTACH]
Started to do the two funnels and fitting the PE
[ATTACH]91122.IPB[/ATTACH]
[ATTACH]91123.IPB[/ATTACH]
[ATTACH]91124.IPB[/ATTACH]
[ATTACH]91125.IPB[/ATTACH]
[ATTACH]91126.IPB[/ATTACH]
Got the motor launches put together and done some PE work
[ATTACH]91370.IPB[/ATTACH]
[ATTACH]91371.IPB[/ATTACH]
[ATTACH]91372.IPB[/ATTACH]
Also put some bits on the front
[ATTACH]91373.IPB[/ATTACH]
[ATTACH]91374.IPB[/ATTACH]
[ATTACH]91375.IPB[/ATTACH]
And started to do the base for this one before all the super structure goes on
[ATTACH]91376.IPB[/ATTACH]
[ATTACH]91377.IPB[/ATTACH]
[ATTACH]91378.IPB[/ATTACH]
Not had much time for modelling this week. But got most of the base done it still needs the clear sealant putting on when I finally finish the build.[ATTACH]92012.IPB[/ATTACH]
[ATTACH]92013.IPB[/ATTACH]
[ATTACH]92014.IPB[/ATTACH]
[ATTACH]92015.IPB[/ATTACH]
Also got some more parts put together and painted
[ATTACH]92016.IPB[/ATTACH]
The next two photo's are just to show the size of this. The last picture is the 1/350 Ting Yuen inside the hull of the 1/350 Illustrious.
[ATTACH]92017.IPB[/ATTACH]
[ATTACH]92018.IPB[/ATTACH]
Got some more parts on this.
[ATTACH]92403.IPB[/ATTACH]
[ATTACH]92404.IPB[/ATTACH]
[ATTACH]92405.IPB[/ATTACH]
[ATTACH]92406.IPB[/ATTACH]
[ATTACH]92407.IPB[/ATTACH]
[ATTACH]92408.IPB[/ATTACH]
[ATTACH]92409.IPB[/ATTACH]
The guns have PE parts with the kit [ATTACH]92410.IPB[/ATTACH]
But in the extra PE set I got they look better so I used them [ATTACH]92411.IPB[/ATTACH]
but boy are they small [ATTACH]92412.IPB[/ATTACH]
[ATTACH]92413.IPB[/ATTACH]
[ATTACH]92414.IPB[/ATTACH]
[ATTACH]92415.IPB[/ATTACH]
[ATTACH]93403.IPB[/ATTACH]
[ATTACH]93404.IPB[/ATTACH]
[ATTACH]93405.IPB[/ATTACH]
[ATTACH]93406.IPB[/ATTACH]
[ATTACH]93407.IPB[/ATTACH]
[ATTACH]93408.IPB[/ATTACH]
[ATTACH]93409.IPB[/ATTACH]
As you can see I've got a LITTLE bit more done. Some of the parts are so small you can hardly hold them to paint them.
