This is my first model. But I would like to get it to look as authentic as possible. I put the flag as a joke[ATTACH]310206[/ATTACH][ATTACH]310207[/ATTACH][ATTACH]310208[/ATTACH][ATTACH]310209[/ATTACH][ATTACH]310210[/ATTACH][ATTACH]310211[/ATTACH][ATTACH]310212[/ATTACH]
Revell 1/72 U-505
GuestTags: None
Looking quite good — and a brave choice too, going for something as complex as this for a first model.Comment
My U-505 is almost completed and now working on base coats. Lower hull and conning tower in German gray. Upper hull is Sky gray.
should i do my decking in German gray? Id like some wood color to show through buy not sure what color for the woodComment
She's almost ready for her first patrol. has her base coats of paints on the hulls.
need to finish the decking, paint the props and then I'm on to weathering.
Can anyone give me some paint ideas for a scum line along the hull?Comment
Originally posted by spanner570Looking good Erik.
Regarding the scum line, I very much doubt there would be one. The wave and diving actions would probably not allow one to 'Grow'. I just dirtied the hull.
Your boat, being a different type might have had a steel deck. Take a look at Google Images of your particular boat for ideas and confirmation. Although looking at your pictures, it looks like a mixture of both wood and steel decks.
Keep in mind it's your boat and we all have different interpretations of what we want on the finished model.
I look forward to seeing the finished model.
Ron
This is my first build but I want it to be as accurate as possible. The U-505 was fairly beat up when it was captured so I want it to be weathered. Can you recommend the paints for the wood.
Iv worked in ship yards and you’d be surprised on the amount of rust ships and tugs have. But it was mostly streaks on the sides and decks. So for a ship that spent time out at sea there would be a fair amount.
Also rust really happens to the areas above water not so much under water as it’s the water and air that creates itComment
Not really a ship guy but for some reason I like subs....sure is a big-un.
Very first model aye?...an ambitious project indeed, but you seem right at home with it and it's looking like an experienced modeler
is doing it, good for you!:thumb2:
From N.Y.C. I see, what part? I was born and raised in Bklyn till about 25 years ago. I now live way up in the Adirondack Mts.
Am watching this one :thinking:
Jim.Comment
I’m from Staten Island, spent some time up in the Catskills.
What are you guys thought on a brown filter for the deck after the German gray?Comment
So I painted my conning tower to night and it did not go great. I pre shaded and then sprayed gray. The paint was coming out way to thick.
one side looks ok, the other side not so much. Also I dropped my airbrush well cleaning it and the nozzle bent so Im dead in the water till a new one comes. Here are some pics.
Hi, it still looks nice but I can see what you mean, preshading requires very thin layers of paint if you don't want to hide the effect...
But you can go in again with a subtle darker version of the base color, but take your time if you do it like that.
Cheers, nice project :thumb2:Comment
I have a question. my compressor does not adjust. Im using an IWATA revolution airbrush. How can i make thinner lines?
I may just go back in and preside it again and then re do my base. the problem is im still learning how to use my air brushComment
