The rag tag crew is assembled so let's start the patrol.....
The first job for anyone modelling a U. Boat is to drill out all the water vent openings, of which there are many. This has to be done whatever the scale or I think the boat just won't look right. Your choice whether to or not. If a waterline model is required then just drill out the ones which will be seen. Choose open or shut forward torpedo outer doors (Mine are closed) then join the hull halves.
Opened out ready for tidying up.
[ATTACH]317670[/ATTACH]
See the two large openings? Don't open these out. I did by mistake, and yes I've lashed myself with a knotted rope soaked in sea water - Very nice too!
[ATTACH]317671[/ATTACH]
Here's a good tip for any ship model that has slot-in decks. See the two hull stiffeners? Before fixing them, file away some of the plastic edges from 9&3 o'clock to the top of the pieces. Not too much, just enough to show a very small gap between them and the outer hull. Then once the hull and stiffeners are glued together the deck will now be ever so slightly oversized. This will allow you to file the deck to a perfect fit. The other, rougher method is to fit the deck then fill any gaps with filler....Nah!
[ATTACH]317672[/ATTACH]
Thanks for showing me that trick Dad.....Miss you.
Cheers.
Ron
Cheers.
Ron
