Looking dapper Ron
Revell 1/72 VIIC/41 'Atlantic Version' German U. Boat
Well Ron, I have been following this from the beginning, but it seems I have forgotten to comment on this beauty. For that, I must apologise to you and now,
"COMMENT!!!"
There, I feel so much better now...โฆโฆโฆ.
AllenLife's to short to be a sheep...Comment
Thanks Paul. Writing that I'm easy going with my builds keeps the rivet counters and nit pickers from making any adverse comments 'cos they know it's a waste of time and they go after someone else. Not that we have any of those types on S.M.......Comment
On we go.
Thanks to all for the great and humorous comments. All good stuff and they make this build all the more pleasurable to put together.
I've glued and painted the underwater bits. Not many and very straight forward.
The forward dive planes and bronze anchor fitted.
[ATTACH]320022[/ATTACH]
[ATTACH]320021[/ATTACH]
Stern dive planes, rudders, prop. shafts, protective skid and screws.
[ATTACH]320024[/ATTACH]
[ATTACH]320023[/ATTACH]
Apart from the rigging, that's the boat built.
Time to get the yard brush out and start the weathering! Then I'll tackle the rigging....:cold-sweat:
Cheers.
RonComment
The sub is looking great.
JimComment
Cheers chaps.
I mentioned on page two how with the big flat headed brush, I first coated the whole hull with a wash of brown/grey acrylics and let the paint run where it chose to go thus leaving streaks.
Here is the result of a second similar coat. Because I couldn't faff about with such a large area (near enough 36") I had to be quick. A couple of minutes for both sides is all the time I had or the effect would have been lost due to the paint drying too quickly. See how it's produced a fair amount of dark stains by just letting the paint run where it likes over the first coat? Here and there the paint has gathered around the open 'vents' and then run even darker streaks down the hull. All from just two coats and no fiddling about........I've never done such a large area of plastic before and I must confess to being well chuffed at the result......:thumb2:
Here's the before and afters.
[ATTACH]320081[/ATTACH]
[ATTACH]320082[/ATTACH]
[ATTACH]320083[/ATTACH]
I also gave the stern gear a coat of the same colour. The paint has nicely gathered around the rivets too.
[ATTACH]320084[/ATTACH]
Keep it simple and work fast!
I don't like to see operational U.Boat models caked in rust as some seem to be. Of course it's the individual's model not mine, but I firmly believe there would be very little if any, actual rust on these boats. My reasoning is that.
A. The boats weren't around long enough for rust to form and......
B. I think they would be well looked after and kept in good condition by the proud crew and re-painted where required whilst back in their pens.
C. A lot of time spent underwater.
D. Being leathered by the Atlantic swells.
So all I'm doing on mine ( right or wrong) is some oily, grimey brown water stains. So what I have done up to now might well suffice.
Thanks for looking.
RonComment
Seriously tho Ron, so far the painting is looking good.:thumb2::thumb2::thumb2::thumb2::thumb2:
Paul
:smiling2:Comment
Excuse my ignorance Ron but if you have holes in a sub does it not sink? Are the holes part of a hollow part of the sub with the solid part of the sub underneath?
P.S Weathering is spot on:thumb2:Comment
