1/144 MikroMir Holland class submarine
    After the ICM 1/144 Type IIB sub, I decided to have another go, even smaller, the first Royal Navy submarines
Name:	mikro-mir holland.jpg
    This is a short run model, but the injection moulded parts are delicate, as are the PE parts. I got a bit ahead of myself & glued the hull together before taking the piccies!
ID:	1143123Click image for larger version
ID:	1143124Click image for larger version
    You can choose any one of the 5 members of this class, the differences being slight paint variations & decal numbers. Although a White Ensign is provided, it was only seen at launch - at sea there didn't seem to be any flag flown!
    The class had a crew of 8. No.5 has half her crew on deck - there are towing cables rigged along the side of the hull. An officer is sitting on the edge of the hatch/conning tower ( fore & aft cap ) - the rating in front of him is at the helm. The 3 smaller light coloured pipes are air tubes - the taller pipe is the ( fixed ) periscope.
    I've decided to do a waterline model, despite it going to be rather small. I think that the 'N' gauge railway passengers will be converted to RN matelots & officers
    • 15692
    Hi Dave
    Your last sub worked out really well. Looking forward to seeing you tackle this tiny one.
    • Bortig the Viking
      • Mar 2019
      • 780
      Maybe it would get wet, lol. :tongue-out3: :smiling2:
        Being such a tiny model, progress can be quite quick - I made a lipped base - I used masking tape to lay out a rough waterline. Then vertical cuts..........................
        Horizontal cuts to remove the excess material - keeping close as possible to the tape
        After removing the tape, I sanded the hull down on a sheet of emery paper it doesn't have to be perfect, as the sea will cover the waterline
        Hull added to the base - I'll roughen up the plastic card, so that the DAS will have something to key into. I'll use two layers to avoid cracking & warping
        The depth of sea will be 1mm plus the 'waves'
        • rtfoe
          • 9083
          Nice Dave that you're doing it waterlined. A submarine in its natural state with three quarters of its body submerged. They remind me of the British X Class subs.
            I found this:
            I suspect that the artist has made it more roomy than it actually was!
            • Bortig the Viking
              • Mar 2019
              • 780
              I found this:
              [ATTACH=CONFIG]n1143133[/ATTACH]
              Would I be right in assuming this only went out in shifts, as I can't see any living/sleeping quarters, it must have felt a bit like a coffin in there.
                Well, the range of these A class was 250 miles @ 8knots = 30+hrs. They could spend a day and a half at sea. So they would be on watch keeping - only 4 sleeping/resting at a time, the others being on duty. Generally the crew would bunk on a depot ship, whilst in port, the sub being moored alongside. All of these crews were volunteers, and they would receive 'hard lying money', a small bonus on their pay for bad conditions. It was very hazardous, on an essentially experimental vessel. ( I once visited a modern RN sub & I was claustrophobic on that!!!!)
                  The first layer of DAS applied, the plastic card surface was dampened, to give better adhesion
                  The final thin skim will add the sea details - DAS can be thinned with water, to a slurry, that you can use a paintbrush ( kids' nylon brushes are ideal ), to smooth & add ripples etc.
                  This will now go into a cool room for a day or so, so that when it dries, it doesn't crack - at least not too much!
                  • dave
                    • Nov 2012
                    • 1828
                    • Brussels
                    interesting subject, I went on one of the old diesel-electric O-boats at Faslane, and I will second them being cramped. As I recall I could only stand upright in two places, underneath the conning tower and underneath the forward torpedo loading hatch.
                      I visited HMS Alliance ( when she was still in commission ) when I was a teenager, at a Navy Day ( Falmouth? ), It was cramped, dank, claustrophobic and smelled! Now, I recognise that was a mix of oil, diesel and bilgewater, which I became familiar with a few years later..............
                      There's no way I would go underwater on one of those things! I spent all my time in the MN trying to stay on top of the water - and succeeding!!!
                      • stillp
                        • 8093
                        • Pete
                        • Rugby
                        My only experience was a trip around a US submarine at Battleship Park near Mobile, Alabama, which was quite roomy - enough headroom in most places. I still wouldn't want to spend days/weeks in one though.
                          Ouch, I visited Mobile in the mid 80's - the most unsettling place I ever visited in the States, the racial tension was really frightening ( and I visited some scary places in the 80s! ) - I went ashore once, and that was enough for me...........
                          • stillp
                            • 8093
                            • Pete
                            • Rugby
                            Scariest place I've been in the USA was Louis Armstrong Park in New Orleans. Lovely park, but as the sun went down and the drug dealers started setting up shop in their trucks, I realised I was an ethnic minority...
                            I didn't actually go into Mobile, just Battleship Park. My hotel and conference centre was at Point Clear, across the bay. Nice place, 3 staff for every customer so great service, even by US standards.
                              New Orleans! Bourbon Street, Basin & Canal Street - had a few good nights out there - only problem was that after a few drinks - all the live Jazz groups sounded the same. We eventually found a sidestreet bar - which advertised 'positively no jazz here' - it was packed!
