Jack's Border 1/35 U-Boat Conning Tower
  • monica
    • Oct 2013
    • 15169
    #106
    looking at it like Mark1 said ,the far side the support bar is facing backwards ,by the look of it and
    this close side is the other way,,
    • Jack L
      • Jul 2018
      • 1271
      • Cheltenham
      #107
      I do see what you and Mark mean. I’ll have another look tomorrow. Thanks all
      • Jack L
        • Jul 2018
        • 1271
        • Cheltenham
        #108
        Ok thanks for the observations, you were all right and it’s supposed to be the other way round. Were I was confused, there should be a protrusion that has snapped off somewhere, so I’ll need to scratch something there which shouldn’t be too difficult, although I was going to paint and weather the slide separately…my need to rethink that now.Click image for larger version
        And with the guns made up (I have seen less complicated stand alone kits), that is construction complete. Next step is painting.
        The AA gun was a pain in the arse. I could not get that mesh to fit at all….so some more ‘tactical damage’ has been added.
        Started painting the torpedo, not a single picture seems to show a consistent colour scheme.
        • monica
          • Oct 2013
          • 15169
          #109
          so glad that you got it sorted,it happens at times you just dont see it,
          look forward to more updates
          • Mini Me
            • Jun 2018
            • 10711
            #110
            Looks good Jack....That deck gun looks the Bomb :thumb2:
            • Jack L
              • Jul 2018
              • 1271
              • Cheltenham
              #111
              Waiting for some paint from John, so been painting a couple of the figures. Not sure about them if I'm honest. Primed in black, sprayed white from above and then went with a glaze in the respective colours. I don't think it's worked. Found it hard to get the glaze consistency right, it was either 'bubbly' and blotchy, or too think and lost it's transparency. Was not as easy as youtube suggested (as per).Click image for larger version
                • 15707
                Painted figure looks fine. I find a drop of flow enhancer and some retarder helps acrylic glazes to cover evenly.
                  • 18908
                  Figures look ok to me Jack.
                  I’m guessing you diluted with water? The blotchy effect occurs because you have over diluted the paint. This is worse with lighter colours because of the white component of the pigment.
                  Regarding glazes, it’s best to dilute with glaze medium, and use darker colour’s because they work more effectively. If you want to glaze with lighter colours inks are more reliable, but still not great. My hint would be to paint the piece with the lighter colour then glaze it to add the shadows.
                  • Jack L
                    • Jul 2018
                    • 1271
                    • Cheltenham
                    #114
                    Thanks Jim...had another go using flow improver instead of water. Worked much better!
                    Yes diluted with water (as per nightshift). The main colour I'm going with is a German Grey, mixed with a tiny bit of tan. Have gone again with some flow improver instead of water and it's definitely worked better. Thank you.
                    Now comes the battle with skin tones. I want them pretty pale looking, but may have gone a bit too pale with the skipper. The fellow far tight is a better shade. The other two have only had a first coat.
                    • monica
                      • Oct 2013
                      • 15169
                      #115
                      nice going with the figures ,never easy
                      • PaulinKendal
                        • Jul 2021
                        • 1608
                        • Kendal
                        #116
                        Just caught up with this - what a fabulous build! The scratch building is fantastic - attacking a kit like this must take a great at deal of courage, and plenty of skill to not muck it all up.
                        • Neil Merryweather
                          • Dec 2018
                          • 5190
                          • London
                          #117
                          Don't sweat the paleness of the flesh tones, I think it's a valid idea.
                          If you're happy with the actual painting side, leave well alone and just bear it in mind for next time.
                          • Andy the Sheep
                            • Apr 2019
                            • 1864
                            • Andrea
                            • North Eastern Italy
                            #118
                            The figures look fine to me. The skipper could be a fair/red haired guy, thus with a paler complexion than his crew.
                            • stillp
                              • 8094
                              • Pete
                              • Rugby
                              #119
                              The skipper looks just fine to me.
                              • rtfoe
                                • 9086
                                #120
                                Originally posted by Jack L
                                Not all that uniform, but not sure that will be noticed when in place. May need a couple more when I see what will and won't be seen.[ATTACH=CONFIG]n1190946[/ATTACH]
                                Well done Jack. I did the same for my 1/72 Walrus catapult leveling handles...saves time and money. Haven't been on your post lately but had I, would have edged you to do it this way.
                                To make same size circles I would wrap the wire a couple of times round the dowel and snip along one side.
                                I bet it was more satisfying making em.
                                Wabble
